SPC UPC arm help
Discussion in 'Suspension' started by cain0725, May 6, 2021.
  1. May 6, 2021 at 7:24 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    The only reason I actually looked into this thread is I recently saw a post on a facebook group where someone actually did swap sides/flip them upside down!
    I had SPC on the 4runner and loved the adjustability but if the installer doesn't understand how they work....good luck.
    Edit: to the OP, looks normal to me!
    https://www.tundras.com/threads/spc-uca-question.40269/
  2. May 6, 2021 at 7:29 PM
    I've seen at least one post where they were mixed up as in wrong side, but not upside down. You would have to press out the ball joints and reinstall the opposite direction. I'm just not comprehending that but not disputing it either....ha
  3. May 6, 2021 at 7:32 PM
    cain0725
    cain0725 [OP] New Member
    tires going on tomorrow are inch taller or more tomorrow. No room for taller tires
  4. May 6, 2021 at 7:35 PM
    blackoutt
    NWA
    OEM+
    The ball joints on SPC are just one big nut so they easily come off. They may even ship unassembled? The hardware doesn't fit upside down which is where the other guy got confused on the extra parts and why his upper ball joints were so sloppy lol. There's a pocket (to collect mud) on the top and the bottom has a slot for the star plate. Pretty neat really. Torque that sucker down with some red loctite for sure.
  5. May 6, 2021 at 7:37 PM
    Yeah, I forgot these are SPC's...
  6. May 6, 2021 at 7:51 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    If you don’t want to use spacers then get new wheels with the proper offset. You’re achieving the same end result. Or don’t put on bigger tires.
  7. May 6, 2021 at 8:20 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    The problem doesn't appear to be with your UCAs or alignment, it just looks like your wheels have too much positive offset for your setup.
    If you want to run a lift and UCAs and bigger tires then wheel offset will need to be a factor in everything fitting correctly.
    If you don't want to run spacers that's your call, but if you had no intention of running +18 or +25 offset wheels then you can expect some rubbing on the UCA.
    406Michael likes this.
  8. May 6, 2021 at 8:32 PM
    cain0725
    so if i go with some say method wheels and plus 25 offset , this will correct my issue? what backspacing would i need?
    JimboSlice413 likes this.
  9. May 6, 2021 at 8:32 PM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Why don't you want to use spacers? I'm running 1" spacers with SPC UCAs on 285/65/20s with plenty of room.
    Black Wolf likes this.
  10. May 6, 2021 at 8:37 PM
    cain0725
    1- dont want my wheels sticking out a mile.
    2. local shop that says they are a weak point and not good for long term durability.
    3. The whole reason i bought what i did was trying to do things right. Spend once , cry once as others have said.
    4. I will buy wheels if it will fix problem or return to stock.
  11. May 6, 2021 at 8:38 PM
    cain0725
    i will call toytec tomorrow as well.
  12. May 6, 2021 at 8:38 PM
    cain0725
    and take back to shop
  13. May 6, 2021 at 8:38 PM
    cain0725
    and wonder why they didnt notice this
  14. May 6, 2021 at 8:44 PM
    bigblue14
    Craig
    1" spacers will not make your wheels stick out by a mile. I don't like that look either. Picture attached.
    I understand you're upset but don't get too upset about this. It's a solvable problem. If this was a 350 truck I would agree that you don't want spacers. I don't have issues with them on these trucks. If you're considering new wheels anyway - go that route.
    You're still in the buy once cry once phase. This is part of the deal.
  15. May 6, 2021 at 8:46 PM
    cain0725
    so anyone know what offset abd backspace will stick out the most?
  16. May 6, 2021 at 8:47 PM
    cain0725
    and mean least? , i dont want rocks and dirt thrown up the side of my truck
  17. May 6, 2021 at 8:48 PM
    cain0725
    thanks for evryones help
  18. May 6, 2021 at 8:48 PM
    OnespeedTRD
    Don
    San Diego
    No need to call anyone or take it back to the shop. Your suspension is done right. Your problem lies with your wheel/tire choice.
