Spyder Tail lights?
Discussion in 'Lighting' started by Surfer Ken, Mar 28, 2018.
  1. Jun 21, 2019 at 10:52 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    The problem is that the factory wiring isn’t really color coded or clear which one is positive and which one is negative. If you have a multimeter you could turn on your taillights with the assembly out and read the two wires to know for sure and then mark them. I’m running the smoked and I guessed them correctly. But, I should have done what I mentioned above.
    rollingTide29[QUOTED] likes this.
  2. Jun 21, 2019 at 11:00 AM
    rollingTide29
    rollingTide29 New Member
    Chase
    Murfreesboro, TN
    2019 MGM TRD Sport Crewmax
    Do you remember how you plugged then in?
  3. Oct 8, 2019 at 7:11 AM
    colossalcrewmax
    colossalcrewmax New Member
    2019 tundra crewmax
    S&B intake , nfab side steps , limo tint 5% and 35% front window , custom side exit exhaust
    I would like to know this as well as i am getting ready to order a set
  4. Jan 4, 2021 at 5:06 PM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Did you happen to order a set and install, and remember in what order the wires were connected? Or anybody else for that matter?
    Attempted earlier and blew the 10 amp STOP fuse. I only had 1 fuse in my tool box so I reassembled my OEM tails until I get a bunch more from the auto store. The directions are garbage from Spyder. The 2 pictures they provided don’t show the correct wiring, and their YouTube install doesn’t mention it either.
  5. Jan 5, 2021 at 6:24 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Not to mention, the color of the OEM wiring isn’t very helpful either. If I recall, you’re only dealing with two wires that could be reversed so you can probably just flip those.
  6. Jan 7, 2021 at 3:03 PM
    MatD13
    MatD13 New Member
    Popped the smoked red Spyders in today without blowing a fuse again. Took a couple pics for anybody in the future that had my problem the other day. The bottom picture I took is kinda hard to see the trucks wiring. Just match the green from the light to the truck wiring and should be good to go.
    Also found out that if you have a LED reverse light, it will cause the blinkers to hyper flash, so I put my original halogen bulbs back in with success.
  7. Jan 7, 2021 at 5:51 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Ok, how about a pic with them installed an on? :)
  8. Jan 8, 2021 at 4:50 AM
    MatD13
    MatD13 New Member
    Happy with the results!
    Tundra805 and Downytide like this.
  9. Jan 8, 2021 at 7:02 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    One of the main reasons I would consider this is so I could have brighter LED backup lights.
    Does this upgrade provide this? Or is there a hyperflash issue?
  10. Jan 8, 2021 at 8:03 AM
    MatD13
    MatD13 New Member
    Hyper flash issue with LEDs. I purchased some Lasfit led reverse bulbs and caused it unfortunately. I wanted brighter reverses too. swapped back to stock and it went away.
  11. Jan 8, 2021 at 4:33 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    That's nice, exactly what I'm looking for, kinda annoys me that we have such a cool front end then get stuck with wacky halogen tails.
  12. Jan 8, 2021 at 4:49 PM
    MatD13
    MatD13 New Member
    Thanks! I am glad I purchased it. I went with the “red smoke.”
  13. Oct 23, 2021 at 1:46 PM
    FSUTundra
    FSUTundra Misplaced Texan
    Cody
    2018 MGM 4x4 CM TRD
    Just got done installing mine - red smoke. This post was super helpful to get the wires matched up. No blown fuses.
  14. Nov 3, 2021 at 11:55 AM
    FSUTundra
    Cody
    2018 MGM 4x4 CM TRD
    So after a couple weeks of driving now, I'm getting hyperflashing with my turn signals. I've only noticed it specifically when my headlights are on, I'm braking, and have the turn signal on.
    Anyone else have this issue? Any solutions? I've also reached out to Spyder and the retailer I purchased from to see if they have any suggestions as these should be plug and play.
  15. Dec 5, 2021 at 4:57 PM
    MatD13
    MatD13 New Member
    Did you ever resolve this? I resolved mine a few weeks back after checking all the fuses again and found I had a 40 amp fuse blown under the hood. I had the exact same issues as you when hitting the brakes, headlights on, and turn signal on. Reinstalled the taillights and all is good now.
  16. Dec 13, 2021 at 6:22 AM
    FSUTundra
    Cody
    2018 MGM 4x4 CM TRD
    I did not, I reached out to spyder and they sent me new resistors. I put those on and now it's hyperflashing all the time. I'll give my fuses a look and see if that resolves it. Thank you
  17. Jan 12, 2022 at 2:07 PM
    MatD13
    MatD13 New Member
    another question for you… did you ever do the recall for the turn signal brightness? The techs would’ve repinned the front turn signal adaptors…
    I just did the recall and it was doing the hyperflash like stated in posts above. After checking all fuses and the wires in the taillights, I ended up “undoing” the recall and repinning the adaptors myself.
  18. Jan 12, 2022 at 2:30 PM
    FSUTundra
    Cody
    2018 MGM 4x4 CM TRD
    I don't recall that one being done on my truck off the top of my head.
    I ended up switching back to the old resistors that were originally in the taillights and it went back to the same issues where it will hyperflash sometimes. I checked all my fuses as well and didn't see any blown ones.
    What do you mean by what you did? You reversed the recall and then made another change to your front turn signals? Do you have just the stock LED headlights?
  19. Jan 12, 2022 at 6:21 PM
    #49
    MatD13
    MatD13 New Member
    the recall was essentially moving one wire over in the harness. The attached video in the link, post #67 shows what the Toyota Tech will do when performing the recall. I just moved the wire back to the middle spot. It works all good now
    Think I found the solution to the dim front turn signals on 18+
  20. Feb 1, 2022 at 12:33 PM
    #50
    FSUTundra
    Cody
    2018 MGM 4x4 CM TRD
    I'll try and take a look and see if can tell if they're flipped. Appreciate all the help.
    MatD13[QUOTED] likes this.
  21. Jul 26, 2023 at 8:40 PM
    #51
    Chitownpro
    Chitownpro New Member
    2020 White TRD Pro
    I have the Spyder red smoked taillights on my 2020 Tundra and still have my left turn signal only hyper flash when applying the brakes. I saw others post about this same problem, did anyone ever find a solution? 2nd set of Spyders and same issue.
