Shudder in 4WD HI
Discussion in '2.5 Gen Tundras (2014-2021)' started by zeke7681, Nov 16, 2018.
  1. Nov 16, 2018 at 7:15 AM
    zeke7681
    zeke7681 [OP] New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    We got about 7in of snow where I live, so I drove to work in 4 wheel high. I noticed a slight shudder when backing up into the parking spot. Is this slight to moderate shudder normal while in 4wheel high while backing up (2018 crewmax) ?
    NjPro likes this.
  2. Nov 16, 2018 at 7:32 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Where was the shudder feeling coming from ? Did you have your steering turned close to full lock ?
    15whtrd likes this.
  3. Nov 16, 2018 at 7:35 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    This is when mine happens in the dirt. Is it normal?
    NjPro[QUOTED] likes this.
  4. Nov 16, 2018 at 7:35 AM
    zeke7681
    Zeke
    PA
    yeah the wheel was turned not sure about full lock though. Now that I think about it, I used reverse earlier in a straight line and no shudder.
  5. Nov 16, 2018 at 7:37 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    If your in 4wd and turn the steering to full lock or close, yes it is normal. Try sweeping turns if possible and not hard turns.
  6. Nov 16, 2018 at 7:38 AM
    zeke7681
    Zeke
    PA
    Thanks, I was scared something was messed up with my new truck
  7. Nov 16, 2018 at 7:38 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    That is the most logical answer than.
  8. Nov 16, 2018 at 7:46 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Yep hard turns they like lock up. Be easy on turning. Unless your doing donuts :burnrubber:
  9. Nov 16, 2018 at 8:38 AM
    zeke7681
    Zeke
    PA
    Thanks!
  10. Nov 16, 2018 at 8:44 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s because you were turning. As long as the ground is slippery it should not be an issue. When I off road and I am using 4 x 4, I will turn off 4 x 4 if I have to make a very tight turns and 4 x 4 is unnecessary.
    NewImprovedRon likes this.
  11. Nov 16, 2018 at 9:08 AM
    TheBeast The Beach
    yes..happens on all 4x4...one wheel try to catch up with the other at close to full lock
  12. Nov 16, 2018 at 12:19 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    If your turning hard on dry or just wet toad in 4x4 your gonna have a bad time
    15whtrd likes this.
  13. Nov 16, 2018 at 1:41 PM
    15whtrd
    15whtrd Mr. Blonde
    4sallypat, joonbug, sdde4n and 4 others like this.
  14. Nov 16, 2018 at 7:42 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Was the parking lot snow-covered?
  15. Nov 16, 2018 at 9:41 PM
    zeke7681
    Zeke
    PA
    yes
  16. Nov 17, 2018 at 7:27 AM
    EIRE1916
    EIRE1916 New Member
    I have the exact same issue my truck is brand new 2000 miles and exact same circumstances
    One of the guys here said just put it into 2WD just for the tight turns or parking spots
    It’s normal from what I hear which is a relief to me too
    zeke7681[OP] likes this.
  17. Nov 18, 2018 at 8:37 AM
    r1-superstar
    DB
    UTAH
    Thanks!
  18. Nov 18, 2018 at 9:14 AM
    NjPro
    NjPro New Member
    Tom
    Nj
  19. Nov 18, 2018 at 9:41 AM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    This is what happens when you turn full lock in 4WD and off-roading in technical terrain like this guy did.
    https://youtu.be/4q7GUN2CXlU
    4sallypat, joonbug and 15whtrd like this.
  20. Nov 18, 2018 at 7:19 PM
    PA452
    PA452 New Member
    What a dope. I just skipped to the end when it happened. I don't know how you can know enough to know what any of those parts are called, but not know you shouldn't be in 4WD driving on terrain like that.
    14burrito and Alexstundra like this.
  21. Nov 18, 2018 at 7:23 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    I know he makes a lot of videos and has nice parts and breaks them a lot knows a lot... he learns the hard way. I think the same thing but at same time stuff breaks he figures it out and has fun
  22. Nov 19, 2018 at 6:13 AM
    15whtrd
    15whtrd Mr. Blonde
    I would think you want to be in four-wheel-drive for the terrain he was on, just need to turn it off when turning. No?
    Matty4wd likes this.
  23. Nov 19, 2018 at 6:32 AM
    PA452
    PA452 New Member
    What I saw in that video, there was absolutely no need for 4WD coming down that hill, turn or no turn.
    Black Wolf, OR18TRD and Alexstundra like this.
  24. Nov 19, 2018 at 8:59 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    I agree. He def learned that day lol. Maybe that’ll help some other newbies use 4wd as little as possible
  25. Nov 19, 2018 at 9:04 AM
    TheBeast The Beach
    he has good videos, break stuff and fix/install most of them. He is just trying to have fun imo. plus he has long travel, that is even more work when shit breaks.
    Black Wolf, YTThao530 and 15whtrd like this.
  26. Nov 29, 2018 at 4:37 PM
    r1-superstar
    DB
    UTAH
    So this is continuing to happen in 4HI on the slightest of slow turns (1-8pmh). I'm turning the steering wheel one full rotation so not even close to full lock. Still normal?
  27. Nov 29, 2018 at 4:46 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    If your in dirt, snow or wet conditions I don’t think this is normal. Maybe it would bind on a dry road with 1 full turn of the wheel.
    Full disclosure, I AM NOT A MECHANIC.
    Other memebers will have insight as well. Your truck is brand and under warranty, bring it to the dealer if you have any doubts.
  28. Nov 29, 2018 at 4:48 PM
    PA452
    PA452 New Member
    On what kind of surface? Dry pavement? Wouldn't surprise me at all. Wet pavement? Still wouldn't surprise me.
  29. Nov 29, 2018 at 5:15 PM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    He was driving on a road covered in construction paper :burnrubber:
    NjPro likes this.
  30. Nov 29, 2018 at 5:42 PM
    r1-superstar
    DB
    UTAH
    Wet pavement. Driving through the neighborhood (up to 15mph). I'm asking since this is my first Tundra. However this didn't happen on my 03' 4WD Sequoia or 00' 4WD 4-Runner.
