Small propane tanks
Discussion in 'Recovery & Gear' started by TheBeast, Mar 6, 2022.
  1. Sep 5, 2022 at 1:44 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    what hose is he using? something you have to cobble together or do they sell them like that?
  2. Sep 5, 2022 at 2:05 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  3. Sep 5, 2022 at 3:09 PM
    SAGE63
    San Diego County
  4. Sep 19, 2022 at 4:09 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Kind of. You can equalize the pressures without actually filling the empty tank ,though. There's more to it. If he had both tanks upright the pressure would equalize, but with gas, not liquid and the tank wouldn't be useful. Also, if you don't open the valve and let out the gas at the top of the empty tank, the pressures will equalize without filling the tank to any significant extent.
  5. Sep 20, 2022 at 7:15 AM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    Correct, I use to flip tanks over and stand up to fill others
  6. Oct 15, 2022 at 9:06 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Been a while since I’ve filled smaller tanks off a 20# one. Like since before OPD valves….
    Will a modern 20# tank with OPD valve flow LP when inverted?
    I’ve got a 5# bottle, but just stop and have it topped off at the feed store when needed…. I make sure I’m buying other stuff since it’s about a $3 fill.
  7. Feb 26, 2023 at 9:51 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
