Shellshock’s TRD PRO
Discussion in '2.5 Gen Builds (2014-2021)' started by shellshock, Apr 30, 2019.
  1. Jun 19, 2019 at 2:05 PM
    shellshock
    shellshock [OP] Guy who drives a lot
    Iowa
    2019 TRD PRO
    Added the inlays for the bedside
  2. Jun 19, 2019 at 2:06 PM
    shellshock
    Iowa
    2019 TRD PRO
    Icon RXT hopefully going on this weekend
  3. Jun 21, 2019 at 7:24 PM
    shellshock
    Iowa
    2019 TRD PRO
    Icon RXTs are installed! Definitely what this truck needed. Setup is dialed in now
  4. Jun 23, 2019 at 2:02 PM
    shellshock
    Iowa
    2019 TRD PRO
    I think we are sitting pretty good after approximately 500 miles. It drives noticeably different too. Highly recommended
  5. Jun 23, 2019 at 3:20 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    What option are you on?
  6. Jun 23, 2019 at 3:22 PM
    shellshock
    Iowa
    2019 TRD PRO
    2
  7. Jun 23, 2019 at 5:46 PM
    Porterpike
    Porterpike New Member
    Daniel Kruger
    2015 MGM Tundra Crew Cab
    I have a 2011 Tacoma and sold it for an older 4Runner. When we were looking a few months ago and test drive the Tacoma again it just seemed so small. Wife gave the blessing for the crew tundra and after two road trips so far I’ve not heard complaining from her about being cramped
  8. Jul 4, 2019 at 6:19 PM
    shellshock
    Iowa
    2019 TRD PRO
    Added some pinstripes today
    Also had to get creative to keep all the pieces attached and not left in Utah
  9. Jul 6, 2019 at 4:02 PM
    shellshock
    Iowa
    2019 TRD PRO
    Got my falkens on today.
  10. Jul 7, 2019 at 9:03 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Let us know how you like the Wildpeaks, thinking of those for when my stock Michelin's wear out (I like that they're snow rated). Are those the rokblokz flaps?
  11. Jul 7, 2019 at 9:08 AM
    shellshock
    Iowa
    2019 TRD PRO
    I’ve got a set on my Tacoma with 50,000+ miles on them and still have tread left. I won’t buy any other tires. They’ve been excellent in all conditions on and off road. Quiet. No loss in fuel economy.
    Yes. rokblokz. You can see the flex in the picture I posted. Factory ones would still be in Utah if I had left them on.
    jewsNbrews and Yzed608[QUOTED] like this.
  12. Jul 7, 2019 at 9:15 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Awesome, thanks!
  13. Jul 7, 2019 at 7:49 PM
    shellshock
    Iowa
    2019 TRD PRO
  14. Jul 8, 2019 at 10:15 AM
    tbell18
    tbell18 New Member
    Thomas Bell
    2019 Tundra TRD Pro
  15. Jul 10, 2019 at 1:52 PM
    shellshock
    Iowa
    2019 TRD PRO
    I've got a bunch of parts coming for the Tundra I need to get on before Rocky Mountain Overland Rally
    Rago ditch light bracket
    Rigid Dually SS pro
    SDHQ Behind the grille light bar bracket
    Rigid SR 40
    Switch pros 9100
    SDHQ battery terminals
    HAM radio, Group 27 battery and font camera also coming soon (once I order them)
  16. Jul 10, 2019 at 2:08 PM
    dradd
    dradd Sometimes there is just us
    City of Champyinz
    '17 TRD Pro
    pending...
    Very nice! Is there a particular reason you did not go with larger tires?
  17. Jul 10, 2019 at 3:17 PM
    shellshock
    Iowa
    2019 TRD PRO
    I thought about it but didn'ty want to make a jump to E range tires yet. I really considered going to 295 falkens...
    I wish there was a try and buy on tires so I could run them for a week and see how it affects the ride, performance and fuel economy.
    dradd[QUOTED] likes this.
