Switching to 5w30?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Klowry97, Mar 23, 2020.
  1. Jun 13, 2022 at 12:24 PM
    #271
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    SnrDisregardo likes this.
  2. Jun 13, 2022 at 12:31 PM
    #272
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Anything Dino-based or semi-synthetic (colder climates), and change it at 3000 miles. It has worked for generations and always will.
    I like Super Tech - $24 for 8 quarts is hard to beat.
    WILLINH likes this.
  3. Jun 13, 2022 at 12:42 PM
    #273
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Not 100% scientific and it’s not all 1 brand, but this is kind of a cool test showing flow at room temp and -11 Degrees Fahrenheit with 0w20,5w20 and 10w30. May as well skip ahead to around 9 minutes where the test starts with room temp oil. https://m.youtube.com/watch?v=sZJnKfw3WQA
  4. Jun 13, 2022 at 12:53 PM
    #274
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    I've read somewhere that if you go with more aggressive solvents(?stuff that dissolves?), it has an adverse side effect where your gaskets get eaten away quicker. It was some credible no name Joe.
    Either way, Joe praised mobil1 since it has perfect balance of solvents(?stuff that dissolves?).
  5. Jun 13, 2022 at 12:53 PM
    #275
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Please explain the "...does not provide enough dissolving power to keep polymer vm in solution at engine operating temp" a little better. I'm curious about this.
    My last two vehicles that were sold with over 200k miles each used Mobil 1 at 5k to 7.5k mile intervals. The valvetrain was very clean on both when sold.
  6. Jun 13, 2022 at 2:47 PM
    #276
    sd172
    sd172 New Member
    South Dakota
    This is an interesting article on this topic:
    https://www.stle.org/files/TLTArchives/2013/12_December/Feature.aspx
    Mobil 1 had their hand slapped when they tried to use a synthetic formulation in aircraft piston engines: oil additives precipitated under normal loads and sludged up expensive engines.
    It is really a hit or miss situation if your synthetic oil is thermally stable and doesn’t drop additives. You might have been lucky.
    Retired...finally likes this.
  7. Jun 13, 2022 at 8:41 PM
    #277
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My dad has 2 interesting toyota engine experiences.
    05 gx470, he changed the oil maybe 3 times in 90k miles, engine was totally shot, heavy knocking could barely idle.
    02 landcruiser with 4.7, 2 oil changes in 120k miles, then sat for 2 years. Fired up with new battery and ran perfect
    toyota builds tough engines, we overthink it by a mile. Who cares what brand oil you use, if you change it in reasonable intervals you are probably in the top 20% of all auto owners.
    Alex38 and Oey12 like this.
  8. Jun 13, 2022 at 9:46 PM
    #278
    AZBoatHauler
    So.Arizona
    :monocle:
  9. Jun 14, 2022 at 3:36 AM
    #279
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    As I have stated in the past, a friends Jeep 4.0L went 188,000 miles without an oil change.
  10. Jun 14, 2022 at 4:12 AM
    #280
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    in regards to cleaning...
    I ran Castrol whatever in my old Acura integra.
    My dipstick had all kinds of varnish on it. (stay on topic)
    When I started using M1 - it cleaned the varnish off off my dipstick on the 1st change.
    Kirkland 0w20 keeps my dipstick clean as well.
    if you have varnish on your dipstick, you are doing it wrong.
    it is important to use quality lube.
    I love oil threads.
  11. Jun 14, 2022 at 4:44 AM
    #281
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    A buddies FIL used too do his oil changes by just adding when it got low. After 4 quarts he’d change the filter and add what oil that was required. Never lost a motor. Never had any motor wear issues. Used whatever oil that was on sale.
    WAtundra4x4 likes this.
  12. Jun 14, 2022 at 4:50 AM
    #282
    sd172
    sd172 New Member
    South Dakota
    Those would be my ‘winter’ oil picks for colder climates.
    91CF48A9-1D66-4648-95A8-C44D9833FB43.jpg AC7BB0F8-9BE2-4A49-B88D-D29515CF6051.jpg
  13. Jun 14, 2022 at 4:54 AM
    #283
    nobodyintexas
    nobodyintexas What?
    South of Houston
    what is this "winter" y'all speak of?
    I might want to go see it.
  14. Jun 14, 2022 at 4:55 AM
    #284
    sd172
    sd172 New Member
    South Dakota
  15. Jun 14, 2022 at 6:00 AM
    #285
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Seems accurate.
