Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Dec 28, 2021 at 4:13 PM
    #181
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    In my Tundra; (2021) vintage, Toyota changed the oil at 5000 miles with Pennzoil 0 - 20.
    I had some clickety clack so I threw in a bottle of Ceratec and the engine was electric motor quiet.
    My oil changes are Pennzoil 5-30 with a bottle of Ceratec.
    Improved mileage and cemetery quiet.
    sd172, Trust86 and cran2 like this.
  2. Dec 28, 2021 at 5:03 PM
    #182
    Trust86
    Trust86 New Member
    2007 DC
    This last oil change I threw in 3 quarts of 0W 40 Amsoil signature series and 5 quarts of Castrol 5W 40 bc it was leftover oil I had lol. Sounds amazingly quiet and smooth. The wife’s car (2017 sienna) also calls for 0w-20 and that sounded like a diesel straight up. Threw 5w-30 in it and the difference is night and day, noise wise.
  3. Dec 28, 2021 at 5:15 PM
    #183
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Do you remember in the old day's, in the 70's when gas and oil where in short supply. The price triple, that's when a lot of us switch to recycled 30w recycled oil.
    Most cars started to smoke when they hit 60,000 miles on them, and a lot of truck and cars didn't make passed 100,000 miles, without a rebuild.
    I remember when we used lots of recycled oil in the military.
  4. Dec 28, 2021 at 5:18 PM
    #184
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    I had a 4.6L SOHC V8 engine in a Ford Mustang once. It was an engine that was used for many years. In the early years of production they spec'd 5W30. In latter years they spec'd 5W20. There were NO changes to the engine. It was very obviously a ploy to score higher on EPA CAFE numbers.
    I ran 5W20 in mine for a while and got oil analysis each oil cycle. I then switched to 5W30 of the same brand and ran that for a while with oil sampling. The 5W30 produced lower wear metal numbers in the oil samples, which of course makes sense.
    My Tundra will never see a 0W20 or 5W20 oil.
  5. Dec 30, 2021 at 9:51 AM
    #185
    Nowhereman
    Al
    Monterey Bay area
    Back then there was an ad for a toilet paper oil filter conversion.
    Twin canisters that held toilet paper to filter your oil twice as good as a conventional filter.
    Never knew anyone who use em though.
    Sumo91 likes this.
  6. Dec 30, 2021 at 9:53 AM
    #186
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    It's a pretty common set up on older diesels, it actually is a really good bypass filter, people use toilet paper rolls, or a paper towel roll.
  7. Feb 3, 2022 at 7:41 AM
    #187
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Anybody used 5W30 full synthetic from Quaker state? Any difference to Pennzoil? Both are from Shell and there is price difference in favour of Quaker state. Is it just brand loyalty craze?
  8. Feb 3, 2022 at 12:07 PM
    #188
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    0W30 = year round use whether it's hot or cold outside
  9. Feb 3, 2022 at 12:10 PM
    #189
    Mobeyk
    Mobeyk New Member
    They didn't add 0W30 but here is the rest. Good comparison list.
  10. Feb 3, 2022 at 12:29 PM
    #190
    AZBoatHauler
    So.Arizona
    Rumor is Toyota branded oil is made by Mobil 1. I get 5qt jugs of Mobil 1 at wal-mart for $26. They also go on sale at Costco every now and then 6qt case for $27. Hard to beat that.
    Cpl_Punishment likes this.
  11. Feb 3, 2022 at 1:14 PM
    #191
    737fixer
    737fixer New Member
    Correct my confusion. There are a million charts that show outside ambient temperature and what oil to use. Then there are another million forums where people argue for example me here in Phoenix and its 115 degrees in the summer that one should switch to a higher viscosity oil. EVERYTHING keeps using the outside ambient temperature as the reason. But engine oil doesn't care about the outside temp. once it's at operating spec. My truck oil temp in summer is literally only 2-3 degrees higher then coming home last night from work when it was 35 degrees. The oil is operating in the same environment at operating temperature. I could understand changing the W(winter) viscosity but not the normal operating viscosity. I talking in general here as our trucks do have different viscosity numbers for other countries even though the engine is the same. I just find it odd that outside ambient temperature is even a consideration in the topic.
  12. Feb 3, 2022 at 1:27 PM
    #192
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Damn, it regularly gets above 90 here in socal,looks like i should be using 15w-40. That would cover the whole band of temperature my truck sees a year from winter in the mountains to heat in the summer.
    Saltyhero13 likes this.
  13. Feb 3, 2022 at 1:30 PM
    #193
    Mobeyk
    Mobeyk New Member
    Its somewhere in this thread said correctly, what it comes down to is the first few minutes till you reach operating temp of engine. That time frame is the one that causes the most friction and ambient temperature plays a role. In addition, the manufacturer used the ambient temp range to classify oil viscosity for the every day consumer. Cooling engine at higher ambient temperatures might play a role too in the long run for longevity of the engine oil, how else would you be able to generalize oil change intervals as a guideline?
