Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Mar 25, 2024 at 7:57 AM
    #601
    WiscoWalleye
    WiscoWalleye New Member
  2. Mar 25, 2024 at 8:53 AM
    #602
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    In the 2010’s the moly was higher on Toyota oil.
    WiscoWalleye[QUOTED] likes this.
  3. Mar 25, 2024 at 9:19 AM
    #603
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I kinda understand the moly love
    but changing oil at 5k renders all that blather mute
    I ran Kirkland 5w-30 for 5k and blackstone saw near zero wear metals.
    90k miles on truck
    tough to sell me on expensive oil.
    facts are hard to argue.
  4. Mar 25, 2024 at 9:33 AM
    #604
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    They switched to a different, more effective moly additive, it does not require as much content like old additive did. Pretty much all modern oils with moly have it around that number.
  5. Mar 25, 2024 at 10:38 AM
    #605
    WiscoWalleye
    When and what is it called? Because I talked to one of the blackstone chemists and he said without a doubt Toyota oils have the highest moly content of all the oils they test. The second being redline. And this conversation was a week ago.
  6. Mar 25, 2024 at 10:40 AM
    #606
    WiscoWalleye
    Id pretty much agree with this statement. Frequent changes are the best thing you can do.
  7. Mar 25, 2024 at 10:44 AM
    #607
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    One possible is trinuclear moly. Mobil or one of the additive companies found it more effective than regular moly, and not as much was required.
    vtl and WiscoWalleye[QUOTED] like this.
  8. Mar 25, 2024 at 10:55 AM
    #608
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In the beginning of 2010s. The new stuff is called "tri-nuclear organic moly".
  9. Mar 25, 2024 at 11:15 AM
    #609
    WiscoWalleye
    Hmm….I find that suspect if this oil tested in 2018 shows a drastic difference.
    http://pqiadata.org/Toyota_0W20.html
  10. Mar 25, 2024 at 11:16 AM
    #610
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Just because the chemistry is available, doesn't mean the oil blender for Toyota oil has to use it.
    Over the past few years, oil formulations have changed due to API moving from SN to SN Plus and now SP.
  11. Mar 25, 2024 at 11:19 AM
    #611
    WiscoWalleye
    Elaborate because that makes no sense if your saying the blender can blend the oil however they want if Toyota has a specific formula they require.
  12. Mar 25, 2024 at 11:24 AM
    #612
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    How about this:
    Just because the chemistry is available, doesn't mean that Toyota will specify its use. If Toyota leaves the additive chemistry specifics to the oil blender, the blender is not required to use a particular chemistry just because it is available.
    We don't know what parameters that Toyota requires for its bottled engine oil. It could be a very elaborate specification, or it may be driven by cost.
  13. Mar 25, 2024 at 11:53 AM
    #613
    WiscoWalleye
    Gotcha makes sense, but wouldn’t they want a uniform quantity for use in all vehicles for all additives. Just saying for example say they start having a problem with pre-ignition from the higher compression turbo engine's not liking some additives. Ford actually had this issue in the eco boost when it first came out and they changed the oil additives to address it because the low tension rings were letting enough oil by for the additives to actually make a difference in combustion. I’m just wondering if Toyota hasn’t done the same thing now that they have gone to mostly turbos in their new line ups. And the new formula is still good enough for the older vehicles or at least they will claim that. Just a thought. I have a sample at blackstone being tested but they are back logged 2 months I guess.
  14. Mar 25, 2024 at 12:26 PM
    #614
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    That's the idea with API SP rating. Its supposed to cover for the newer vehicles where pre-ignition is a concern, as well as all other engines.
    Don't get too caught up on what metallic additives are in an engine oil. There are many additive packages that have no metallic components, so those will not show up on a spectrographic analysis by Blackstone.
  15. Mar 25, 2024 at 12:31 PM
    #615
    WiscoWalleye
    That Makes sense. And I change it every 5,000 miles so as long as it’s any quality oil it’s fine. I’m just kinda miffed if I was buying that expensive Toyota oil thinking it has all this moly when it doesn’t. It would make sense though since I noticed my last oil change of Toyota oil the engine was louder. So I changed to 0w-30, They probably did change the formula.
  16. Mar 25, 2024 at 12:37 PM
    #616
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I don't disagree.
    Valvoline Extended Protection has higher than average moly content. I'm using the 5W-30 version in my 5.7 now. It runs pretty quiet.
    WILLINH and nobodyintexas like this.
  17. Mar 25, 2024 at 12:38 PM
    #617
    WiscoWalleye
    Awesome thanks!
  18. Apr 12, 2024 at 7:15 AM
    #618
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Ok, so which oil is better?
    :duel:
  19. Apr 12, 2024 at 7:50 AM
    #619
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    I will use Honda oil for my Honda ATV's and Yamaha oil for the Yammy jet ski's but for the trucks I use Castrol GTX or Kirkland 5-30 and always change around 4K, 5K max. I have never in my life bought Toyota motor oil. Filters yes but not oil.
    My old cars get different oil all together regarding zinc content.
    ATV25 and Leo's first like this.
  20. Apr 13, 2024 at 6:49 PM
    #620
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ok here's the Blackstone report on the Amsoil 0w-20 in my '15 Sequoia.
  21. Apr 14, 2024 at 1:21 AM
    #621
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Just going to remind everyone, that Blackstone’s ‘liability is limited to the cost of the analysis’)
    nobodyintexas likes this.
  22. Apr 14, 2024 at 4:55 AM
    #622
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Nothing better than fresh oil.
    :redxfall:
    Lifer and Leo's first like this.
  23. Apr 14, 2024 at 5:48 AM
    #623
    nobodyintexas
    nobodyintexas What?
    South of Houston
    at ~5k mile intervals....Amsoil & Kirklands look STAGGERINGLY similar.
    both brands have very very low wear metals.
  24. Apr 14, 2024 at 6:42 AM
    #624
    sd172
    sd172 New Member
    South Dakota
    Also going to remind everyone, that the ICP testing technique does not ‘see’ metal particles larger than 5 microns, that can also freely move through any oil filter (that captures particles of 25 microns or larger).
  25. Apr 14, 2024 at 6:44 AM
    #625
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Where do you get $14/qt?
    I pay $7.35/qt.
  26. Apr 14, 2024 at 6:49 AM
    #626
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    They look much bigger than 5 microns
  27. Apr 14, 2024 at 8:28 AM
    #627
    nobodyintexas
    nobodyintexas What?
    South of Houston
  28. Apr 14, 2024 at 8:29 AM
    #628
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I pay $38 for 10qts of kirklands
  29. Apr 14, 2024 at 8:33 AM
    #629
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Hella expensive for 4 quarts of oil. I started out using the signature series but switched after a few OCIs. Pennzoil ultra platinum 5w-30, 3pk of 5q right from Amazon.
    Edit- that said, I do like other amsoil products for other things so I still have a membership.
  30. Apr 14, 2024 at 8:36 AM
    #630
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I used PUP and no complaints
    presently trying valvoline hi mile/ advanced
    It’s hard to find PUP on the shelf in south houston
