Splicing light bar into high beams?
Discussion in '2nd Gen Tundras (2007-2013)' started by Scooter916, May 27, 2021.
  1. May 27, 2021 at 8:18 AM
    Scooter916
    Scooter916 [OP] New Member
    Nathan
    08 5.7l CrewMax SR5 2wd,
    custom shift knob, Hooke Road front and rear bumpers, 12v Solutions Remote Start
    Just ordered new front and rear bumpers and they are arriving this afternoon. I plan on hooking the light pods up to the existing fog light wire harness. But was wondering if its possible to hook the light bar up so it only comes on with my high beams? Or if I should wire to a 3 position switch (work independently, in tandem with highs and off)
    Electrical is new to me so I've been reading up the best I can.
    I plan to tie the rear pods into the reverse lights
  2. May 27, 2021 at 8:55 AM
    Scooter916
    Nathan
    Forgot photi
  3. May 27, 2021 at 8:57 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Yes, I had an add a fuse with one of the highbeam fuses along with a switch. The lightbar would come on with the high beams if the switch was left in the on position.
  4. May 27, 2021 at 10:13 AM
    Scooter916
    Nathan
    yeah that's what I'm thinking the more I look into it. need to sit down and do some research on that
  5. May 27, 2021 at 10:54 AM
    rossdepanfilis
    rossdepanfilis New Member
    Ross
    Ridgway
    2018 Tundra Platinum
    2 Cars Seats in the back, Gator Pro Tonneau, KB Voodoo Rack
    I originally had LED light pods wired to come on with my reverse lights. Now I have them setup on a switch (on-off-on) to either come on when I flip the switch one way, off in the middle, or come on with the reverse lights.
    The reason for that is because when I did not need/want those BRIGHT LED pods turning on when I was backing out of a parking spot on the road or parking lot and potentially blinding the person coming up the road.
    On my work truck, I currently have my light bar tied directly to my high beams. (through a relay) and I want to put them on a switch where it I can turn off the light bar if I don't need it. I just haven't gotten around to it yet.
    I need the light bar and the rear light pods for plowing snow, in the woods, or driving down a lease road where there is no traffic or street lights or anything like that.
  6. May 27, 2021 at 10:58 AM
    Scooter916
    Nathan
    Yeah I'm leaning more towards the 3-way for the light bar, I like the idea of the 3-way for the rear. and will probably run the front pods off my existing flood light wire harness with an adapter
  7. May 27, 2021 at 11:14 AM
    Scooter916
    Nathan
  8. May 27, 2021 at 1:53 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I always use a relay triggered off the factory high beams for my supplemental lighting. If you ever plan to use them for backroads where you may encounter traffic and need to dim them quickly, a switch is a pain.
    tundramike23 and dumbassdave like this.
  9. May 27, 2021 at 11:14 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Do you mind linking a relay or providing a part number? - like one you'd use for a light bar or pair of ditch lights?
  10. May 28, 2021 at 4:57 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Just google "light bar relay kit"........10 bucks almost everywhere. Most kits come with switch, relay, wiring and instructions (which looks like it will helpful for you). Some states require accessory lighting be switched. If you want your forward lighting to come on with the high beams, just run your trigger wire through the switch and turn it on/off. (see post #3)
  11. May 28, 2021 at 8:58 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    I have lightbar on with my high beams too, for this reason. A push button switch is too hard to get at quickly. On mine, I went one step farther in case I ever needed to have my high beams on but my light bar off. With a second relay, I tied into the fog light switch, so that if I have my fog light switch off, my light bar wont be on with high beams. If you are doing lighting stuff, may as well also look at the mod that keeps you fog lights on with your high beams. May as have all of the lights on!
  12. May 28, 2021 at 10:45 AM
    Scooter916
    Nathan
    I was mainly wanting them on a switch for when I go camping and I might need to set up camp in the dark, mostly the bar will be used only with high beams on backroads.
  13. May 28, 2021 at 10:54 AM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Have you looked into a SwitchPro?
  14. May 28, 2021 at 11:07 AM
    Scooter916
    Nathan
    That looks pretty sweet, but a little out of my price range ( if I was looking at the right thing?)
  15. Oct 14, 2022 at 5:51 AM
    tundramike23
    tundramike23 New Member
    Michael
    Tyler, Texas
    2015 Toyota Tundra Platinum
    Momentum GT Cold Air Intake/ Bilstein 5160 Series/ Ironman 4x4 Raid Series Front Bumper w MONSTER WINCH./ Ironman 4x4 32" Lightbar w Light Cubes/ CBI Toyota Tundra Overland Rock Sliders/ JS 3000w High Output Alternator + Big3 Kit/ Pedal Commander
    how did you find which wire runs your highbeams? Did you find a diagram for the headlight assembly plug in?
  16. Oct 14, 2022 at 5:53 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    ^^^^This!
  17. Oct 14, 2022 at 6:18 AM
    tundramike23
    Michael
    Tyler, Texas
    Ohannon7 likes this.
  18. Dec 30, 2022 at 8:40 PM
    InfernoPro15
    InfernoPro15 New Member
    Instead of splicing into the high beam wire has anyone tried locating high beam fuse or is that not a thing here. I haven’t looked yet.
  19. Dec 30, 2022 at 9:38 PM
    campergf23
    campergf23 2021 TRD Sport Premium DC
    Quebec, Canada
    I've got my light bar set up like that. Add a fuse from the highbeam to the + on my switch. It then goes to a relay and the light bar gets its power straight from the battery.
    With my setup, the light bar comes on with highbeams, but only when the switch is in the "on" position. I can leave the switch on and toggle the high beams/light bar with the highbeam stalk, or let them turn on and off with the auto highbeam feature ('21 trd sport premium).
    I used to have the light bar on it's own switch, but like others I found it to slow to disable when encountering oncoming traffic.
    InfernoPro15[QUOTED] likes this.
  20. Dec 31, 2022 at 4:03 AM
    InfernoPro15
    This is perfect. Wired my 42in grill one yesterday according to instructions and I love it but the separate button is a pain. Figured unhook the positive wire from the battery and run it off high beam fuse that way I still have the button to disable it with during inspections and way easier to manage it on back roads with high beams stalk switch. Awesome.
    campergf23[QUOTED] likes this.
