Starter help.....
Discussion in 'General Tundra Discussion' started by TxTundraGuy89, Jul 5, 2015.
  1. Jul 6, 2015 at 3:49 AM
    TxTundraGuy89
    TxTundraGuy89 [OP] New Member
    Korwin
    Are the bolts on the manifold to exhaust indeed metric though? Cause I was using an SAE and it had a solid grab on it.
  2. Jul 6, 2015 at 6:49 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    That I do not know
  3. Jul 6, 2015 at 7:22 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I used a 14mm when I was removing the bolts connecting the front of the muffler to the connecting pipes coming from the engine. I haven't encountered any SAE on my Toyotas. There are some that are very close though.
  4. Jul 6, 2015 at 9:21 AM
    TxTundraGuy89
    Korwin
    Well damn, if that's the case that's where I probably went wrong. Good news is I talked to a guy where I'm staying and he's supposed to come look at it tonight.
    T-Rex266 and Wynnded like this.
  5. Jul 6, 2015 at 9:23 AM
    csuviper
    Broomfield, CO
    That is what i was thinking. They should all be metric but there are some standard that are very close, some closer than others
    1/16" = 1.587mm
    1/8" = 3.175mm
    3/16" = 4.762mm
    1/4" = 6.35mm
    5/16" = 7.937mm
    3/8" = 9.525mm
    7/16" = 11.113mm
    1/2" = 12.7mm
    9/16" = 14.287mm
    5/8" = 15.875mm
    11/16" = 17.463mm
    3/4" = 19.05mm
    13/16" = 20.638mm
    7/8" = 22.225mm
  6. Jul 6, 2015 at 9:24 AM
    csuviper
    Broomfield, CO
    Yea should be 14mm. So if you used a 9/16" socket then you were .287mm too big
  7. Jul 6, 2015 at 9:26 AM
    TxTundraGuy89
    Korwin
    Yeah, glad I have the reference now. Just hopefully today or tomorrow I get it back and have beast running again I'm having withdrawls right now.
  8. Jul 6, 2015 at 5:25 PM
    Good luck. The starter swap is probably the trickiest. I have not read any good DIY experiences with the starter. Certainly doable just a pain in @ss. Home depot has PB too. It works.
  9. Jul 6, 2015 at 6:15 PM
    TxTundraGuy89
    Korwin
    Thanks, luckily I have a neighbor that's a mechanic and he's going to take a look and fix the truck tomorrow hopefully.
  10. Jul 7, 2015 at 5:00 PM
    TxTundraGuy89
    Korwin
    I have a question guys, my truck is 8yrs old, has 167k on it the guy looked at the truck but sad it's possible that when taking off the bolts on the manifold to the block they could break. What are the real odds of that happening?
    The guy is a true mechanic and he's being upfront with me.
  11. Jul 7, 2015 at 5:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's a very real possibility, look at what happened to the bolts that you were working on, and they were of similar material. The bolts and the engine block are different materials and given the heat cycles and passage of time, they tend to be....difficult to separate. If any one of them are broken, they will need to be drilled out and new threads inserted. It's generally referred to as a "helicoil". That's just one of the reasons that many consider the placement of the starter behind the manifold such poor engineering.
    If this fella can get your truck back on the road, you will be indebted to him. IMO
    Black Wolf likes this.
  12. Jul 7, 2015 at 5:33 PM
    TxTundraGuy89
    Korwin
    Yeah he said he can do it, he's just afraid that one will break and then I'll be screwed, but I'm caught in a hole cause if a shop does it, puts me in the same position.
    So I'm not quite sure what to do.
  13. Jul 7, 2015 at 5:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have you been squirting the bolts with PB Blaster/WD40 while pondering your decision? That can only increase the odds of removal, but it's a chance that will need to be taken regardless of who has a try at it, this guy or the shop. Someone has to do it or the truck never moves again.
  14. Jul 7, 2015 at 5:49 PM
    TxTundraGuy89
    Korwin
    I haven't going to pick up some now. Regardless if it breaks have to send it in a shop period.
