Spacers - Maybe
Discussion in 'Wheels & Tires' started by zlaneb, Dec 14, 2016.
  1. Jan 6, 2017 at 10:43 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I don't have my truck in front of me but I believe the screws to move the liner forward is underneath. I don't think you sheared those off. You probably sheared off the screws that hold the liner in on the side.
  2. Jan 6, 2017 at 11:06 AM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    You're right. Those screws are under the bottom of the liner in the bottom of the front bumper.
    @zlaneb a level on the front definitely wouldn't hurt your cause. And as for the heat gun, I've heard the same stuff that it would help. So giving that a try probably wouldn't hurt either.
  3. Jan 6, 2017 at 5:09 PM
    zlaneb
    zlaneb [OP] New Member
    Austin, TX
    @Zharris - The 17 model may be different. Too damn cold to play with it tonight, but see pic for an annotated view. IMG_6673.jpg
  4. Jan 6, 2017 at 5:42 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I moved my liner on my 16 almost 1". Check my build thread I have pics of it in there.
  5. Jan 10, 2017 at 7:19 AM
    zlaneb
    Austin, TX
    Update - I moved my liner forward like you guys recommended. It was a total of 10 minutes and it is providing me the clearance I need.
    To move them forward you remove 4 10MM screws that are on the edge of the liner and 2 12MM bolts on the bottom. Then gently fold the liner into the bumper and reuse the screws and original holes. For me, I couldn't get all 4 10MM back into the liner, however once it warms up, I will try again, b/c the liner will be more moldable.
    joonbug likes this.
  6. Jan 10, 2017 at 9:54 AM
    Zharris
    Zharris Merica!
    Glad it worked man. It was snowing and I didn't want to go out in the snow to check my truck. I was feeding some misinformation on the screws. Haha 16 and 17 are the same looking at your picture.
