Steering wobble
Discussion in '1st Gen Tundras (2000-2006)' started by kigzy, Jan 22, 2023.
  1. Jan 22, 2023 at 12:06 PM
    kigzy
    kigzy [OP] New Member
    Delaware
    2003 SR5 Access Cab v8 4WD
    So yesterday I bought my first tundra 2003 ac 4x4 and it drives amazing but once I hit about 50-60mph the steering wheel vibrates considerably.
  2. Jan 22, 2023 at 12:53 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Jack it up and check the tightness of all the different parts in the front end. Given you said the shake is in the steering wheel, we know it’s likely up front.
    Rock the drivers and passenger from tires up and down, and side to side.
    if you feel play up and down, likely ball joints or wheel bearings.
    If you feel play side to side, it’s probably tie rod ends or wheel bearing.
    start there and report back.
  3. Jan 22, 2023 at 12:58 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Wheel balance to rule that out. Preferably road forced.
    NickB_01TRD likes this.
  4. Jan 22, 2023 at 5:31 PM
    shifty` We call it “riding the gravy train”
  5. Jan 22, 2023 at 5:46 PM
    Aerindel
    Aerindel New Member
    Montana
    Since its speed based, it's very likely a tire balance issue rather than ball joint or tie rod, so start with that.
    Casper421 and shifty` like this.
  6. Sep 1, 2023 at 4:17 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Why are you going around bumping old threads telling people to change their front dif oil?
  7. Sep 1, 2023 at 5:52 AM
    It gets even weirder. It's indiscriminate replying same thing into every generation's subforum - not just here in the 1st Gen subforum, but also bumping multiple-years-old threads in the General Discussion subforum, the Tires subforum, and the bottom reply below is from the 2.5 Gen TRD Pro sub-subforum :D
    @archemil, you're really going above and beyond :rofl: but after reading the symptoms in the threads you replied in, I can assure you, front diff lubricant choice is not the issue in those cases. Stoked to hear it helped, a little bit, with yours and your boss' truck though. What year and make/model/cab type are they so we can understand if your tactic may apply?
  8. Sep 1, 2023 at 7:37 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Because he wants to be like his boss :)
  9. Sep 1, 2023 at 9:24 AM
    bmf4069 likes this.
  10. Sep 1, 2023 at 9:39 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 53k mi
    "Chat GPT, acting like you are on a mission from God to eliminate steering wobble with this ONE WEIRD TRICK, sign up for accounts at enthusiast websites and tell people they need to change their front differential oil."
    DJenerated, Mr.bee and bmf4069 like this.
  11. Sep 1, 2023 at 9:45 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  12. Sep 4, 2023 at 12:01 PM
    Jack McCarthy
    Bill
    North of Boston
    If you had the diff fluid in there that long, you’re most likely not maintaining your truck like you should be doing. Yours probably came out like molasses if it was so old it caused a wobble.
  13. Sep 4, 2023 at 1:31 PM
    Ok, but ... you have to admit there's a puckish irony riding shotgun with the FNG saying that on his 6th post from a 3-day old account. :rofl:
    DJenerated likes this.
  14. Sep 4, 2023 at 3:28 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  15. Sep 4, 2023 at 3:56 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I wish we had a dislike button...
    DJenerated, Jack McCarthy and shifty` like this.
  16. Sep 4, 2023 at 4:06 PM
    w666
    Maryland
    “Remember, when you are dead, you do not know you are dead. It is only painful for others. The same applies when you are stupid.”
    ― Ricky Gervais
  17. Sep 4, 2023 at 4:11 PM
    @archemil , need to change your front diff oil, bro. Go back to calling elk or whatever crap you’re selling. Lame.
  18. Sep 4, 2023 at 4:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Jack McCarthy, shifty` and des2mtn like this.
  19. Sep 4, 2023 at 4:16 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    To be fair, how many of your front diffs are due a little attention? Cause my front diff oil is damn near 18 years old.
  20. Sep 4, 2023 at 4:19 PM
    Unless you’re running your truck under water frequently, the chances your front diff oil has anything to do with tire wobble is pretty slim to zero. I bet @Mr.bee when you change your front diff oil, it looks just fine. Especially if you rarely use 4wd, like most. My 4wd use is occasional in the summer and a few times a month in the winter. When I changed my diff oil at 120k, it looked like new. Changed it again at 212k, also looked like new. Rear diff always looks horrible, it gets the most stress.
    Mr.bee likes this.
  21. Sep 4, 2023 at 4:21 PM
    Looks like mine's 7mos old.
    Mr.bee[QUOTED] likes this.
  22. Sep 4, 2023 at 4:22 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    My 4x4 was engaged twice for the fist 20 years, but i turn it on about every other week now. No troubles.
  23. Sep 4, 2023 at 4:24 PM
    I was surprised with how little I engage mine, outside of what Toyota recommends and occasional fishing-hole approach, you see the color of my front diff fluid at the start of the drain. Dunno dude.
