Sub enclosure dimensions
Discussion in 'Audio & Video' started by bsktball55, Mar 15, 2017.
  1. Mar 15, 2017 at 6:06 AM
    bsktball55
    bsktball55 [OP] New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Can anyone that has either built a sub box or has a sub box that works in a 2014+ crewmax please give me the dimensions that you used? Just need bottom width, top width, and height. I'm trying to determine if a certain box will fit, but can't find the dimensions of the back seat area.
    OPSteel and Maddsilence like this.
  2. Mar 15, 2017 at 6:52 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    If I remember correctly...4" top width, 7" bottom width, 12" height
    I just tried to measure it...really tough to do with it in the truck, but from what I could measure, those numbers are really close.
  3. Mar 15, 2017 at 7:23 AM
    Hannabl
    Hannabl New Member
    Apollo Beach FL
    2015 Toyota Tundra XSPX CrewMax
    Optima yellow top, K&N complete cold air intake, ANZO USA full light package(headlights,tail lights, 3rd brake light, Light bar) Gibson full stainles cat back exhaust, Bak flip G4 bed cover, Taco tunes 12" sub box w/kicker sub and Mono block D Soundstream amp, Lumar 15% window tint, PowerStop Big brake upgrade all four corners, ..... Very soon 3/1 Toytec Boss lift
    I ordered mine from Taco Tunes for my 15 crewmax. I believe they have all the dimensions on line.
  4. Mar 15, 2017 at 7:35 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Thanks, I'm trying to figure out if this box will work. http://www.jlaudio.com/cs110tg-tw3-car-audio-powerwedge-subwoofer-systems-93302
    It's 4.1 inches at the top, 12.4 inches high and 6.25 inches at the bottom. I've heard the 12 inch box just barely doesn't fit, but this one is listed as being smaller on their website, while some people are claiming they are the same size. I may take the seat out this weekend so I can actually measure the space back there. Like you said, it's really hard to get accurate measurements with the seats in.
  5. Mar 15, 2017 at 7:38 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  6. Mar 15, 2017 at 7:52 AM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I was mistaken a little...I ordered mine online from here http://www.audioenhancers.com/vehiclespecific/tuncm110.php Looks like the dimensions are 3.5" top, 6.5" bottom, and 12" tall
  7. Mar 15, 2017 at 10:49 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Thanks I'm wanting to go with just one sub right now so I don't use up the entire behind the seat area because I don't want to have to move my jack and I also throw some stuff back behind there too. Do you think there is room for an extra half inch up at the top, or is it already snug up there?
  8. Mar 15, 2017 at 12:17 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    there's room for another 1/2 on top and bottom for the box itself...what I can't answer though is there enough room for the sub to clear the seatback with a box another 1/2" bigger. My gut and from what I can feel with my hand says yes, but I don't want to be responsible for your $400 gamble :anonymous: .
  9. Mar 15, 2017 at 2:32 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Glad you mentioned that. I didn't even think about the actual sub clearing the seat back. One person mentioned that the 12 in sub almost fit, but it was hitting at the top, but the 12 in is taller and wider. I believe my local shop has some in stock that I will probably go see if I can test fit it before buying it. I was going to try and save a little bit buying it online, but it's not worth the gamble if I'm not sure if it will fit.
  10. Mar 15, 2017 at 2:40 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I want a smaller box that only takes up half of the back. I keep stuff back behind my seats and don't want to use up the entire thing. I've only seen a couple that are like that such as Tech12volts which I have heard good and bad things about him. The box alone from him is $130 and takes 6-8 weeks to get. This box has the sub I want which is a $300 sub plus the box would be $430. This box with sub is $360 so I would save some money and this box is designed specifically for this sub.
  11. Mar 15, 2017 at 3:11 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    that's what I have...two of them. I love these subs
    GNTundra likes this.
  12. Mar 15, 2017 at 3:19 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Was looking at the 10in tw3. From what I've read, the 10 in would probably be better sounding for the type music I listen to.
  13. Mar 16, 2017 at 8:19 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Little overkill???? :)
  14. Mar 16, 2017 at 12:14 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Glad you guys are happy with the subs, I've read some good reviews on them, but it's always good to hear from others.
  15. Mar 20, 2017 at 5:24 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I will be adding this underneath the seat..is 1 inch gap enough? Fosgate 12inch p3?
  16. Mar 21, 2017 at 8:44 AM
    xj2202009
    x
    Lutz, Fl
    @GNTundra. Thank you very much I been looking for one of those..
  17. Apr 19, 2017 at 7:44 AM
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    OP, did that TW3 end up fitting? I am looking at the same 10" JL Audio TW3 sub but the Lg model (which is a little thinner on the bottom) for my 2017 Crewmax. Not sure yet if it will fit. If nit Crutchfield said they will give me a full refund including shipping.
  18. Apr 19, 2017 at 7:47 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I was told by someone on Tundra Crew on Facebook that they fit the 10 inch on in their truck. I ended up going with a box may by Tech12volts. He is making me a box with the 10tw3 sub in it for less than what that one cost.
  19. Apr 19, 2017 at 8:42 AM
    OPSteel
    OPSteel New Member
    Thanks...if mine doesn't fit, I may contact your guy to help me too.
  20. Apr 19, 2017 at 8:55 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I have (2) 10 in tw3s in a box under the seat. Takes up every but of room under the seat but sounds tremendous. I had to figure out another storage solution for all my stuff that used to live there
  21. May 15, 2017 at 9:35 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    BLONGTX likes this.
  22. Sep 6, 2018 at 9:29 PM
    Kerbey7011
    Kerbey7011 New Member
    Michael
    2015 Black TSS Off-road Tundra
    OP, did yours fit? Thanks
  23. Sep 7, 2018 at 4:38 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Check with tech12volts. He got me a 10tw3 sub with a box for about $50 cheaper then that one is.
  24. Sep 7, 2018 at 6:54 AM
    Kerbey7011
    Michael
    Okay I will do that. There are a lot of options on crutchfield and Best Buy that may have the right dimensions but I guess it’s better safe than sorry!
    Thanks bsktball
  25. Sep 7, 2018 at 11:00 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I'm not sure what his prices are like now, but when I got mine last year, he gave me the box and sub for about $20 more than I could get the sub for on any other site. I got my amp and speakers through him as well so he may have given me a better deal, but it is worth checking. He specializes in Tundras.
