Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Aug 31, 2022 at 6:06 PM
    #301
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Biggest issue it causes is oil consumption.
  2. Sep 1, 2022 at 3:32 AM
    #302
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Statistically...which of these grades of oil lead to oil-related engine failure?
    is there a bell curve available to ponder?
    hagrid likes this.
  3. Sep 1, 2022 at 4:19 AM
    #303
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^. NEVER NEVER NEVER forget this ^^^.
    5W30 Costco Kirkland for me.
  4. Sep 1, 2022 at 4:23 AM
    #304
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    My wife’s 19’ Rav4 uses 0w16 and sounds like it has marbles in it sometimes when she pulls it into the garage. I’ve been having the dealer do the free oil changes but I think those are used up now. Curious if switching to 0w20 may be a better move even for the Rav.
  5. Sep 1, 2022 at 4:39 AM
    #305
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I may make the switch to something different. Is there anything to be concerned about as far as engine tolerance etc?
  6. Sep 1, 2022 at 4:42 AM
    #306
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not if you read the Toyota owners manual.
    it says it in plain English...run what you want.
    listen up....engines don't fail (due to oil) if you keep the proper level of oil in them.....EVER.
    Go to Costco...get a bunch 0w20 or 5w-30. you will save $ and sleep well.
  7. Sep 1, 2022 at 4:46 AM
    #307
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll swat the hornet's nest again....
    I used Costco 0w20 to dyno my S/C 2020.
    then I sent a sample to blackstone.
    The costco oil was unfazed by the ~5000miles & ~18 dyno pulls.
    That is not anecdotal.
    yes, I change every 5k - you should too.
    and I use Toyota filters.
    NWPirate and Terndrerrr like this.
  8. Sep 1, 2022 at 4:52 AM
    #308
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yeah, yeah...it needs more Moly...
    look at that TBN...:D
    the point...use whatever oil you want...even Costco 0w-20 kicks ass.
    just keep it filled properly.
    Cpl_Punishment likes this.
  9. Sep 1, 2022 at 5:48 AM
    #309
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    nobodyintexas likes this.
  10. Sep 1, 2022 at 5:51 AM
    #310
    nobodyintexas
    nobodyintexas What?
    South of Houston
    what brand?
  11. Sep 1, 2022 at 5:52 AM
    #311
    Sumo91
    TN
    High Performance Lubricants HDEO for the most recent UOA
    Schaeffers for the previous OCIs
  12. Sep 1, 2022 at 5:53 AM
    #312
    nobodyintexas
    nobodyintexas What?
    South of Houston
    pardon my ignorance ... is that around $10/Qt?
    Sumo91[QUOTED] likes this.
  13. Sep 1, 2022 at 6:09 AM
    #313
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What happens if the molybdenum coating on the piston skirts starts coming off? Can the analyzer distinguish between oil molybdenum and skirt molybdenum?
    Hbjeff, Oey12 and nobodyintexas like this.
  14. Sep 1, 2022 at 6:15 AM
    #314
    Sumo91
    TN
    I'd have to look. I buy in bulk. I went to HPLs open house that they hosted recently to check out their blending facility and got to talk to some of the leaders in the oil industry, and they had 25% off their oils if you signed up and went to it. I believe it was around $7.50/qt with the discount, so $10/qt. And I'll be running this for around 20k/OCI, so it comes out really cheap per mile, plus all the benefits of running their oil (esters/ANs)
    If you want to extend your drain intervals, or just want to run an amazing oil, I highly recommend it. If you like 5k OCIs, then keep running whatever you're running.
    nobodyintexas[QUOTED] likes this.
  15. Sep 1, 2022 at 6:21 AM
    #315
    nobodyintexas
    nobodyintexas What?
    South of Houston
    things will now get out of hand...talking about looking up people's skirts.
  16. Sep 1, 2022 at 6:44 AM
    #316
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    "How do you make people wanna get off a nuclear submarine?"
