Steering wheel vibration that the dealer can’t fix
Discussion in '2.5 Gen Tundras (2014-2021)' started by robatumd, Sep 21, 2022.
  1. Sep 21, 2022 at 5:46 PM
    robatumd
    robatumd [OP] A_B_C
    Rob
    2020 Tundra SR5 CrewMax TRD Sport
    Need some help from the pros…
    I have a 2020 CM TRD Sport w/ 17,500 miles. All factory maintenance has been done in regards to oil and tire rotations.
    A couple weeks ago I started to notice some steering wheel vibration at highway speed between 60-70 mph.
    The vibration kept getting worse so I took it to the dealer. They did a tire balance and said it was fixed. Well it wasn’t. The vibration is now even worse. The weirdest thing is that it comes and goes. Usually when accelerating onto the highway it starts up, then getting up to speed it gets worse and after a few mins gets better.
    I know another cause here is ‘cupped’ tired but when I look at them they look just fine.
    I’m taking it back to the dealership tomorrow but I feel like I need to direct these guys.
    Any ideas? Anything besides another wheel balance or bad tires (which would suck if they only lasted 17k miles).
  2. Sep 21, 2022 at 6:32 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    parked too long and flat spot the tires...
  3. Sep 21, 2022 at 6:55 PM
    TTund16
    TTund16 New Member
    hopefully it's not drivetrain related.
    I had a faint pulsation in steering wheel and only in 5th gear and certain RPMs ... I haven't noticed it in a long time! Maybe I got used to it. lol
    My research showed that some have reported or noticed it with Tacoma or 4-Runners as well. also reported with some other cars (not Toyota).
    Can't recall now but I think it had to do with drivetrain and/or combination of even exhaust system & powertrain and certain resonant frequencies.
    if all else (tires, balance , shocks , suspension , brakes , etc.) ok, read my thread if interested but your vibration could be different. Mine was a very faint pulsation and hard to reproduce:
    https://www.tundras.com/threads/pulsation-in-steering-wheel-in-5th-gear.15217/
  4. Sep 21, 2022 at 7:02 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Swap another set of tires on and drive it then see what happens
  5. Sep 21, 2022 at 7:12 PM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    Sounds like something within the steering or suspension may have worked itself loose. Check all nuts and bolts and do a complete visual inspection of the front end undercarriage.
  6. Sep 21, 2022 at 7:15 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Take it somewhere else and let them balance the tires. It might help. Sometimes the balancing machines are off. That has happened to me before.
    Try rotating the tires front to back to see if that helps. If it does, that can help narrow it down.
    robatumd[OP] likes this.
  7. Sep 21, 2022 at 7:16 PM
    fugazi
    fugazi New Member
    2019 Cavalry Blue Tundra
    Check to see if they are using a plate and finger type adapter and not just cone adapters on the wheel balancer. High end machines can also do a road force balance, which may require dismounting and rotating the tire on the wheel. Sorry, I know those are both directly related to the tire balance that you just had done. Also wheel lug torque and pattern are very important on the 5 lug wheels
  8. Sep 22, 2022 at 4:14 AM
    AgileTundra
    AgileTundra New Member
    2018 Silver Sky Tundra Platnium 4x4
    alignment
  9. Sep 22, 2022 at 4:27 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    Appreciate all the ideas!
    Dropping it at the dealer now. If they can’t fix it I’ll take it to my Indy guy.
  10. Sep 22, 2022 at 4:31 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    It comes and goes but never fully goes away.
    I have a video of it but can’t upload here. It’s a wicked vibration!
  11. Sep 22, 2022 at 4:31 AM
    Have the runout checked on the rotors. I had this on my 2013 and it was in fact the rotors. Does it shake more if you tap the brake pedal while it's shaking?
    AgileTundra likes this.
  12. Sep 22, 2022 at 4:33 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Use a tire shop for alignment and balancing. I learned the hard way, well a $136 lesson.
  13. Sep 22, 2022 at 4:38 AM
    timsp8
    NY
    Also make sure all the lug nuts are torqued correctly and to spec. And that there is no rust or dirt between your wheel and the rotor. Try to rotate them and clean the contact surface while they are off.
    texasrho83 likes this.
  14. Sep 22, 2022 at 5:11 AM
    DannyD303
    DannyD303 New Member
    I doubt this is the issue but I had a car once that had a real bad vibration that would come and go. Turns out my brake caliper was seizing and not releasing the rotor. That car had well over 100k on the clock so again, doubt that's what's going on here.
    My 2019 4Runner Pro had a similar issue as well and the "fix" was to change the alignment and add a degree of toe-in. According to the dealer it would load up the front suspension a bit more. Seemed to help and I had 60k miles on my original tires with plenty of tread left.
    Just 2 more things to look at
  15. Sep 22, 2022 at 7:40 AM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Good luck in finding the issue. Please update if you get something figured out. My Tundra and my wife's Highlander both have this issue and I've grown tired of throwing money at fixing. She is still questioning my decision to move to the Toyota brand because of how her car drives. :frusty:
  16. Sep 22, 2022 at 7:47 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Same issue with mine tire was out of round they had to road force balance it to find the issue tires had around 5k miles and wouldn’t warranty it so I’ve been stuck with it since I lowered my psi and took away a lot of the vibes but as the tires are now 50% worn you can feel it even more can’t wait to replace these coopers .
