Should I trade my 2018 Tundra in on a new one? help me decide.
Discussion in '3rd Gen Tundras (2022+)' started by borla123, Nov 29, 2021.
  1. Dec 13, 2021 at 1:53 PM
    #121
    Kentuckytundra
    Kentuckytundra I love spam calls, we talk for hours
    Axle ratios don't matter because of transmissions? News to me. I am biased to reliability, which is why I chose the 21.
    This is the first toyota I've ever owned, been a ford guy and still own my 3/4 ton. There's aspects of the new tundra I wish the 21's had, like crawl control. But I'm not a fan of making a truck have a smaller engine and forcing it to work harder through forced induction. I'd rather have a bigger engine with a power adder.
    As far as payload, look at the sticker in the door of a new 22 model and let me know how much more it is than the 21's, with its smaller gas tank.
  2. Dec 13, 2021 at 1:56 PM
    #122
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Comparing their mileage in the 5.7 to the ttv6 the ttv6 wins, sticking by this until someone proves it otherwise. The ford they said constantly was high revving and in boost, the tundra stayed calm, cool, and low rpm's out of boost.
    Breathing Borla likes this.
  3. Dec 13, 2021 at 1:57 PM
    #123
    Kentuckytundra
    That's cool man, maybe it will be the best engine ever made and get way better milage than the ecoboost while being more powerful and more reliable. I hope so. Doubt it.
  4. Dec 13, 2021 at 2:01 PM
    #124
    Breathing Borla
    Northern Illinois
    yes, there is a lot more than looking at the rear end, there is a transmission between the engine and the rear end, it makes a huge difference having 10 gears, vs 6 gears and impacts the overall final drive ratio.
    and then if you watch the ike gauntly TFL just did, the ttv6 seamed to not work nearly as hard as the larger v8 since its forced induction. MPG for all of them towing is shit, thats not the point, the point is it gives you power for those tows, then when unloaded gets much better mileage.
    most models are 200-400 pounds more payload for 2022 and the smaller tank is smaller but the range is the same or better in most, not all, circumstances since the efficiency is much better.
    Im not knocking your 2021, I have a 2016, but there is no reason to believe that the new truck won't eb as reliable at this point, Toyota has been making reliable turbos forever.
  5. Dec 13, 2021 at 2:02 PM
    #125
    Breathing Borla
    Northern Illinois
    tundra has way lower torque peak than ford, 2400 rpm, huge difference !
  6. Dec 13, 2021 at 2:04 PM
    #126
    Kentuckytundra
    You believe what you'd like, I have no qualms with that. I'll go with my opinion. I'll take tried and true over what essentially amounts to hoping the new engine will be as reliable. Like I said I keep my trucks for the long haul so proven track record trumps hope everytime.
  7. Dec 13, 2021 at 2:08 PM
    #127
    Breathing Borla
    Northern Illinois
    nothing wrong with that, I still have my 2016.
    but I was more addressing hauling, towing, and gearing aspect of your post to clear up some misinformation.
    no worries
  8. Dec 13, 2021 at 2:14 PM
    #128
    Kentuckytundra
    Misinformation about what? Gearing does in fact matter, 3.31 is not as good for low end torque. Neither is an engine that relies on boost to build for torque. Payload and hauling capacity is ambiguously defined, its fairly commonly known that heavy duty vehicles use leaf springs over coils. Not every aspect of the new Gen is better for hauling or payloads. Factually some of the changes aren't actually "better".
    Like I said, look at the sticker on the door.
  9. Dec 13, 2021 at 2:18 PM
    #129
    Breathing Borla
    Northern Illinois
    never mind man, it doesnt matter
    DexterL likes this.
  10. Dec 13, 2021 at 2:19 PM
    #130
    Kentuckytundra
    I get it, guys are excited about the new generation. But not everything Toyota changed was good for a truck. Pretty obvious.
  11. Dec 13, 2021 at 2:36 PM
    #131
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    2022 Tundra 1794 listed at my dealership with 1820lbs of payload! This is on their site as the vehicle is incoming. But, if this is true this is epic and the highest payload of any Tundra I’ve seen. :fingerscrossed:
    Mattedfred likes this.
  12. Dec 13, 2021 at 2:40 PM
    #132
    Kentuckytundra
    That would be a good increase! Typically 2wd non offroad trucks have higher payloads.
  13. Dec 13, 2021 at 2:47 PM
    #133
    UATundra
    UATundra New Member
    Is it 4WD?
    If so I'd put that at about a 0% chance from what I've seen.....and I hope I'm completely wrong and that is what it comes in at, because I'll buy it.
    If all the 4WD SR5's I'm seeing are coming in actually in the 1,350-1,400 lb range there's no way a loaded 1794 has 1,820 lbs unless they are using a complete different suspension and drivetrain for the higher end models. My guess is 1,400 lbs or less and I honestly hope I'm proven wrong.......
    I'd really be surprised if it's that high in a 2WD, but maybe?
  14. Dec 13, 2021 at 2:50 PM
    #134
    Malinois38
    Pa.
    It is 4x4 btw. I would agree that is has to be a typo…
    1UP likes this.
  15. Dec 13, 2021 at 2:54 PM
    #135
    UATundra
    UATundra New Member
    I sure hope it isn't, but I'm going to remain slightly pessimistic on this.
    Are you going to look at the truck when it arrives? I'd love to know if this is actually the case.
    I just looked at a Platinum that's coming in at one of our local dealers and they list it as "base" curb weight, so that's before options. On the one you posted they just call it curb weight. Interesting.
