Shm0 Tundra Build
Discussion in '2.5 Gen Builds (2014-2021)' started by jefroshm0, Dec 22, 2020.
  1. Mar 7, 2021 at 7:19 AM
    #61
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Do those fab pieces make you feel like you’re sitting back into your seat?
    jefroshm0[QUOTED][OP] likes this.
  2. Mar 7, 2021 at 2:01 PM
    #62
    jefroshm0
    jefroshm0 [OP] New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    A little . It makes your knees sit higher up. Takes back pressure off at an angle that does make you feel like your sitting back more.
  3. Mar 21, 2021 at 12:08 PM
    #63
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    Where did you get the switch adapter/ relocation harness? I can’t find it anywhere. Thanks
  4. Mar 21, 2021 at 12:36 PM
    #64
    jefroshm0
    Elk Grove, CA
    Got the relocation harness from
    https://accessorides.com/products/r...harness-for-toyota-tundra-2010-2017-plug-play
    the switch adapter for the center console comes from a guy I found on Facebook. He is also a member of the community but I don’t know his name. I can only give you his Facebook link. I used messenger and PayPal to handle the purchase.
    Hope this helps.
    Blkdmax[QUOTED] likes this.
  5. Mar 28, 2021 at 2:47 PM
    #65
    jefroshm0
    Elk Grove, CA
    Finally finished my last set of cable trimming on the rock lights. Installed all 8 with minimum cable mess under the truck. All together I cut away about 150 ft of cable from the system. Install with soldering and bracket making was about 3 hours. Another project on the build done.
    mav7021234 likes this.
  6. May 23, 2021 at 6:15 PM
    #66
    jefroshm0
    Elk Grove, CA
    Put these guys on. Some damage and rough edges but it’s a door handle.....who cares. Easy install on a 40$ part
  7. Jun 29, 2022 at 10:02 AM
    #67
    Kappes03
    Kappes03 New Member
    2014 Tundra 1794 1996 Toyota Hilux Surf
    Ran through your build and maybe missed it, curious where you mounted your switches. If you did that is.
    Thanks!
