Shock Tuning
Discussion in 'Long Travel Suspension' started by osidepunker, Nov 18, 2019.
  1. Nov 19, 2019 at 9:02 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Higher spring rates can increase bouncy feeling. Do you have a heavy front bumper?
  2. Nov 19, 2019 at 9:02 AM
    osidepunker
    osidepunker [OP] OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    higher spring rates increase bounce, then you reduce the valving to get rid of the bounce.
    thats the point of tuning
  3. Nov 19, 2019 at 9:04 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Wouldn't reduced valving have less effect over the piston? Allowing more free movement?
  4. Nov 19, 2019 at 9:07 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    its not that simple. Depends on which shaft speed you are targeting. for bounces on the road, those are slow speed shaft movements and are controlled by the largest shims; the 1.8 and 1.6
    For whoops, jumps, and G outs those are controlled by the high speed shims, The 1.425 and smaller shims
    For road bounces after swapping springs, make the larger shims thinner. But you should have a flutter in there. So start with the face shim, then if need be adjust the 1.8 on the main stack
    chugs, ColoradoTJ and Hbjeff[QUOTED] like this.
  5. Nov 19, 2019 at 10:01 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    No, I don't have a heavy bumper, but I will at some point.
  6. Nov 19, 2019 at 11:57 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    :bananadead:
    831Tun, joonbug and Hbjeff like this.
  7. Nov 19, 2019 at 12:00 PM
    KevinK
    Tundras to Sedona
    I think the issue in referencing the shims as high and low speed is that it implies one isn't affected by the other, or that low speed shims aren't engaged during high speed events, or high speed shims aren't engaged in low speed events.
    it might be better to describe the largest shims as active on *every* shaft movement, and the high speed shims activated to their full motion in the highest speed shaft events.
    I'll let others carry on the argument over which action in a truck qualifies for high or low speed shaft movement.
  8. Nov 19, 2019 at 1:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Here we go again. :argue:
    SAGE63, KevinK[QUOTED] and 831Tun like this.
  9. Nov 19, 2019 at 5:03 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    This topic is great. Its just am not long travel and will never be most likely. Can help be directed towards us MT guys? I have Fox 2.5 dsc extended travel and it drove horrible when i went to mojave such a harsh ride even with stock ltx tires at 20 psi. I wont be speeding on trails. Just need it to handle much better then what it comes from fox factory. Need to make it back to NYC in one piece. And am not afraid to work on my own vehicles.
  10. Nov 19, 2019 at 5:19 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    but, but, why?
    thanks for this. i only played a little bit with my tubes over the summer. still need to put the new shim stacks (compression with flutter and rebound) in the coilovers.
  11. Nov 19, 2019 at 8:29 PM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Alex got a thorough ball washing today. This is why he still loves the forum. Lol.
    KevinK, osidepunker[OP] and jc153 like this.
  12. Nov 20, 2019 at 5:24 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    For bounces on the road, those are slow speed shaft movements and are controlled by the largest shims; the 1.8 and 1.6
    For small road and trail bounces make the larger shims thinner. Start with the face shim, then if need be adjust the 1.8 on the main stack
    If you want better bottom out control, increase the thickness of the smaller shims. The 1.425 is an "in-between" shim. Play with the number and thickness at your discretion. But I suggest sticking to the Fox recipe. So play with the numbers of large shims, making sure you dont have more 1.6 and 1.425 shims than 1.8. Dont mess with the numbers of 1.350 and smaller, adjust the thickness of them as a group. You basically have two choices for high speed, 1.350 and smaller make them all 0.015 shims or make them all 0.020 shims.
    So to reiterate, the 1.350 and smaller is one group. two variables, 15s or 20.
    The large shims 1.8, 1.6, 1.425 are a second group. Two variables, the thickness and the number. The larger the shim, the smaller the bumps it affects.
    Dont forget about the flutter, its a very important factor.
    Kevin, you should stop thinking of ways to argue with me about this and start thinking about what Im saying so you can understand the concept.
    Yes, tuning a MT truck is exactly the same as tuning a LT truck. You just have to understand that your suspension travel is less. So the "whoops" you would tune for will be much smaller. and the "jumps" and "G-outs" are going to be smaller as well.
    Most guys dont care to try to tune an MT truck, but I can help you. The first step is to open up your shocks and tell me what stacks you have in there and then together we can see if there is room for improvement
    reywcms and KevinK[QUOTED] like this.
  13. Nov 20, 2019 at 6:47 AM
    Civiceg94
    NYC
    Good thing i saved the old shocks. Would the stacks have the specs stamped on it ? And would calling fox have the information?
  14. Nov 20, 2019 at 6:54 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    no the best thing is buy a set of dial calipers and measure them yourself. There nothing like taking control of your own parts and knowing exactly what you have
  15. Nov 20, 2019 at 7:03 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Hey Alex, so I have the ADS triple bypass w/clickers in the rear and the knob adjustment dial in the front. The truck has turned into more of a daily driver now so my original plan is no longer in place. What I want from it now is just a nice, smooth ride. As it currently sits I feel every damn crack in the road. It just feels really stiff and it's not fun at all to drive. I'm not sure which tube(s) I need to adjust though to make it a softer ride.
  16. Nov 20, 2019 at 7:06 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    tubes can only do so much to help the street ride. I would start by opening the both tubes all the way and see how it feels. If that makes it smooth on the street, then we can work on how to find a balance between the street and dirt. but if it doesnt help you have to change your valving.
    For the front open the dial all the way and see if that helps. If not same as the rear we have to look at your valve stacks
  17. Nov 20, 2019 at 7:12 AM
    Sas
    OKC, OK
    Which ones though? I have three on the rear that I can adjust.
  18. Nov 20, 2019 at 7:14 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Sry, I assumed you knew about compression and rebound. So one tube should be labeled rebound and that controls when your wheel moves down. The other two tubes should be labeled compression and they controll when the wheel move up. Open all three all the way and then tell me if it gets smooth on the street.
    But dont forget to record your current position so you can return it!
    Starting from where they currently are, count how many turns it takes to fully close them. That will be your baseline. Then open them up all the way and report.
    Sunnier, Pinay and 831Tun like this.
  19. Nov 20, 2019 at 7:17 AM
    #49
    Sas
    OKC, OK
    Okay, thanks. And no, I don't know shit about how adjusting the tubes affects ride. I've been reluctant to do anything for fear of really screwing up the ride.
  20. Nov 20, 2019 at 7:43 AM
    #50
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    If you can install the suspension, you can rebuild/revalve shocks.
  21. Nov 20, 2019 at 8:13 AM
    #51
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Hey Alex, a list of tools might be helpful. I found it to be a bit of an investment. Lemme know if I miss anything.
    1) Shock body clamps/ soft jaws
    https://www.kartek.com/parts/king-fox-or-sway-a-way-30-shock-body-billet-aluminum-soft-jaws.html
    2) N2 tank and fill kit
    https://www.schmidtyracing.com/Uniweld-400PSI-Regulator-Kit-and-Whip-p/n-reg-uni400-8r-w.htm
    3) Dust cap tool
    https://www.kartek.com/parts/univer...per-cap-on-king-fox-or-sway-a-way-shocks.html
    4) Reservoir piston tool
    https://www.kartek.com/parts/all-ge...-depth-gauge-works-on-fox-or-king-shocks.html
    5) Bullet
    https://www.kartek.com/parts/fox-78...ls-from-tearing-when-you-rebuild-a-shock.html
    The above are examples only, not suggestions. Different tools for different size/ brand of shocks. Research required, batteries not included.
  22. Nov 20, 2019 at 8:32 AM
    #52
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Bro you bought bypasses and have never fucked with them?! Go to town! Sounds like your ride is already screwed up lol. Just screw the tube adjusters in and count how many turns they take and now you know where to reset them to. Bypasses work by flowing fluid around the piston in the zone that the tubes are mounted around. The tubes have a spring loaded check valve, by adjusting the screw you are adjusting how much that check valve can open. Since it's a check valve, it only allows flow in one direction. You can figure out the direction a tube works in by looking at the direction fluid can flow:
    Looking at this picture, you can imagine the check valve on either of these tubes pointed up. If fluid flowed in from the perpendicular welded tube it would press against the back side of the check valve and keep it sealed, if fluid flowed in from the bent side direction it would push against the check valve and flow OUT (into the body) from the perpendicular side. So if you picture the shock compressing (piston moving up) it's trying to displace fluid, and that fluid can go in the bent side and out the perpendicular side and flow into the "vacuum" behind the piston. Likewise if you pulled the shock apart (rebounded it) then you get a pressure build up underneath the piston and it tries to flow fluid into the perpendicular side, but obviously the check valve now seals up so that tube won't flow. That's why tubes are rebound/compression specific.
    So going back to what the tubes actually do, by adjusting the check valve you adjust the flow through the tube. So if you open up a tube completely then you are decreasing your damping since you are allowing lots of fluid to bypass (flow around) the piston. Likewise, taking it to the extreme, if you completely screw all your tubes in then your bypass tubes aren't doing anything and it's effectively a "normal" shock. This is also why a lot of times you see tubes that overlap the same section, tubes can only flow so much fluid (ie can only soften a zone so much). But on the flip side, the stiffest your shock can be is with no tubes in a zone. So you might have a really stiff shock, and a ton of tubes that overlap--all the overlapping tubes allow a lot of fluid to flow and soften the shock, but you still have super stiff valving for areas like the bump zone where you probably don't have any bypass tubes since you want it as stiff as possible.
    This is why Oside said to open all your tubes, every tube open will make the shock as soft as possible. If the ride is still ass then the bypass and your coilover still have too much valving going on, even with everything set as soft as possible.
    Hopes that helps a bit.
    TL;DR -- Open (unscrewing) a tube makes that section SOFTER.
    chugs, Sunnier, TRD15559 and 3 others like this.
  23. Nov 20, 2019 at 12:14 PM
    #53
    Sas
    OKC, OK
    Thanks gents, makes sense. I have all next week off so I'll dick around with it on Monday and see where it goes. I'm assuming turning the adjusters clockwise (if you're looking at the face of the adjuster) is closing them up?
  24. Nov 20, 2019 at 12:22 PM
    #54
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @osidepunker fix my shit.....
    :anonymous:
    oh wait i need to do my 3" leafs first :welder:
    Sunnier and osidepunker[OP] like this.
  25. Nov 20, 2019 at 5:21 PM
    #55
    Civiceg94
    NYC
    Gotcha i will do this. I found a video of me doing some fake prerunner stuff. The terrain was alright. But from your expertise maybe you could kinda tell whats it doing. And how i explain how the suspension felt in mojave. This is a great topic that will help people that are far from shops that tune and shipping would be expensive. I forgot to mention am on stock leafs for now until funds allow to buy new ones.
    https://www.instagram.com/p/BxXR-EXg94J/?igshid=hgj5p2eogimh
  26. Nov 20, 2019 at 7:05 PM
    #56
    Sas
    OKC, OK
    Image/Video isn't showing up for me.
  27. Nov 20, 2019 at 7:16 PM
    #57
    Civiceg94
    NYC
    Well that sucks. I tried uploading from my phone and it doesnt work.
  28. Nov 21, 2019 at 6:02 AM
    #58
    osidepunker
    Alex
    2013 Tundra DC 4x4
    haha no offense homie, but I dont see your suspension working. Need to get on some small whoops or terrain with more dips and rises
    joonbug and Civiceg94[QUOTED] like this.
  29. Nov 21, 2019 at 6:06 AM
    #59
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Some terrain like this would be a perfect testing area for an MT truck:
    https://youtu.be/kryrpTcDzKU
    Here is the best footage I have from when I was mid travel:
    https://youtu.be/_R7DUbned4w
    Sas likes this.
  30. Nov 21, 2019 at 6:07 AM
    #60
    Civiceg94
    NYC
    No offense taken this is on the east coast this as close i could get to lol Making the suspension work Ill try again in the future.