  16. Dec 13, 2021 at 3:01 PM
    #136
    Breathing Borla
    Northern Illinois
    max payload on toyota spec website is 1665 for that model, thats before any options or accessories, like off-road package or HUD, etc/
    its likely around 1400 ish real world, which is still more than the 1100 or so in most last gen 1794, platinums.
    they have the GVWR, curb weight, and payload calc wrong
    According to their numbers it would be GVWR 7780- curb weight 5490 = 2290 lbs payload
    GVWR on toyota site is 7285, curb wieght 5620
    7285-5620 = 1,665 payload before options and accessory
    thats 1794 CC 5.5 bed 4x4
    1UP likes this.
  17. Dec 13, 2021 at 4:11 PM
    #137
    borla123
    borla123 [OP] The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    That dealer info shows a turning radius of 24.3 feet on the 2022 Tundra.
    The turning radius on the 2021 Tundra is only 22 feet. See attached.
    Is that 2.3 feet a big deal ? Would it be noticeable on tight trail turns (90 degrees) where the trees and rock walls, are close on each side ? I mean its really tight right now where I go as it is.
  18. Dec 14, 2021 at 5:49 AM
    #138
    borla123
    Ontario
    Bed Size for Hauling Items - Depth and Width. 2022 on left 2021 on right.
    Inside Bed Depth 2022 - 20.9 inches 2021 - 22.2 inches
    Inside Bed Width (total/between wheel wells) 2022 - 58.7/48.7 inches 2021 - 66.4/50.0 inches
    If anyone thinks a matter of inches is nothing - then you have not tried to cram stuff into a pickup bed under a tonneau cover.
    Someone I know used to work for Enterprise Rental. He could drive whatever vehicles were left on the lot home for his use at end of the day.
    I got to see and drive mostly Rams and F150's . I used to joke with him about how shallow the bed in the Ram is.
    I could touch the bottom of the bed from the outside.
    That is not possible on my 2018 Tundra due to the increased depth.
    FlyingWolfe likes this.
  19. Dec 14, 2021 at 8:49 AM
    #139
    DexterL
    DexterL New Member
    1.3in of depth is really nothing, the width I am slightly worried about
  20. Dec 14, 2021 at 9:09 AM
    #140
    Dtronic
    Dtronic New Member
    Orlando
    2019 F-350, 2020 Jeep Rubicon UL, 2021 Dodge Ram, 2021 Hyundai Sonata N-Line
    Dealership pages are not where I would get or quote information about ANY vehicle.
  21. Dec 14, 2021 at 9:29 AM
    #141
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Yep, it would be noticeable. It makes the 2022 shortbed take as much space to turn as my enormous beast.
  22. Dec 14, 2021 at 9:33 AM
    #142
    borla123
    Ontario
    Thank you for this information. I really appreciate it ..... and damn this is not good.
    Got the bedsize numbers from here. Should have posted the link.
    https://pickuptrucktalk.com/2021/10/is-the-2022-toyota-tundra-smaller-a-spec-by-spec-comparison/
    rruff[QUOTED] likes this.
  23. Dec 17, 2021 at 8:30 AM
    #143
    john1062
    john1062 New Member
    2022 Tundra
    This will have a payload of +/- 1300 lb. Real payload is about 400lb less than the posted ones. Big B/S from the Marketing Team
  24. Dec 17, 2021 at 9:53 AM
    #144
    borla123
    Ontario
    I don't know personally of any Tundra owners (a few) that pay attention to payload numbers. I have never given it a second thought. Load her up. The driving dynamics have never suffered.
    Toyota1234, OppoMojo and rruff like this.
  25. Dec 17, 2021 at 10:01 AM
    #145
    borla123
    Ontario
    The only reason this new truck has been an interest to me is because of what I can get $$$ as trade in on a new vehicle.
    But the more I look into this 2022 Tundra.....well lets wait till I actually see and drive it to speak more.
    My trade in is worth the same at the other brands. But the only two I would consider Tremor and Rebel seem to have bad consumer experiences.
    I don't want to take my boring pretty uneventful Tundra ownership - knock on wood so far - for granted.
    rruff likes this.
  26. Dec 17, 2021 at 10:33 AM
    #146
    rruff
    rruff New Member
    And have more issues than if you'd just loaded up the Tundra... :benchpress:
    Toyota1234 likes this.
  27. Dec 17, 2021 at 11:50 AM
    #147
    rruff
    rruff New Member
    That's expected. The Ford 3.5 Eco is only 2 mpg better than the old Tundra on Fuelly, while the EPA is 6 mpg better. I'd guess the manufacturers are tuning to optimize for the EPA test, but Toyota never did that on the old Tundra.
    Oey12 likes this.
  28. Dec 17, 2021 at 2:03 PM
    #148
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Honestly that thing probably idled a lot prior to purchase. And I noticed that is total mpg not tank average. When I first picked up my truck with 10 miles on it, it have an average of 8 mpg’s on that screen. Now after 10k my total average is 17.5. I think the new Tundra is going to get on par if not SLIGHTLY better than the 5th 4Runner which was about 20ish.
  29. Dec 17, 2021 at 3:38 PM
    #149
    rruff
    rruff New Member
    That's an anecdote. Speed and wind can make a huge difference. Plus, in the first 1,000 miles on my truck I was constantly cycling the throttle to break it in... not good for MPG.
    It'll be as good as the competition on average... which is good enough IMO.
    On another forum someone commented that Toyota has had so many years to make this redesign perfect, they should have nailed it. That's delusional. The Tundra is a low volume vehicle, and they have only so many $$$ they can afford to invest. Time is irrelevant, man-hrs are not. Ford and GM each sell ~7x as many trucks, so they can afford much bigger R&D budgets.
    The features and tech are never going to be class leading. Hopefully reliability still will be.
  30. Dec 17, 2021 at 3:40 PM
    #150
    Oey12
    Oey12 New Member
    Joey
    New York
    :101010:
