Seafoamed my engine.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Feb 26, 2020.
  1. Mar 15, 2020 at 12:27 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Mine sounded exactly like post 20 as well. It’s in the shop right now getting lifters and cam gears replaced on the driver side. Covered under powertrain warranty.
  2. Mar 15, 2020 at 1:42 PM
    Professional Hand Model
    Hand Protectors
    Any reason on the cause for replacements?
  3. Mar 15, 2020 at 3:38 PM
    Uhhhh....
    Dave
    7” BDS, 37s
    I'll ask them tomorrow when I call for an update.
  4. Mar 16, 2020 at 5:06 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    You may want to consider using a modern, low oil PEA fuel system cleaners. I used that in my 2006 Corolla XRS and the check engine light came on and needed to replace an oxygen sensor.
    MMO is 70% Naphthenic Hydrocarbons. 29% Mineral Spirits. Used in gas its more of a upper cylinder lube than it is a cleaner.
    My guess the reason my check engine light came on would be a P0420 catalyst efficiency CEL flooded the cat and o2 sensors with oil/lubricant. In the old days with lower catalyst efficiency standards (pre-2002) there would be no issue. Today catalytic converters are held to a higher efficiency (+-90%). So, if you if you have some miles, you've been burning oil for a while, etc. your cat may be on the edge of efficiency producing a catalyst efficiency CEL until you burn off the MMO.
    HulkSmurf14[QUOTED] likes this.
  5. Mar 25, 2020 at 11:51 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    First attempt they replaced:
    lifters & cam gears on driver's side
    both timing chain tensioners
    camshaft pulley assembly
    valve adjusters
    cylinder head gaskets
    valve arm subassembly
    It was still making noise. They opened it back up & took it down further.
    Second attempt they replaced:
    head on driver's side
    That fixed it. Now there's noise on passenger's side. So they're tearing that side down & will be replacing the head. They said pass side might have been making noise all along, just not as much as driver's side, & it was getting drowned out by loud driver's side.
    They said the noise was caused by the valves not getting oiled like they should to the top of the engine.
    Disclaimer: 95% of this post is Greek to me. I'm just regurgitating what I've been told by someone at Toyota who likely understands all of this stuff only 10% more than I do. lol