    Even on stock suspension, if you put wider/taller tires on stock wheels you'll run into issues with rubbing, which is why folks do lifts and different wheels.
    To address your concerns:
    1. Your wheels will stick out about the same whether you go with a +25 wheel or a 1" - 1 1/4" spacer. Stock is +60 - +25 = 35mm difference. Stock at +60 - 1" (25.4mm) = 34.6mm. Stock at +60 - 1 1/4" (31.75mm) = 28.25.
    2. The debate on wheel spacers is a huge one, but if you stick with BORA or Spidertrax you'll be fine. Plenty of folks running them with zero issues. Properly installed they are no more or less weak than your wheel or hub.
    3. Doing things right is a good path, but you have to complete the equation, which includes the right wheel offset for the tire size you're wanting to go with.
    4. Wheels with the correct offset, or spacers to create the same offset on your stock wheels, should get you the clearance you need for the tire size you're installing.
  19. May 6, 2021 at 8:49 PM
    #49
    18" TRD Off Road Wheels
    The lower the offset number the further out it will stick. Your stock wheels would be +50 or +60 IIRC. A +25 wheel will poke out a little, where as anything +0 or even in the negatives will push the wheels out further.
    Keep in mind, using spacers or offset to push the wheels out may result in some rubbing on the front air dam or the mud flaps. That will depend heavily on your tire size, too.
  20. May 6, 2021 at 8:50 PM
    #50
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I would swap the wheels. I don't see this as the shops fault, they installed what was purchased. You're not the first person to run into issues changing the uppers with stock wheels. Methods come with a 0 or +25 I believe. Check the forum for pics but I prefer the +25, they'll stick out a little but not an obnoxious amount.
  21. May 6, 2021 at 8:53 PM
    #51
    Moving the wheels out to accommodate what you have is going to expose you to more debris. Just the way it works when you start moving a vehicle outside of it's stock specifications and equipment. You could add flares to protect the sides etc., but that adds the issue of paint wear under the flares. As the saying goes "You gotta pay to play."
  22. May 6, 2021 at 8:54 PM
    #52
    cain0725
    they ordered the dang tires, and said it would all fit, put i like 17 inch wheels with more tread, heard it helps with the ride. so maybe that is the solution, so plus 25 offset , what does backspace mean? Since i have change the suspension, stock charts wont work online to see what fits.
  23. May 6, 2021 at 8:56 PM
    #53
    cain0725
    also would going down on my 6112 help with this at all? Say to the 1.9 setting?
  24. May 6, 2021 at 9:14 PM
    #54
    Saltyhero13
    Saltyhero13 Throbbing Member
    A rare clip of @hagrid waving to a young disciple, sending him off to the transmission cooler sweat shop...
    ...the disciple was me. I never recovered from our separation.
    Black Wolf[QUOTED] and hagrid like this.
  25. May 6, 2021 at 9:16 PM
    #55
    OnespeedTRD
    Don
    San Diego
    Before you do anything else I'd take it to the tire shop and have them install one tire and test fit. You never know, it may fit just fine and you'll be done. I wouldn't spend anymore money or change anything until you at least do a test fit with what you have.
    If you're going with a 1" taller tire, only half of that will be above the centerline of the wheel, and it looks like you have some room there.
  26. May 6, 2021 at 9:18 PM
    #56
    cain0725
    ok, well thats good, its the same place. They are huge shop and only do lifts and tires. Surely they will figure something out!
  27. May 7, 2021 at 6:40 AM
    #57
    cain0725
    here we go at the shop, there mounting one front tire.
  28. May 7, 2021 at 8:26 AM
    #58
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Well?? It fit??
  29. May 7, 2021 at 8:33 AM
    #59
    cain0725
    called toytec, they had shop push the ball joint position out and change bottom control arm , then align. Have 1/2 clearance now. All is good. No rubbing anywhere. whew!
  30. May 7, 2021 at 8:33 AM
    #60
    cain0725
    thanks everyone!
