Steering Rack play
Discussion in '1st Gen Tundras (2000-2006)' started by Dragracingdan, Jul 7, 2018.
  1. Jul 10, 2018 at 1:41 PM
    Dragracingdan
    Dragracingdan [OP] New Member
    2003 Tundra Limited
    (Tie rod end picks on previous page)
    Also I was reading this thread and someone mentioned carrier bearing. So while I was under there I shook the drive shaft center support bearing and there was quite a bit of play. Also the rubber was split in a few spots. The drive shaft also seemed to be sagging in the support bearing. Here is a picture below. Your thoughts?
    Thanks,
  2. Jul 10, 2018 at 2:27 PM
    Professional Hand Model
    Hand Protectors
    Yeah buddy. Grease those zerks. The carrier bearing is ok unless it starts wobbling and vibrating. When that happens change out your yokes and u-joints with new. In the meantime, grease the zerks. Should be 5.
    Dragracingdan[OP] likes this.
  3. Jul 10, 2018 at 3:17 PM
    Hand Protectors
    Anyone know the factory specs on allowable ‘play’ on these carrier bearing housings?
  4. Jul 10, 2018 at 3:55 PM
    Dragracingdan
    2003 Tundra Limited
    Thanks for the reply. I could easily shake the drive shaft at the carrier bearing. After looking some more, this may be where all the vibration and shaking is coming from?
    Didn't see any zerks while down there (wasn't really looking) Man, I really hope this is the issue I've been chasing! Seems like an easy enough project for a Saturday or Sunday.
    I can't find a good diagram of the drive shaft. There are 3 U-joints and @Professional Hand Model said yokes (...?) Is there anything else I should replace while I have the drive shaft apart?
    Thanks alot,
  5. Jul 10, 2018 at 3:58 PM
    Hand Protectors
    Youtube is your friend.
    Casper421 likes this.
  6. Jul 10, 2018 at 4:09 PM
    Hand Protectors
    Just change the carrier bearing and u-joints with zerk-able replacements. You can remove the drive shaft and take it up to a place that specializes in propeller shafts and they will put your parts on as they have a special press for the joints. Do not go cheapie on the carrier bearing and buy the Toyota OEM. Watch youtube about it.
    revtune likes this.
  7. Jul 10, 2018 at 4:09 PM
    Hand Protectors
  8. Jul 10, 2018 at 6:47 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  9. Jul 11, 2018 at 4:25 PM
    Dragracingdan
    2003 Tundra Limited
    Parts ordered. Went with all OEM parts. Got the carrier bushing and new U joints.
    Thanks to all for the assistance
  10. Jul 11, 2018 at 4:55 PM
    Hand Protectors
    Let us know if you find out the factory play in that new bushing. Mine has some play at 157k, but no problems with vibration.
  11. Jul 12, 2018 at 1:55 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    When you replaced the steering rack bushings did you tourqe everything to spec? They need to be much tighter than I originally thought and tightening it all tightened my steering up a lot.
  12. Jul 12, 2018 at 4:48 PM
    Dragracingdan
    2003 Tundra Limited
    When I replaced the bushings things definitely got better. I will go back and double check the torques though
    Thanks,
  13. Jul 12, 2018 at 4:57 PM
    Dragracingdan
    2003 Tundra Limited
    Ahh, found the page with the torque specs for those rack bolts. Thanks again
  14. Jul 13, 2018 at 7:36 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    123 ft lbs on that top bolt isn't easy but I finally got the wrench to click. Just enough clearance under the tranny pan to clear the torque wrench handle .
    revtune likes this.
  15. Jul 17, 2018 at 6:54 AM
    Dragracingdan
    2003 Tundra Limited
    Driveshaft parts are backordered from Toyota. Should be getting the tires any day now
  16. Jul 18, 2018 at 3:33 PM
    Dragracingdan
    2003 Tundra Limited
    Driveshaft parts tomorrow and wheels and tires this weekend!! Not sure I'll be able to get to the driveshaft this weekend but I should be able to test out the new wheels and tires
  17. Jul 20, 2018 at 4:35 PM
    Dragracingdan
    2003 Tundra Limited
    Got the new tires and wheels on. Still doing the shake/vibrate thing but not nearly as much.
    Guess I'll move on the to carrier bearing when I can. Rain this weekend.
    Comments and suggestions appreciated
    Best,
  18. Jul 21, 2018 at 6:59 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Good to hear that the new wheels and tires helped the shaking.
    Are you still have a steering issue at highway speeds?
    Is the shaking in the steering wheel or more in the seat?
    Can you post your allignment specs?
  19. Jul 21, 2018 at 8:13 AM
    #49
    Casper421
    In the woods
    06 DC
    lets see the new wheels and tires!
  20. Jul 21, 2018 at 11:16 AM
    #50
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    I had the exact same vibration and it ended up being my carrier bearing on the driveshaft.
    revtune likes this.
  21. Jul 21, 2018 at 1:14 PM
    #51
    Dragracingdan
    2003 Tundra Limited
    Still slight back and forth movement in steering wheel. Used to be at 65 mph now it seems it's doing it at 45 to 50 mph with the new tires.
    There is also vibration throughout the cab. Water bottle in the cup holder is constantly shaking etc.
    Here's a pic of the alignment sheet from the alignment I got 2 or so weeks ago...
  22. Jul 21, 2018 at 1:16 PM
    #52
    Dragracingdan
    2003 Tundra Limited
    Before with the corroded 15 year old Enks:
    After with new wheels (please forgive, it needs a wash..)20180720_171911.jpg
    Casper421[QUOTED] likes this.
  23. Jul 21, 2018 at 1:25 PM
    #53
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Looks great!
    Your alignment numbers look good.
    Can you take a video of your steering rack and tie rods when you turn the wheel side to side with wheels on the ground. This will show you where the play in the steering wheel is coming from.
  24. Jul 21, 2018 at 1:28 PM
    #54
    Dragracingdan
    2003 Tundra Limited
    Thanks!
    Raining out now and I'll need a second person to man the wheel. May take me a few days to post a video
    Thanks for your replies and comments
  25. Jul 21, 2018 at 1:46 PM
    #55
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    I was able to prop my phone under the truck and then hop in and steer it.
  26. Jul 21, 2018 at 1:50 PM
    #56
    Dragracingdan
    2003 Tundra Limited
    Great! I'll give it a try
    Thanks
  27. Jul 22, 2018 at 6:27 AM
    #57
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    Carrier bearing replacement helped tremendously with mine, but I've still got a vibration somewhere.....i'm still enjoying chasing gremlins and replacing worn out parts at 214k lol.
  28. Aug 19, 2019 at 9:16 PM
    #58
    jkeith72
    jkeith72 New Member
    2005 Tundra SR5 4X2 Double Cab Phantom Gray
    Any updates on this? Did the vibration get fixed?
  29. Jul 21, 2020 at 6:02 PM
    #59
    Hg750
    Hg750 New Member
    Any updates? I have a 2000 model doing the same wobble you described.
  30. Jul 21, 2020 at 6:14 PM
    #60
    shifty` Countin' and breathin', disappearin' in the fade
    It looks like last login from @Dragracingdan was back in September 2018. Can't even properly tag him on here anymore. I doubt he's gonna be answering y'all any time soon. Hopefully it wasn't something bad resulting from the wobble.
