Squeaky Brakes
Discussion in '2.5 Gen Tundras (2014-2021)' started by hillbillytoyo, Nov 15, 2017.
  1. Sep 13, 2019 at 9:58 PM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    I have same issue only on start up and going in reverse dealer keeps saying they are fine
  2. Sep 13, 2019 at 10:31 PM
    TTund16
    TTund16 New Member
    Mine did it since new definitely going forward. Can't recall in reverse since I back-in most of the time and everything seems to be working fine. I hear some squeaks for the first one or two brakes but then back to normal with no noise. I am going to pay more attention now and see if the squeak is coming from a specific tire. The noise seems to be coming from all angles, that's why I've been ignoring it. :D
  3. Sep 13, 2019 at 10:57 PM
    Boxer310
    Boxer310 New Member
    Mine seems to be coming from the rear only comes on after a fresh start after truck was off for a while and I reverse our the driveway then all good
  4. Sep 16, 2019 at 6:28 PM
    nodnero
    nodnero I'm here legally yo!
    Temecula, CA
    Cement 2018 Limited 4x4 Crewmax
    18x9 Method 312 285/75R18 Toyo R/T Trail TRD Pro Suspension
    Update: Rear hub and bearings will be replaced under warranty. No mention as to whether or not tied to potential TSB.
  5. Sep 17, 2019 at 3:41 AM
    316KS_Runner
    316KS_Runner There’s no place like…
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    About a month ago I took mine in for its first oil change, and asked them to look at the brakes as they are squeaking really bad. After digging deep into the issue they found that the rear calipers sliders did not have a speck of grease on them. Turns out they were never lubed up from factory.
  6. Sep 30, 2019 at 10:47 AM
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    Good to know. Mine is garage kept and count me in the list of those who said it only does it when backing out of driveway first thing in the morning. I have noticed it tends to be more common after it has been raining, just gave it a bath, or is humid outside. Dealership said they double checked them and brakes are fine and to let them know if still happening at next service. Very glad to have found this thread.
  7. Nov 7, 2019 at 9:55 PM
    Cali2017NeverAgain
    Cali2017NeverAgain New Member
    I am having the same issue with my 2019 Tundra 1794. I bought with 6 miles on the odometer. At 1,200 it started to make some weird noises, like clicking sounds and other noises I can't describe. It's as if something is rubbing against the rotors. Then, the dealer decided to sand the pads and the rotors, and now the breaks squeal when I brake. The dealer said "we can't replicate the noise you're hearing, so we can't fix the issue." I shot a video of the truck backing up, but they're still telling me that bullshit. I am now in direct talks with Toyota Headquarters. I didn't pay almost $52K for a truck to have noisy brakes. It seems that either the mechanics at the dealer are incompetent or they just don't care about fixing the problem. I bet that if the truck was out of warranty, they would find the way to fix it.