  17. Sep 22, 2022 at 8:00 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I need to do road force balance too, since I change my tires to KO2 it have shakes comes and go, but if it’s shake on factory tires, I think it’s alignment or flat spot. If dealer cant fix it, may have to go American tires or any shop that have a road force machine, and ask for road force balance.
  18. Sep 22, 2022 at 4:27 PM
    robatumd
    robatumd [OP] A_B_C
    Rob
    Got the truck back from the dealer….
    On my short drive home (all highway, 65-70mph) the vibration was much improved. It’s not 100% perfect as I could still feel a very small vibration but it is much much better.
    Here’s what they told me they did:
    1. Rebalanced the tires. Test drove and it was still bad
    2. Put the fronts on the back. Test drove and it was better but not perfect
    3. Final rebalance. Issue mostly fixed. The tech said he thought it was 90% better and that I wouldn’t notice.
    The tech also mentioned that he saw some ‘light cupping’ on the outside of the edge of the front tires. He thought that replacing the tires would make it 100% but wanted to leave that to me.
    So I will continue to monitor it. The sucky part is that when I go for my next tire rotation in a year I guess I have to get new tires right? Assuming the cupping won’t go away by having them on the back? Maybe I need to do some burnouts to level them out :)
    Appreciate all the ideas and thoughts. Such a great community us Tundra owners have here!
  19. Sep 22, 2022 at 4:35 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    oof. tire rotation every 5k.. I think alignment make your tire cupping
    AZBoatHauler likes this.
  20. Sep 23, 2022 at 3:49 AM
    Bammer
    Monroe, CT
    Go to a tire shop and not a chain, a good well respected local place. I got the same explanation when I had an alignment issue. The dealers words, we did the alignment and it was close, once we swapped the tires from front to back, it was perfect. Yeah right, to a tire shop, alignment done = 100%
  21. Sep 23, 2022 at 8:48 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ditto on the tire rotation every 5kmiles. That makes a huge difference in keeping them wearing well and riding smooth.
    Tundras are sensitive to wheel balance and alignment. Skip the dealer for those services and find a tire or suspension shop that can do it right. The alignment being off just a hair will induce vibration that comes and goes based on speed, road conditions, etc.
    keeping air pressure correct, 5k balance and rotation of tires and alignment whenever needed will keep your truck driving as smooth as possible and extend the life of your tires.
  22. Sep 23, 2022 at 9:21 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    P rated tires you could go anywhere to balance, when you change out to LT tires, you may need shops that do road force balance.
  23. Sep 23, 2022 at 10:26 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Are you still on stock tires? The Bridgestone Duelers that come stock on 20" wheels aren't known for their longevity. Could be getting worn and out of balance.
    I had a u-joint in the driveshaft of my old T100 go bad and it made for a god awful vibration throughout the whole truck. It had about a 1/2" of play and depending how far off axis it would get stuck at, the truck would vibrate worse. I would hope the shop checked that sort of thing, but always worth going through and making sure all your driveline components are tight.
  24. Sep 24, 2022 at 4:18 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Get an alignment done at a reputable shop...Ask if they do printouts of before and after the alignment, with factory recommended specs.....I'd leave the tires on the front if worn evenly and not rotate them.... I had a continuing steering vibration problem at all speeds, .. Took it to a tire shop for Road Force balance, tech recommended don't waste your money.. Needs alignment.. drive it till the tires wear out, come back install new tires and align...Which took care of my problem..
  25. Sep 25, 2022 at 11:26 AM
    34ford
    34ford New Member
    2018 sky silver DC 5300 miles
    none yet
    I always road force balance, even on my Hot Rods w/ street tires. Makes a big difference , if anyone ever explains to you how it works you will always spend the extra$ and get it done right the 1st time. 34ford
  26. Sep 25, 2022 at 11:43 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    agrestic1 likes this.
  27. Sep 25, 2022 at 11:47 AM
    agrestic1
    2016 CrewMax
    Agree after alignment get them Road Force Balanced if available.. I found that even if a shop is listed on Hunter Road Force web site, call ahead to be sure..
  28. Sep 25, 2022 at 11:49 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Most local, small shop don’t have it, it’s a very expensive machine.
  29. Sep 26, 2022 at 5:09 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    After a weekend of driving it I’ve realized a couple things.
    1. the tires are definitely cupped. I’m now getting a rumble in the seat from the bad tires that went on the back.
    2. I think my alignment is slightly off. I really played with it on a super flat and straight road. It ever so slightly pulls to the left. My guess is it’s been that way for a while which is what cupped them
  30. Sep 26, 2022 at 5:10 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    Hit post too fast!
    I’m going to find a good alignment shop and then likely get new tires.
    I’m on stock 20’s. Any recos? I like KO2’s….