  15. Jul 7, 2015 at 6:10 PM
    TxTundraGuy89
    Korwin
    Is there a slight chance with enough pb blaster they could come out smoothly?
  16. Jul 7, 2015 at 7:07 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes, absolutely. That's why most everyone usually has some variant of it handy. It does necessitate a little time to soak in though. If you're dashing out to get some this evening, give them a splash tonight so that it has a chance to soak in overnight, then hit them again as soon as you can in the morning. That will increase the odds in your favor before you guys actually put a wrench on them. I know you're in a pinch to get this sorted, but giving it some time to work in is prudent.
  17. Jul 7, 2015 at 7:20 PM
    TxTundraGuy89
    Korwin
    Yeah, let me ask this as well. If i took it to a shop and they broke the bolts they would be liable for any extra work correct?
  18. Jul 7, 2015 at 7:21 PM
    50/50 chance. You're damned if you do, and damned if you don't.
  19. Jul 7, 2015 at 7:26 PM
    #49
    TxTundraGuy89
    Korwin
    Dammit....guess i'm in quite a hole then huh?
  20. Jul 7, 2015 at 7:29 PM
    #50
  21. Jul 7, 2015 at 7:30 PM
    #51
    TxTundraGuy89
    Korwin
  22. Jul 7, 2015 at 7:40 PM
    #52
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would think not. They're not being negligent or careless, like over tightening the lugs with an impact. Just my opinion there...
  23. Jul 7, 2015 at 8:07 PM
    #53
    TxTundraGuy89
    Korwin
    Yeah thats where it's a catch 22 I think, cause it's not like there already broke.
  24. Jul 7, 2015 at 8:18 PM
    #54
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    True, but your starter is (broken), and you may need to "break some eggs to make an omelette". You're between a rock and a hard place man. From what is understood, the manifold must come off to get to the starter...
  25. Jul 7, 2015 at 8:20 PM
    #55
    TxTundraGuy89
    Korwin
    Yeah guess I'll find a shop and say a prayer. Like you said a rock in a hard place have to make a decision
  26. Jul 7, 2015 at 8:26 PM
    #56
    csuviper
    Broomfield, CO
    If the shop breaks the bolts trying to get them out they will be charging you for the extra labor it takes to remove and new bolts because they were seized. Not the shops fault they were seized. They should come and tell you that they are seized if they can't get them out right away and ask for permission to proceed with harsher measures.
    Is there any way you can get in there with a torch and heat the housing around the bolt to hopefully expand the hole?
  27. Jul 8, 2015 at 4:30 AM
    #57
    TxTundraGuy89
    Korwin
    He said he could but he's afraid then it would mess up the threads.
    I do have a question though, before I go any further with this task. Whenever I went to start my truck the day it didn't start. My truck voltage meter was reading in the middle between 9v and the middle line, but when tried to jump start it, it would go straight to the middle line could that be an indication of a bad alternator?
  28. Jul 8, 2015 at 7:49 AM
    #58
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm not sure how it's set up, but I would speculate that when the engine is not running and the key is in the run position, the voltage gauge displays the battery voltage. When the engine is running, the voltage gauge displays the alternator output voltage. A shop is going to have a way to check the alternator voltage output and it's ability under electrical load as well.
    It's also possible that your battery is getting tired. A shop will be able to load test that as well. If the battery is greater than five years old, it may need to be replaced.
    Ask the shop to check those two items first, as they're easier to get to and cheaper to replace. I don't know what the alternator costs, but it's got to be WAY easier to replace than that fricking starter.
  29. Jul 8, 2015 at 8:25 AM
    #59
    TxTundraGuy89
    Korwin
    Yeah talked to a shop and they're going to charge 500 to do the job.
    Battery was tested and came back fine, so going to put it in the shop tonight and hopefully tomorrow or day after have me a running truck.
  30. Jul 8, 2015 at 9:21 AM
    #60
    I remember looking at my alternator and thinking it would be a bitch to swap if it ever failed. Then I located the starter.... :annoyed: I would still replace my alternator myself. Starter??? I just hope it is very well made to last. At least if the dealer has it and something breaks, they will be able to fix it. I won't even touch that.
