Shake in front end
Discussion in '2.5 Gen Tundras (2014-2021)' started by socaljerry82, Mar 29, 2023.
  1. Jun 13, 2025 at 3:21 AM
    #61
    SoTexTundra
    SoTexTundra New Member
    19 DC TRD OFF-ROAD
    After this post was made i had swapped wheels and tires on my truck to some oem steel wheels and whatever tires were on it at the time and my truck ran smooth, that's when I officially knew it was either a tire issue or a balancing issue.
    Ponderosa_Pine likes this.
  2. Jun 13, 2025 at 6:09 AM
    #62
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    I got new agp rims and Michelin defender tires, got a shake at highway speeds. Had them balanced 4 times now still there. Don’t know if it tires or wheels.
  3. Jun 14, 2025 at 3:05 AM
    #63
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    May not be your problem, I had constant balance issues with Michelins. Find a shop that has a Road Force balance machine and will take the time to diagnose it.
  4. Jun 14, 2025 at 4:57 AM
    #64
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    If a road force balance fixes the problem would you have to do that every time you rotate and balance tires. People at big o says it’s the rims.
  5. Jun 14, 2025 at 3:48 PM
    #65
    Ghosty
    Ghosty New Member
    2020 Tundra TRD Pro
    I racked my brain for weeks. Went through three sets of tires. Road force balances, alignments, tire pressures and anything else I could think of. New wheels solved my problem. I had two bent rims. Could barely see it, but replaced those and the issue went away.
  6. Jun 14, 2025 at 6:04 PM
    #66
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    I fought vibrations in 4runner for many miles and months and it was just lazy techs at tire shops that thought it should be good enough if machine gave a green light. Once finally got an old timer to run the machine, problem solved.
  7. Jun 14, 2025 at 7:35 PM
    #67
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    Got tires at big o, going elsewhere for a different opinion. Big o tires suck.
  8. Jun 15, 2025 at 3:48 AM
    #68
    agrestic1
    2016 CrewMax
    Exactly. The shop I went to had both machines. If the regular spin balance didn't correct the issue they would road force. Truck was driven before and after by the manager to make sure the shimmy was gone.. Small tire shop, been there for years, I underestimated their service, they'll have my business from now on..BTW, when looking for a shop that does Road Force Balancing, call ahead, some listed on the web site don't do it..
