So I heard you guys like 40s on 17s..
Discussion in 'Wheels & Tires' started by Spvrtan, May 3, 2017.
  1. May 5, 2017 at 8:59 PM
    #91
    I have always enjoyed Alex's build as well. I was pretty happy to see him sign up on Tundras.com and then 16 posts later....DAMMIT!!! LOL
    The desert guys have a totally different wheeling experience than I do when it comes to setups. Seeing @dragos28 rig in person was pretty cool and I would enjoy it a lot. I can't get enough when it comes to speed and challenge.
    I would never go back after having beadlocks, and I don't run low pressures since I run race compound tires (15-20 psi, compared to some that go 7-12 psi). To many benefits.
  2. May 9, 2017 at 2:20 PM
    #92
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    40s performed well on another mild trail in Utah this time. There are a few new rub spots (where I used temporary spray paint to see points of contact) that I need to cut/hammer but overall it's performing well..
  3. May 9, 2017 at 2:22 PM
    #93
    n2deep
    n2deep Pavement Princess
    Now you're in my backyard. Did you get a chance to flex much cause there isn't much flexing on that road.
    dcsleeper408 likes this.
  4. May 9, 2017 at 2:42 PM
    #94
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Only spots I remember getting any flex was the little spots right at the falls after u got down the hill. Still a nice little drive though
  5. May 9, 2017 at 2:55 PM
    #95
    n2deep
    Or if you climb some of the side trails going up the mountain
  6. May 9, 2017 at 11:29 PM
    #96
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Aside from some tie-rods what steering upgrades exist for a Tundra?
  7. May 10, 2017 at 4:27 AM
    #97
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    What are you looking for? Like a new rack? You would have to go full custom for a new rack
  8. May 10, 2017 at 9:02 AM
    #98
    computeruser6
    Dirk
    Escondido
    Spvrtan mentioned steering upgrades earlier but I had never heard or seen of any real upgrades for the Tundra. I'm sticking with 34" tires anyway. I wonder what the limits of the stock rack is though.
  9. May 10, 2017 at 9:14 AM
    #99
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I know guys that have considered custom racks. Especially guys with bracket lifts since they tend to blow the stock rack.
  10. May 15, 2017 at 11:06 AM
    #100
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    Im an expert with steering systems on these trucks and considering Ive replaced 5 racks in 3.5 years with this truck running 37's on a BDS kit .... here is the short version... (i did this first and it didnt solve anything) you can get new upgraded tie rods and rack bushings, but that is not what will fail first on our racks... its the internal seals that will fail the larger tires put too much back pressure on the inner seals and blow them.. so only option is a custom steering rack which if you talk to Howe racing, the premier racing rack company who is 5 minutes from my house and i have showed him my truck and talked with the owner about a custom bolt in solution its 3500-5000$ for a steering setup to support 37's or larger to fit in the limited space not to mention custom tie rods and other stuff to support the custom pump and rack.
    additionally the BDS spindles have a screwed up geometry and adds pressure to the rack which is why BDS guys like my self had a higher rate of failure on racks. Which ultimately led me to my perm fix... i ditched BDS and Im going Long travel.. i know for a fact long travel hasnt caused rack failures even running 37's .. so there you go
    Luckydog, Lindenwood, equin and 2 others like this.
  11. May 15, 2017 at 11:24 AM
    #101
    Spvrtan
    Kris
    San Diego, CA
    From when I researched the issue across the multiple Tundra-based online communities, it seems the people with the BDS kit and getting a broken rack because of it had at least one of the following (if not both) issues..
    1. Cranking the lift too high. Yea, it says it's a 7" lift but that's on the extreme end and obviously puts the axles and rods at risky daily angles. I've been running my BDS kit at 6"
    2. Using the stock rod ends. As you said, the BDS spindles put the tie rods at an awkward angle. I knew that early on and upgraded to Coachbuilder's rod ends that allow for more degrees of motion and raise the ends up a bit from the spindle.
    Other things I considered are tire weight and PSI (affects ground friction), which would mean more resistance for the steering rack to fight and move around. I tried to stay with the lowest weights possible when going to 40s. Right now I'm at ~121lbs per corner. I could probably shave off ~5lbs if I had the money and went for forged wheels but that's a dream for now. I also keep my pressure as high as safely possible for daily usage so that there's less rubber contacting pavement.
    Maybe I'm just lucky but I haven't had any issues with my rack and I'm at 50k miles now (over 2.5 years). I've been running 37s since about 3k when I put my BDS lift on. I still have yet to upgrade my rack's bushings but will do that soon.
    Lindenwood likes this.
  12. May 15, 2017 at 11:39 AM
    #102
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    I had steering limit plates welded on to prevent oversteering and i was ruinning my BDS kit at 5"ish not the full 7 and running 37's for a while and also had CB tie rods as well and still blew 2 racks on that setup... its gonna happen eventually you have gotten lucky thus far give it time it will blow.