  14. Feb 3, 2022 at 5:15 PM
    #194
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    From my 2021 manual
  15. Feb 4, 2022 at 3:30 AM
    #195
    Bammer
    Monroe, CT
    Outside temperatures matter when it drops below zero, I got a lot of flak from friends and family when I say use 0W30, they say, NO WAY TO THIN ! I say , look to the right of the W , thats where you're looking to be once warmed up to operating temperature. 15w40 is for diesels , and that is going by the wayside with new and improved modern diesels.
  16. Feb 4, 2022 at 4:36 AM
    #196
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Does anyone know an example when any oil changed at a reasonable interval did cause any damage to the engine? Just curious.
  17. Feb 4, 2022 at 4:40 AM
    #197
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    now you went and did it....you are gonna lather up the oilies.
    asking for facts. you should know better.
    of the oil related failures....99.99999% had to do with oil availability. keep oil in it. any oil. I use cheap oil. and that cheap oil tested as well as M1.
    more facts...https://www.youtube.com/c/IDoCarsalldaylong
    this dude shows the actual engines & what happens when you starve oil.
    sd172[QUOTED] likes this.
  18. Feb 4, 2022 at 4:46 AM
    #198
    sd172
    sd172 New Member
    South Dakota
    I am just trying to keep this discussion interesting. Wouldn’t it is amazing to see an engine fail spectacularly just because someone put the wrong viscosity oil in it?
    And yes, if your engine consumes oil, it is already dead.
  19. Feb 4, 2022 at 5:02 AM
    #199
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I agree.
    on the Bobistheoilguy site, they talk about everything EXCEPT the obvious fact that engines don't fail if they are oily.
    I ran my 84 Acura integra on Castrol 20w-50. I sold it with 195k miles on it. purred like a kitten.
    now I ran Castrol for YEARS....then I switched to M1, because of the coupon. that stuff cleaned the brown film from my dipstick in one oil change. (a joke is in there)
    so I used M1 from then on. then a Costco was built near my house. Kirklands 0w-20 it is.
    yes, I ran the teflon shit back then & zmax...but my cars still ran.
    I miss my 06 sequoia...big ole smooth riding land yacht with 12 cup holders.
  20. Feb 4, 2022 at 5:03 AM
    #200
    Bammer
    Monroe, CT
    NOPE
    Friend had a Jeep pick up, 1986 or 7 ?? Never did an oil change EVER ! It made it to 188,000 miles before the sludge stopped it cold.
  21. Feb 4, 2022 at 5:39 AM
    #201
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    I knew a guy locally who ran a busy roofing company who bought Ford pickups new and swore he never changed the oil. He added as needed and got rid of them at around 100,000 miles. I asked him if he didn't realize he could easily go twice that with regular maintenance, and he said they were so beat up by then it didn't matter. :)
  22. Feb 4, 2022 at 6:19 AM
    #202
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    This must be why my uncle had such bad luck with the used Fords he bought.
    Alex38, R65, bjp and 2 others like this.
  23. Feb 4, 2022 at 6:45 AM
    #203
    Retired...finally
    There is something to that attitude. I sold our 2011 Honda Element and upon gathering all the service reconds pondered just how much all that time and expense increased the price I would get. My conclusion was very little. To 90% of potential buyers all those records meant very little. Everyone offered the same. What KBB said it was worth.
    sd172 likes this.
  24. Feb 4, 2022 at 6:48 AM
    #204
    nobodyintexas
    nobodyintexas What?
    South of Houston
    very good point.
    at the end of the day...assuming it runs...nobody cares.
  25. Feb 4, 2022 at 7:00 AM
    #205
    Bammer
    Monroe, CT
    Records matter to me. I buy new or CPO , preferably with service records from the selling dealer. I am not into others headaches !
  26. Feb 4, 2022 at 7:06 AM
    #206
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    I think records may make it sell more readily, but you're right. It's worth what it's worth.
    The average Joe is perfectly happy to buy a car, drive it a few years and trade it in. Maintaining it to the nth degree won't get him any better service out of it or make it worth any more at trade in as long as it's clean.
  27. Feb 4, 2022 at 7:08 AM
    #207
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Agreed.
    see, most folks don't think like responsible adults. Just look around Houston.
    nor have they learned to take care of shit.
    tiogajoe and Retired...finally like this.
  28. Feb 4, 2022 at 7:14 AM
    #208
    Retired...finally
    I get a charge when you like a post. Nobody in Texas likes your post.:rofl:
    hANNAbONE and Cpl_Punishment like this.
  29. Feb 4, 2022 at 7:21 AM
    #209
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    The only thing sheep care about is CarFax which has a huge disclaimer you must check before buying the report absolivng Carfax of all responsibility of missing or inaccurate information. CarFax gets their information from Police reports. I would guess 70% of accidents dont have Police reports. Its amazing how the sheep public has been programmed. If you buy a vehicle over $3.5K spend the $300 to have it inspected. They might miss a bad solenoid in the transmission but they wont miss aftermarket panels, paint work, frame damage. As far as maintenance records, the guy that pulls the little book out of the glove compartments with dates and services in different color ink over the years is golden. Half the time the dealer services your car somehting gets fked up......
  30. Feb 4, 2022 at 8:57 AM
    #210
    nobodyintexas
    nobodyintexas What?
    South of Houston
    that's awesome...I hadn't realized that.