    Those were the good days before blank cartridges looked identical to live rounds.
    Wait...
  17. Sep 1, 2022 at 8:44 AM
    #317
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    These same engine manufacturers recommended 5w oil for those exact same cold starts just 15 years ago. What changed?
    AZBoatHauler likes this.
  18. Sep 1, 2022 at 8:54 AM
    #318
    nobodyintexas
    nobodyintexas What?
    South of Houston
    the recommendation.
    the motor sure didn't.
    AZBoatHauler and Hbjeff[QUOTED] like this.
  19. Sep 1, 2022 at 9:13 AM
    #319
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    exactly. The 4.7 didn’t call for 0w-20. I don’t think anyone would call that a “looser tolerance” engine. 0w-20 is bullshit if you live below the frost line
  20. Sep 1, 2022 at 9:34 AM
    #320
    John W
    John W New Member
    I totally agree that the move to 0w20 is entirely CAFE driven. But I have frequently read that much of the wear a vehicle gets is in the period before your oil gets to 212 degrees. It seems like the 0w oils would be an improvement in any environment. What is the downside of a thin oil at startup?
    my commute is a few miles & 10 minutes. My oil doesn’t get to temp on my daily commute. For my use, I’m still thinking 0w30 would be better than 5w anything. Am I off base?
    Cpl_Punishment and Bammer like this.
  21. Sep 1, 2022 at 9:39 AM
    #321
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If we went back in history far enough, ie my dad, one would find arguments that 5w oil was too thin and 10w was better.
  22. Sep 1, 2022 at 9:48 AM
    #322
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So you thinking of blending the two?
  23. Sep 1, 2022 at 9:57 AM
    #323
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Use the 0W30 without hesitation.
  24. Sep 1, 2022 at 11:30 AM
    #324
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    im running 6 qts of 5w-20 and 2 qt 5w-30 this change because thats what i had in the garage. I run 5w-30 plenty of times too.
    my wife’s honda has 5w-20 right now. Sounds light years better than it did on 0w-20.
  25. Sep 1, 2022 at 11:42 AM
    #325
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Blackstone Labs loved my 10,000 mile Mobil 1 0W20 so much they kept asking me to go 13,000 miles. So I chose to...........stop sending them oil samples. :D:D:D
    sd172, Sumo91, nobodyintexas and 3 others like this.
  26. Sep 1, 2022 at 4:25 PM
    #326
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Did the oil sample you sent to Blackstone come from the piston groves that support the oil ring? Did you disassemble the engine to get the sample? Thats were the oil gets carbonized which causes the oil ring to get stuck and not conform to the cylinder wall causing scuffing and excessive oil consumption. change your oil every 5-7K miles.
  27. Sep 1, 2022 at 5:31 PM
    #327
    Sumo91
    TN
    If your oil has the correct Chemistry and detergents, you don't have to worry about carbon build up or stuck rings, some oils even free carbonized rings and remove build up. 5-7k is a waste of money.
  28. Sep 1, 2022 at 5:39 PM
    #328
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Watch this video on YouTube.
    TOYOTA OWNERS! Please NEVER Do THIS to Your Toyota!
    Oil change waste of money? Mortgage interest is a waste of money, credit card interest is a waste of money, no shopping home owner insurance every year is a waste of money......... Oil change cost is pennies, nothing, not even accounting error. don't be penny wise dollar fool.
  29. Sep 1, 2022 at 6:04 PM
    #329
    Sumo91
    TN
    This video was actually brought up at the open house, and it was absolutely obliterated. Don't trust some random youtube mechanic, but if you want to, then by all means, do so. I'll trust the people who have put their life into making great oils, who have literally written the books and developed today's oil as we know it.
  30. Sep 1, 2022 at 6:05 PM
    #330
    Joe333x
    Joe333x Member
    Boston
    Guessing you meant to post this?
    https://youtu.be/TJhFAwFv-O0
    MEWaters likes this.