  18. Jul 10, 2019 at 3:40 PM
    dradd
    City of Champyinz
    '17 TRD Pro
    pending...
    I know it is going to sound silly... I am considering getting the Falkens in the 265/70/18 size. Just a tiny bit taller, I don't think it would even be noticeable in width. But I could say I got bigger tires :facepalm:.
  19. Jul 10, 2019 at 4:20 PM
    #49
    shellshock
    Iowa
    2019 TRD PRO
    The main thing is I wanted something more aggressive. I’ve got a set of AT3w on my Tacoma and they have been awesome. This was the biggest I could go and still stay SL load range aka now gain 20 lbs a tire.
  20. Jul 20, 2019 at 9:09 PM
    #50
    shellshock
    Iowa
    2019 TRD PRO
    All my lighting and electrical stuff has arrived and hopefully will be installed this week.
    I'm working on installing a HAM radio in a couple other trucks and then I'll tackle it in the tundra. Likely going to be an ICOM 2730
    Still debating on the front camera. I put the kit from car solutions in my Tacoma and its pretty nice but I don't like that it has to override the GPS signal when active so it messes with navigation and the breadcrumb trail.
    Watt maker and Rica25 like this.
  21. Jul 21, 2019 at 9:46 PM
    #51
    shellshock
    Iowa
    2019 TRD PRO
    Switch pros, battery terminals, ditch lights, grill light all installed
    Running the wire through the firewall for the switch pro was a pain but it’s not so bad now that I finally figured it out. Cut off the nipple on the drivers side directly under the main wiring harness, disassemble the connector on the switch pro (good luck, this is way harder than it should be), tape up the ends and rub some dish soap on it, it’ll slide right though. Reassemble the connection and you are all set.
    The SDHQ grill mount required a little more massaging than I anticipated but everything seems to fit properly now. I had to bend the horns slightly for clearance as I needed to move the bar back to keep from hitting the grille.
    Aside from those couple things, everything else went by pretty quick.
    Here’s my switch pro wiring for anyone else who’s installing one. Also it’s very easy to disassemble the inlet into the dust box and use it as the entry point for the switch pro. Everything is tested and working: ignition, lights & high beam trigger.
  22. Sep 17, 2019 at 5:42 AM
    #52
    shellshock
    Iowa
    2019 TRD PRO
  23. Sep 20, 2019 at 5:58 PM
    #53
    shellshock
    Iowa
    2019 TRD PRO
  24. Oct 8, 2019 at 12:17 PM
    #54
    shellshock
    Iowa
    2019 TRD PRO
    Mounted the poles for the habitat the other day. Now I won't have to worry about them falling down into the bed any more. Actually a simple solution and only a couple dollars in outdoor velcro.
    jewsNbrews likes this.
  25. Oct 8, 2019 at 12:18 PM
    #55
    shellshock
    Iowa
    2019 TRD PRO
    Ordered a fridge slide for my arb elements... turns out UPS was not so kind...
  26. Oct 8, 2019 at 12:24 PM
    #56
    shellshock
    Iowa
    2019 TRD PRO
  27. Nov 16, 2019 at 3:06 AM
    #57
    SOS CONCEPTS
    SOS CONCEPTS SOS Concepts
    Is that Cav_blue from tacoma world behind you?
  28. Nov 16, 2019 at 5:08 AM
    #58
    shellshock
    Iowa
    2019 TRD PRO
    Yup. Other guy us from tw too
    SOS CONCEPTS[QUOTED] likes this.
  29. Nov 16, 2019 at 6:41 AM
    #59
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    How are the icon RTX holding up? Still liking them?
  30. Nov 16, 2019 at 6:45 AM
    #60
    shellshock
    Iowa
    2019 TRD PRO
    Very happy with them. Ride has been great and they are usually quiet unless they are really full of dirt. I’d definitely do them again. I’m running option 2, so I’ve still got another spring I can add to the leaf pack if I add a bunch more weight
    Y0TA PR0[QUOTED] likes this.
