Sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Levinger79, Nov 27, 2019.
  1. Nov 27, 2019 at 2:24 PM
    Levinger79
    Levinger79 [OP] New Member
    Knoxville TN
    2016 White Tundra Platinum
    So I removed my front sway bar 2016 Crewmax Platinum to have powder coated white to match my rig. This was on the truck when I purchased it. Question is, whats the difference between this sway bar and the red TRD one... Besides the color?
  2. Nov 27, 2019 at 2:37 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    The TRD one is solid and much heavier than the hollow one currently on your truck.
    TheBeast and Levinger79[OP] like this.
  3. Nov 27, 2019 at 3:00 PM
    Levinger79
    Knoxville TN
    Is there really a noticeable difference in handling by upgrading to the TRD front from this bar?...or would I just be better off adding a TRD rear (nothing there now) and calling it a day.
  4. Nov 27, 2019 at 3:04 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The rear is amazing and IMHO a must have. I have the TRD front sitting in my garage waiting for my staycation starting 12/13 to install my 6112's, TRD Sway & sway bushings (don't come with the sway buy a set) & new end links.
    I'll be able to report on the difference sometime around 12/15 or so.
    Levinger79[OP] likes this.
  5. Nov 27, 2019 at 3:14 PM
    TheBeast The Beach
    TRD one is heavier and has rounded ears
  6. Nov 27, 2019 at 3:43 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    The rear sway is worth it, Get It.
    Rex Kramer and Levinger79[OP] like this.
  7. Nov 27, 2019 at 3:50 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    I also upgraded to the Trd front sway, I can’t remember exactly but the Trd is heavier and I can only imagine translates to being a touch stiffer too. To me it didn’t seem too much of a difference but I did notice it felt tighter and more controlled in the turns also swear it just felt more solid cruising on the freeway. I say go for it! It’s only money :spending:
  8. Nov 27, 2019 at 4:05 PM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    I have front and rear and love both because I turn corners like a mad man and it gives less body roll
  9. Nov 27, 2019 at 7:57 PM
    Levinger79
    Knoxville TN
    I took off the front sway today to powder coat, drove probably 20-30 miles on some city roads and winding backroads, I think I like the ride better with it gone. Definitely not buying the front TRD for a few extra pounds and a cunt hair more rigidity. Lol. I'll find better mods to waste my money on.
  10. Dec 1, 2019 at 6:59 AM
    Toyota_loyal
    Toyota_loyal Platinum Pro build in progress
    deb
    Denver, CO
    2020 Platinum CM
    I found a difference in the handling. It wasn't as dramatic as the rear, which was installed weeks after the front, but it was noticeable and an improvement, IMO
  11. Dec 1, 2019 at 9:40 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    u tube the front trd bar. They say it’s great upgrade, especially when paired with the rear.
  12. Dec 1, 2019 at 1:40 PM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    The TRD Front sway bar weighs 29 lbs compared to 17 lbs for the normal one.
    Wondering though why if you purchase one it is TRD Red and the stock one on my 2020 PRO is black...anyone know why ?
  13. Dec 1, 2019 at 1:45 PM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    https://www.tundras.com/threads/say-yes-to-the-trd-sway-bar.55587/
