Starter help.....
Discussion in 'General Tundra Discussion' started by TxTundraGuy89, Jul 5, 2015.
  1. Jul 8, 2015 at 9:21 AM
    #61
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    $500 is a good price. I was reading that several others were quoted 6 hrs with a total around $1200
  2. Jul 8, 2015 at 9:22 AM
    #62
    Sometimes your local dealer will have online repair specials.
  3. Jul 8, 2015 at 9:25 AM
    #63
    Ditto on that. $500 is peanuts nowadays. A co-worker had his 2010 Sierra's auto transmission line replaced. Just 1 that was leaking . Simple job $630.00.
  4. Jul 8, 2015 at 10:59 AM
    #64
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's probably the hot tip. The headache and stress of doing it yourself can be more than it's worth.
  5. Jul 8, 2015 at 11:13 AM
    #65
    TxTundraGuy89
    TxTundraGuy89 [OP] New Member
    Korwin
    Yeah I'm real DIY so bothers me but in the end probably for the best.
    Wynnded likes this.
  6. Jul 8, 2015 at 1:36 PM
    #66
    TxTundraGuy89
    Korwin
    I guess what sucks mostly is now there doing poor engineering on purpose just so you have to throw your vehicle in the shop and that's what sucks most I think.
  7. Jul 8, 2015 at 1:40 PM
    #67
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They were probably hoping that the vendor they were getting the starters from were selling them a more reliable component so they could get away with this design.
  8. Jul 8, 2015 at 2:52 PM
    #68
    When the starter finally goes, might as well throw on some long tubes. Turn a negative into a positive. You have to pull off one side anyways. Just a random thought.
  9. Jul 8, 2015 at 4:10 PM
    #69
    TxTundraGuy89
    Korwin
    Haha yeah I would like to but since it's my tow vehicle trying to keep it mostly stock.
  10. Jul 8, 2015 at 6:05 PM
    #70
    Mike Tread lightly.
    south carolina
    You know it could be worse... you could have my engine thr 2uz-fe... the starter is in a valley under the intake.
  11. Jul 8, 2015 at 6:12 PM
    #71
    TxTundraGuy89
    Korwin
    Yes this is so very true.
    Well The Hulk has been dropped off to have it's transplant done. Going to have him back by tomorrow
    Black Wolf likes this.
  12. Jul 10, 2015 at 9:13 AM
    #72
    TxTundraGuy89
    Korwin
    Well when the other guy moved the starter he broke the signal cable, so they had to order the part.
    Shop just got it in, and The Hulk will be running shortly, so tonight I'll be picking him up.
    T-Rex266 likes this.
  13. Jul 10, 2015 at 12:48 PM
    #73
    TxTundraGuy89
    Korwin
    Well just talked to the shop and they said the starter is in, but now there's no power to my fuse block....so now I'm waiting for a call back but right now I'm not quite a happy camper because I think they messed something up and I'm going to refuse to pay for it.
  14. Jul 10, 2015 at 1:17 PM
    #74
    If you can prove it's not from you, then its on them.
  15. Jul 10, 2015 at 1:19 PM
    #75
    TxTundraGuy89
    Korwin
    Well when I took the truck I had all power and everything hince how I pulled it there. Now there saying there's no power to the fuse block which says there's no power to my truck.
  16. Jul 10, 2015 at 1:40 PM
    #76
    TxTundraGuy89
    Korwin
    Truck is ready!!!! Woooohooooo!!!!! The issue was I had put new battery terminals and didn't begin to think of them being painted and the paint was causing a power restriction, once they changed it, it started right up.
  17. Jul 10, 2015 at 2:26 PM
    #77
    U painted the terminals?
  18. Jul 10, 2015 at 2:27 PM
    #78
    TxTundraGuy89
    Korwin
    No believe it or not they were sold like that
  19. Jul 10, 2015 at 2:28 PM
    #79
    That's odd.
  20. Jul 10, 2015 at 2:29 PM
    #80
    TxTundraGuy89
    Korwin
    I know huh? But truck is running now so happy about that
  21. Jul 10, 2015 at 5:21 PM
    #81
    TxTundraGuy89
    Korwin
    Well The Hulk is back home with Daddy, plugged in my scan tool and I think the gas I'm running is making the truck run codes so definitely going to put good quality gas and a fuel treatment to see what that does.
  22. Jul 10, 2015 at 6:27 PM
    #82
    You're popping a CEL now?
    FWIW I only use Shell in mine.
  23. Jul 11, 2015 at 3:40 AM
    #83
    TxTundraGuy89
    Korwin
    Yeah it was saying the truck has a misfire, the truck was running too lean and too rich. I really think it's just the fuel alone.
    Definitely going to start putting a better gas in the truck.