  13. May 15, 2017 at 11:46 AM
    #103
    n2deep
    Well
    @papasmurf now that you're going LT you shouldn't have any issues. Blew 3 racks on MT and my 4th rack hasn't had an issue since I went to LT. No steering stops and no problems.
    Good choice to upgrade to a real suspension. :p
    papasmurf and osidepunker like this.
  14. May 15, 2017 at 11:48 AM
    #104
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Exactly..... im happy with my choice! LOL
  15. Nov 25, 2018 at 5:27 AM
    #105
    Lindenwood
    Lindenwood New Member
    2002 and 2016 4Runners, Selling 2002 for a Tundra
    2002 4Runner: Custom full rmor, 33 MTs, Fridge, drawers, OBA, flat paint (for easy touch-ups). 2016 4Runner TRDP: Wheels, 32 ATs, 2" Lift F/R
    I would also imagine the high-speed style of offroading you say you do most often is a lot harder on the rack than the slower speed stuff that @Spvrtan seems to mostly do.
    I know I didnt have steering rack issues on my 4Runner until a few times going over rough terrain a bit faster than I really meant to--and i could definitely feel the steering wheel jerking back and forth.
    Thanks for the info and anecdotes, to everyone!
    Rica25 likes this.
  16. Nov 25, 2018 at 9:37 AM
    #106
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Nope I didn’t run fast when I had the BDS and had three rack failures w the BDS since going long travel and stock spindles I haven’t had a rack failure in 40k miles. The bad steering geometry in BDS spindles puts extra stress on the rack causing premature failures. Also most of my wheeling was slow stuff a few years ago. So driving habits have nothing to do with it. And actually the high speed stuff is easier on the steering components because you are going straight when you do slow crawling the high steering angles combined w large tires and torque on the wheels from rocks etc cause extra stress on steering. I mostly blame the BDS gen 1 lift I had less issues when I replaced the spindles w their gen 2 spindles which corrected some of the steering angle problems
  17. Sep 19, 2019 at 8:15 AM
    #107
    Overlandcrawler
    Overlandcrawler New Member
    First gen tundra
    Tons,40s,linked,atlas4,shortened
    Big fan of 40’s myself.
    First post! Hello everyone
    equin, JDL17CM4x4, saybng and 17 others like this.
  18. Sep 19, 2019 at 8:19 AM
    #108
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Lightweights...
    equin, Rica25, BigTimeBolo and 3 others like this.
  19. Sep 19, 2019 at 8:22 AM
    #109
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    nice truck, would love to see the front setup
    jewsNbrews and joonbug like this.
  20. Sep 19, 2019 at 10:45 AM
    #110
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah that thing is dope, moar pics and mod lists please!
    Also, definitely going to need to see some video of that thing in action
    Rica25, jewsNbrews and Pinay like this.
  21. Sep 19, 2019 at 10:47 AM
    #111
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    He's a tease! :mad: First post, one pic and gone. :frusty:
  22. Sep 19, 2019 at 11:19 AM
    #112
    Overlandcrawler
    First gen tundra
    Sorry fellas working on a water leak. It’s a fresh build and currently have the atlas back at advanced getting tweaked
    osidepunker, equin, Rica25 and 5 others like this.
  23. Sep 19, 2019 at 11:22 AM
    #113
    Overlandcrawler
    First gen tundra
    I wonder if one could run an old pre-Tacoma steering box in a current tundra with ifs and add hydro assist? Like the early 90’s trucks
    Rica25 and Pinay like this.
  24. Sep 19, 2019 at 11:26 AM
    #114
    Overlandcrawler
    First gen tundra
  25. Sep 19, 2019 at 11:34 AM
    #115
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Where you located??
    Rica25 and jewsNbrews like this.
  26. Sep 19, 2019 at 11:35 AM
    #116
    Overlandcrawler
    First gen tundra
    Old ifs up top here taped for Psc hydro.
  27. Sep 19, 2019 at 11:37 AM
    #117
    Justincase76
    Justincase76 New Member
    Justin
    Mount Julio, TN
    2016 Tundra
    a lot
  28. Sep 19, 2019 at 11:39 AM
    #118
    Overlandcrawler
    First gen tundra
    In southern Nevada. About a mile from the logandale trails. Hope to have this thing back together for the hump and bump at the beginning of Nov. Would love to meet some of you tundra guys there
    jewsNbrews likes this.
  29. Sep 19, 2019 at 11:42 AM
    #119
    Overlandcrawler
    First gen tundra
    Haha I’m sorry sprvtan! I thought this was a thread on 40’s and tundras. Big fan of you sprvtan and have been following ya on YouTube for a while now. Wish I could have started with a platform like yours
    equin, Rica25 and jewsNbrews like this.
  30. Sep 19, 2019 at 11:43 AM
    #120
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Interesting thought. What would be the benefit or what problem does it solve? Just finding a way around the steering rack failures or trying to adjust the amount of steer angle available?
