Suspension Stacking
Discussion in 'Suspension' started by Jared378, Feb 8, 2019.
  1. Feb 10, 2019 at 6:44 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    It may be a matter of wording. When you say ‘frame’ I think of the long solid piece of steel that runs the full length of the truck. There are bits and pieces welded to that frame that stick out, and we call those body mounts.
    I haven’t seen a tundra rub on the frame, but many of us rub on the body mount. Here’s a pic of where ours used to rub before we cut it out and put in a new plate. Cutting the body mount is a very common practice.
    2FA95977-B6A6-46A2-894D-561D54578E1E.jpg 0549CE02-649A-4F8C-8B79-B242B1833426.jpg
    Markman likes this.
  2. Feb 10, 2019 at 6:46 AM
    KevinK
    Tundras to Sedona
    Yeah, you’re rubbing on the body mount. Some people call it a cab mount.
    You just need to cut that out and put a plate in. Or use a smaller spacer on your wheels. How close is your tire actually to the UCA? What offset are your rims?
    Berdine likes this.
  3. Feb 10, 2019 at 6:57 AM
    Jared378
    Jared378 [OP] New Member
    Jared
    No offset on my rims. They came with the TSS package. I don’t think there’s a reliable, hub centric wheel spacer smaller than 1.25” unless I want to compromise off road capability.
  4. Feb 10, 2019 at 7:02 AM
    KevinK
    Tundras to Sedona
    I’m not super familiar with wheel spacers since we don’t use them, so I can’t speak for a quality one. If you’ve been running these for a while, it may be worth a new look at what’s available and try to find a 1”. It oooks like you have plenty of room for a slight reduction in spacer.
    Or
    Get an adjustable upper control arm like the icon billet. But that’s not cheap.
    Your most economical option is the body mount chop. You can buy the plates and take them to a local fab shop for cut and weld. Less than $400 all in as far as I know and the problem disappears. I’ve never had dealership take issue with a body mount chop.
    040Tundra likes this.
  5. Feb 10, 2019 at 7:15 AM
    Jared378
    Jared
    No reliable 1” wheel spacer. It wouldn’t be worth it to drop $300-400 for a mount chop. Adjustable control arm might work however. I am pretty confident increasing the lift of the vehicle by 1” will solve my issue though. Question is how to get there. Adding shims to the leveling spacer, using my height adjustable shock + coachbuilding shims (tossing the leveling spacer), or working in some sort of preload spacer in conjunction with either my current leveling spacer / height adjustable shock.
  6. Feb 10, 2019 at 8:27 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    You're getting really good advice from everyone here but you seem pretty set on doing the opposite of what everyone says. You want 1 more inch if lift by stacking lifts. Don't say we didn't warn you when you have some kinda of catastrophic failure.
  7. Feb 10, 2019 at 12:05 PM
    KevinK
    Tundras to Sedona
    Here’s the short version. If you’re already at 3+ inches of lift and want more, you need to invest in a bracket lift. There is no way around that. Mechanical breakage will occur if you lift your truck more than it is right now.
    If you want to clear the tires and stop rubbing, you need to either switch wheel spacers or chop the mount or get adjustable uppers. There is no way around that. (Different rims with the correct offset will fix your issue, but is not cheap so I’m not offering it as a solution to your specific situation). Adjustable uppers also aren’t cheap.
    FWIW, we run 37s with no rub at all on a 2” lift. And we offroad hard. Jumps and boulder fields are regular for us. It’s also my wife’s daily driver, so it has to be reliable.
    Here’s an old picture before she got glass fenders and 0 offset beadlocks. These tires were 37x13.5 and didn’t rub.
  8. Feb 10, 2019 at 12:18 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I always like when @Coachbuilder puts his 2 cents in. He makes a great argument and most likely the most sense. :popcorn:
    Coachbuilder1 and KevinK like this.
  9. Feb 10, 2019 at 5:30 PM
    Jared378
    Jared
    Yeah, I’m being stubborn since stacking with Ford is relatively easy and safe in some cases. I’ll probably just end up buying the 4.5” lift kit from RoughCountry. I think that’s the most economical solution. I’m getting minimal rub currently which I can deal with. Getting a lift is just as important as being able to clear the tire so I might as well knock out both at once. Thanks gentlemen.
    I like her truck! Do you have a Tundra? If so send pics
    KevinK[QUOTED] likes this.
  10. Feb 10, 2019 at 7:24 PM
    KevinK
    Tundras to Sedona
    I typically try to steer people away from bracket lifts if they offroad as it appears you do. But if you’re trying to get the beefy look and some off road capability, it’s probably the right thing for you. We were strictly after off road performance, so we kept it as low as possible.
    I drive an FRS. Haha! The Tundra is my wife’s. Everything we’ve done to it has ultimately been up to her.
    Here’s a couple current pics.
    61A24F97-E114-488E-AF38-31EF455C0FB1.jpg 28996641-3D49-45D1-A97B-1C3A96165221.jpg
    zcarpenter92 likes this.
  11. Feb 10, 2019 at 7:35 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Kevink, your wife’s truck looks amazing with those 37’s
    KevinK likes this.
  12. Feb 12, 2019 at 8:44 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for the call.. Yes, you can either add 2 shims on the driver and 1 on the passenger side to correct the driver side lean or use 2 on each side for 1" of additional lift. we need to be sure we are still fully cycling the assembly and with just .50" of shim we will achieve this.
    KevinK likes this.
  13. Feb 12, 2019 at 11:23 AM
    Coachbuilder1
    David
    Salt Lake City UT
    Wheel spacers are def not all created equal, We've used a few select brands over the years and offer Bora on our site for the Tundras https://shop-coachbuilder.myshopify.com/products/bora-wheel-spacer-1-25-tundra-2007-sold-in-a-pair
    Anything thinner then 1.25" will require cutting the end of the lug studs off.
    KevinK likes this.
