Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Jul 29, 2023 at 5:38 PM
    #541
    Abrown3912
    Abrown3912 New Member
    2021 Crewmax
  2. Jul 29, 2023 at 6:08 PM
    #542
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
  3. Jul 29, 2023 at 6:23 PM
    #543
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    kirkland oil only $40 for 10qt
    nobodyintexas and Abrown3912 like this.
  4. Jul 29, 2023 at 7:43 PM
    #544
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Wish I had a cosco near me.
  5. Jul 29, 2023 at 7:53 PM
    #545
    OHwendTrd
    Josh
    21 SR5 3UR-FE
  6. Jul 30, 2023 at 8:16 PM
    #546
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    OHwendTrd[QUOTED] likes this.
  7. Jul 30, 2023 at 8:28 PM
    #547
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
  8. Jul 30, 2023 at 8:53 PM
    #548
    Chip_Tundra
    Chip_Tundra New Member
    Well if anyone is an amsoil loyalist, I can get you 25% off. Lol
  9. Jul 30, 2023 at 8:59 PM
    #549
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    $24 per 5 quarts. Great price, the ultra platinum has been reviewed to be slightly below/comparable to Amsoil signature.
    Great oil. Still have an account for the discount and garage for digital maintenance records. I used to order it religiously but too expensive when I change it on 5k intervals so no personal benefit or gain for the cost. I prefer clean oil that's changed often (6mo/5k).
  10. Jul 30, 2023 at 9:04 PM
    #550
    OHwendTrd
    Josh
    21 SR5 3UR-FE
  11. Jul 30, 2023 at 9:09 PM
    #551
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I don't think it matter much when changing @5k interval
  12. Jul 31, 2023 at 5:17 AM
    #552
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I would not leave in for 15 years…lol
  13. Jul 31, 2023 at 6:22 AM
    #553
    Retired...finally
    I've decided to switch to 5w-30 on my 21. It seldom sees temps below freezing but it does tow a travel trailer a 1,000 miles each fall and spring. Roughly 20% of the time I'm pulling about 3 tons so the 5K OCI works best for me. Each summer I'll do the ATF drain and fill, change the motor oil, air filter and side to side tire rotation. Once in my winter stomping grounds I'll supply the oil, filter, crush washer and filter wrench and have a private shop do the OC and front/back tire swap. I found a good shop in Gulf Shores that will let me do my semi-annual under body inspection while on their rack. The mechanic will be tipped, of course.
    Mike59 and RichterScale like this.
  14. Jul 31, 2023 at 7:28 AM
    #554
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    C'mon gang, with all that money saved, forget a toy filter. Grab a real filter.:rofl:
    Cpl_Punishment and Leo's first like this.
  15. Jul 31, 2023 at 7:47 AM
    #555
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    If you need a real filter, your engine is probably toast. Toy filter should suffice.
  16. Jul 31, 2023 at 10:30 AM
    #556
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Buy it from their website.
    "You can shop on Costco.com without a membership.
    Costco.com is also available to non-members, but you will be assessed a 5% surcharge on your order. Also, there are some items that are only available to members, so non-members can't access everything that's available."
    5% surcharge still puts the 10gal of Kirkland oil well below the alternative options, and it's high quality synthetic oil.
  17. Mar 12, 2024 at 2:07 PM
    #557
    JohnWhicker
    JohnWhicker New Member
    GOD what a read, I am exhausted :)
  18. Mar 12, 2024 at 2:09 PM
    #558
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    And
    it’s not over
  19. Mar 12, 2024 at 2:10 PM
    #559
    JohnWhicker
    LOL I am over, I don't even drink but I think i will have one after this read :)
  20. Mar 12, 2024 at 2:13 PM
    #560
    nobodyintexas
    nobodyintexas What?
    South of Houston
    i rest well knowing my 2 tests proved 5w-30 protects my engine better than 20w
    all the rest is opinion babble
    shamrock246, mgrs, ATV25 and 2 others like this.
  21. Mar 12, 2024 at 2:17 PM
    #561
    JohnWhicker
    Thanks for the hard work and test Sir. I don't mind going with 5w-30 if it does not void the warranty from Toyota?
  22. Mar 12, 2024 at 4:02 PM
    #562
    sd172
    sd172 New Member
    South Dakota
    The next logical step would be switching to straight grade SAE30 or SAE40. Less additives, cleaner engines!
    nobodyintexas[QUOTED] likes this.
  23. Mar 12, 2024 at 7:05 PM
    #563
    Retroboy1989
    Northern Utah
    I went to 0w30 on both my toyotas that call for 0w20. Same startup characteristics, no measurable change in fuel economy.
    Done looking back.
    Bammer and Cpl_Punishment like this.
  24. Mar 12, 2024 at 7:10 PM
    #564
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My 2010 oil cap says 5-20 or 0w-20. If you dont want to go to 30w. Try 5-20, it is a much quieter idle than 0-20
  25. Mar 12, 2024 at 7:27 PM
    #565
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I just started here on page 20. What did I miss?? :rofl:
    Terndrerrr likes this.
  26. Mar 12, 2024 at 9:08 PM
    #566
    Actual testing procedure:
    Send sample into Blackstone.
  27. Mar 13, 2024 at 3:40 AM
    #567
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    As did I, 0w30 and done.
  28. Mar 14, 2024 at 9:06 PM
    #568
    ZPhilip
    Philip
    West Chester, PA
    Which 0w30 are you guys running?
  29. Mar 15, 2024 at 10:00 AM
    #569
    Retroboy1989
    Northern Utah
    I usually watch for mobile 1 to go on sale.
  30. Mar 18, 2024 at 3:29 AM
    #570
    Bammer
    Monroe, CT
    Mobil 1
    WILLINH likes this.
