Shudder in 4WD HI
Discussion in '2.5 Gen Tundras (2014-2021)' started by zeke7681, Nov 16, 2018.
  1. Nov 29, 2018 at 5:44 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Yup, exactly.
  2. Nov 29, 2018 at 5:54 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Hehe sorry for the troll. I think mine does it. I only use when I need it. In heavy snow or mud
    r1-superstar[QUOTED] likes this.
  3. Nov 29, 2018 at 6:03 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Can't speak to your other vehicles, but I would fully expect to get some shudder on wet pavement while turning in 4WD. It's normal, but not good. I'd avoid using 4WD on non-slip surfaces, Tundra or any other 4WD vehicle.
    OR18TRD likes this.
  4. Nov 29, 2018 at 6:31 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You shouldn’t be in 4WD on any pavement unless it’s covered in ice or with like 3” of snow. There isn’t enough slippage on pavement that’s just wet with water.
    OR18TRD and r1-superstar[QUOTED] like this.
  5. Nov 29, 2018 at 6:37 PM
    PA452
    PA452 New Member
    Agreed.
    joonbug[QUOTED] likes this.
  6. Nov 29, 2018 at 6:59 PM
    r1-superstar
    DB
    UTAH
    Thank you for this. :cheers:
  7. Nov 29, 2018 at 7:11 PM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    So, no gravel roads or dirt roads either?
  8. Nov 29, 2018 at 8:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Gravel and dirt is ok.
    Ronin73[QUOTED] likes this.
  9. Nov 29, 2018 at 8:47 PM
    PA452
    PA452 New Member
    I'd say it depends on the gravel or dirt road. It's not always purely about the type of road. Is the dirt hard packed? Stone?
    The question is just does the surface provide enough opportunity to slip or not.
    Sometimes you get into a situation where you can't help but deal with some shudder, like if you're making a turn that you cannot make in 2WD. But IMO otherwise, if you're getting a shudder, you probably shouldn't be in 4WD.
    Ronin73[QUOTED] and landphil like this.
  10. Nov 30, 2018 at 3:54 AM
    Ronin73
    Ronin73 New Member
    Regular gravel road. I find it difficult to have a place to meet Toyota's recommendation to use the 4x4 once a month for a few miles. Unless it rains and I go on a dirt road for awhile, all I have is a regular gravel road.
  11. Nov 30, 2018 at 4:17 AM
    2014 Tundra Boy
    2014 Tundra Boy New Member
    2014 White Tundra TRD
    Let me chime in here if I may. I live off road and have a gravel road. I NEVER use 4wd UNLESS it is muddy or if there is 4-6 inches of snow. IMO there is no need for it unless the roads are muddy or have snow. BTW, I live a little under a mile off the beaten path with a mostly graveled road
  12. Nov 30, 2018 at 7:22 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    @Ronin73 isn’t saying he needs 4WD on gravel. He’s asking if it’s ok to use it on gravel to use the 4WD at least once a month as Toyota recommends. As long as the gravel is loose you should be fine. You can even do it on pavement as long as you’re going straight.
  13. Nov 30, 2018 at 9:02 AM
    2014 Tundra Boy
    Don’t see why you’d need it on a gravel road unless it’s more than several inches deep
