Spin on filter
Discussion in 'General Tundra Discussion' started by InfernoTundra, Oct 8, 2021.
  1. Oct 8, 2021 at 10:32 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    So does my TSS. I think the skid just keeps the underside cleaner versus offering protection for off roading.
    BTBAKER likes this.
  2. Oct 8, 2021 at 10:35 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I think Baxter makes good stuff, and made in the US. I was looking at this but decided to live with the cartridge for now.
    Since it's a new truck, if by the small chance something goes wrong warranty-wise (like a leaking coolant hose/clamp) I wouldn't want the dealership to see that Baxter filter setup while under warranty. They'd love to use it as the reason for anything that is wrong with your truck. Just wouldn't want to give them any ammunition.
    RitcheyRch likes this.
  3. Oct 8, 2021 at 10:54 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    My 2014 SR5 4x4, non TRD, non Offroad, has a skid plate.
  4. Oct 8, 2021 at 11:14 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    There's 3 different 'skids'. 4x4 got standard cheap skid not advertised(2wd 5.7 might also get this one?) >> TRD OR gets a marginally better but still cheap one >> TRD Pro alum. skid.
    The first two basically being tinfoil splash shields.
  5. Oct 8, 2021 at 11:18 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    I didn't like the cartridge type either coming from domestics, but honestly it isn't any more difficult than the spin on. Get the right wrench and the metal filter housing and imo it's easier than the spin ons. I'd just leave it how they designed it. Oil is way too important of an item to start trying to use gadgets to re-engineer the filter setup. My .02
  6. Oct 8, 2021 at 12:26 PM
    InfernoTundra
    InfernoTundra [OP] New Member
    Thanks for the input. My previous truck I had the metal filter housing and the drain bolt at the bottom would be too tight and the whole housing would come off when trying to drain the oil. Probably my fault and wasn't terribly messy but I think this will be much better for me especially after I get the Fumoto drain valve.
    Wahayes[QUOTED] likes this.
  7. Oct 8, 2021 at 12:48 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The oe skid plate is very thin, i agree it is probably mostly intended on air flow and protecting muds/branches from flowing straight up into the engine bay
  8. Oct 8, 2021 at 6:03 PM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    I always thought the anti-drain keeps oil from draining from the filter while sitting. That would be important if the filter screws onto the side of the engine and sits horizontally. Some even sit on top with the opening down. Anti-drain would be very important there. But with the filter hanging vertically with the opening up, where's it going to drain to? I can't see the anti-drain being of any benefit.
    Maybe I'm wrong -- wouldn't be a first :)
  9. Oct 8, 2021 at 6:07 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If the oil filter was higher than the oil pan, oil could drain backwards from higher in the engine, through the filter back to the pan. Even if vertical. Maybe im wrong too
  10. Oct 9, 2021 at 6:40 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    Even if higher than the oil pan the oil would have to flow up first to drain out, though.
    My mother-in-law had a Jeep with the oil filter on front of the engine well above the pan. If the filter didn't have a good anti-drain back valve it could sit there and drain mostly empty. I just can't see that being an issue on the Toyotas.
    Hbjeff[QUOTED] likes this.
  11. Oct 13, 2021 at 7:47 AM
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    I just installed mine and the stock skid plate fits easily with 3 to 4" clearance. IMG_0709.jpg IMG_0711.jpg IMG_0712.jpg
    plumber802 and Mr_Ed like this.
  12. Oct 13, 2021 at 8:02 AM
    InfernoTundra
    Great, thanks for the info. I will be getting the skid plate off my old truck and it will get a newer one.
  13. Oct 20, 2021 at 6:07 AM
    co2owen
    co2owen New Member
    VA
    I'm looking forward to my next oil change! A benefit of the expensive baxter adapter is I won't have to remove the skid plate on my next oil change. I can just reach in there and spin the filter off. I'll use a ziplock bag and some rags to catch the mess but I'm sure that'll beat skid plate removal.
  14. Oct 20, 2021 at 6:20 AM
    InfernoTundra
    I cut a hole in my old skid plate to remove the filter without dropping the skid plate. As long as the filter doesn't hang lower than that, it should work great to remove the spin on filter.
  15. Oct 20, 2021 at 6:28 AM
    co2owen
    co2owen New Member
    VA
    Yes, I've seen some photos on this site of people cutting a hole or cutting a door and welding hardware onto it to reattach it. I'll do that (either a hole or a door) if I have any trouble spinning it off through the side opening of the skid plate.