  16. Jun 14, 2022 at 4:24 PM
    #286
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    My brother took good care of his house and remodeling, but he considered all the new electrical gizmos like windows and sun roofs junk. He added oil when the add oil light came on. I used to “store” his old Tercel when he worked in NY on broadway. I changed the oil once for him after he was gone for awhile, I swear lumps of rust came out. It ran perfectly. He only got 13:years on his original battery tho.
  17. Aug 31, 2022 at 6:10 AM
    #287
    John W
    John W New Member
    Considering switching to 0w30 for the 5.7 in my 2016 Land Cruiser. To date I’ve had 5k changes with Toyota 0w20 synthetic at the dealer (cheap oil change coupons). 63,000 miles. Any brand recommendations for 0w30?
    My use case: in Florida so no cold weather. Lots of short trips where oil doesn’t get to temp, so thinking I should stay with a 0W oil. But also periodic towing of a 4500lb boat, thinking 30 would offer more protection. Plan to keep the truck forever. Appreciate any advice.
    FYI the factory fill on Land Cruiser 5.7’s is 5w30 synthetic in the mideast, Australia and Russia, where they sell many more LC’s than the US. It reinforces the idea that 0w20 is for CAFE, not vehicle protection.
    CaptRussia253 likes this.
  18. Aug 31, 2022 at 6:19 AM
    #288
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    30 grade oil is fine.
    In Florida, there will be no difference in 0W or 5W winter rating. The difference is at temps well below freezing.
    I would use 5W-30 or 10W-30.
    AZBoatHauler likes this.
  19. Aug 31, 2022 at 6:20 AM
    #289
    Bammer
    Monroe, CT
    I like Mobil 1 in the 0W30 flavor.
  20. Aug 31, 2022 at 6:38 AM
    #290
    sd172
    sd172 New Member
    South Dakota
    Here’s all protection you can have, dirt cheap. I would change it every 3000 miles considering short trips.
    Good enough for South Dakota.
    Joe333x likes this.
  21. Aug 31, 2022 at 10:50 AM
    #291
    737fixer
    737fixer New Member
    Well,ggl9000xpic1_12.jpg you guys convinced me. Listening to actual engineers is absurd and the quieter the engine must prove its better. I've starting running this and in one hour my engine is the quietest it's ever been. Literally it's like it is off. Dead silent. Must be better.
    hagrid, Bammer and Cpl_Punishment like this.
  22. Aug 31, 2022 at 11:03 AM
    #292
    Bammer
    Monroe, CT
    Try the 75W140, talk about quiet !
    crewmaxlmt likes this.
  23. Aug 31, 2022 at 11:06 AM
    #293
    AZBoatHauler
    So.Arizona
    Did you miss this fact? It indicates the engineers prefer an oil heavier than 0-20.
    Terndrerrr likes this.
  24. Aug 31, 2022 at 11:07 AM
    #294
    AZBoatHauler
    So.Arizona
    I run 5-30 in both my Land Cruiser and Tundra.
  25. Aug 31, 2022 at 12:08 PM
    #295
    John W
    John W New Member
    Is there a reason, besides price, not to go with 0w30 instead of 5w30? I know 5w30 will work fine, but so will 0w20 as evidenced by lots of high mileage Tundra’s. I’ve seen comparisons of flow at room temperature and the 5w oils are thin, but not as thin as 0w oils. This may not make a real world difference, but I’m wondering why 0w30 isn’t more common. Thoughts?
  26. Aug 31, 2022 at 12:14 PM
    #296
    AZBoatHauler
    So.Arizona
    My thought is 5w should stick around better in the top end at the higher temperatures I see offering better startup protection than 0 weight in the valve train - this is speaking more to oil dissipation after shutdown than flow upon starting…
    nobodyintexas likes this.
  27. Aug 31, 2022 at 12:24 PM
    #297
    Bammer
    Monroe, CT
    Lots of people are afraid of the 0W oils, but the 0 weight is only at cold startup, once hot, it acts like a 30 weight. On BITOG many years ago there was a thin/thick battle that raged on and on, learned alot from a guy there AEHAS was his screen name. Highis end luxury cars, was very passionate about oil. Of course the naysayers badgered him until he just quit. There is a TON to know about oil, and we just scratch the surface.
  28. Aug 31, 2022 at 1:22 PM
    #298
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    If I am understanding correctly from reading some knowledgeable oil guys posts, 0W-20 & 5W-20 will actually coat and stick to the cylinder walls better during high heat than 5W-30?
  29. Aug 31, 2022 at 2:28 PM
    #299
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    You can run up to 20w50 if your climate dictates it.
  30. Aug 31, 2022 at 4:43 PM
    #300
    Joe333x
    Joe333x Member
    Boston
    Thats exactly the reason, 0w20 is a product of the EPA.
