Seafoamed my engine.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Feb 26, 2020.
  1. Feb 26, 2020 at 11:52 AM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    I did the seafoam spray after my engine developed a strange rattle sound when idling and I took it to the mechanic, he said it was fine.
    I then watched the seafoam vid from projectfarm on youtube and I decided to give it try.
    I sprayed the seafoam spray in the throttle body and it totally got rid of the rattling sound. It sounds like my buddies 19 tundra again.
    I still plan on pouring 8oz in the crank and the gas tank when I'm super low on gas.
    I'll update.
    (I have about 70k miles on my 1.)
    15whtrd, Black Wolf, Berdine and 2 others like this.
  2. Feb 26, 2020 at 12:03 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s awesome that it worked! One thing I’ve always done when adding a cleaner to my fuel system, like Lucas and other products similar. I always did it right before my oil change was due. I felt like Whatever crap I cleaned out may possibly end up in the oil. At least those are my feelings on it and it made me feel better to change the oil after the cleaning.
  3. Feb 26, 2020 at 12:03 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I use Seafoam in the crank and tank before an oil change as well. I buy two cans, put 7oz in the crank, fill the tank to where it's around 1/2 tank (I have the 38gal tank) and put the rest of the can plus the other one in the tank. I also use Top Tier gas, so this is probably overkill, but I do like to try and get out as much buildup as possible.
  4. Feb 26, 2020 at 12:09 PM
    Tundra234 Mods, mods, and more mods
    I used it in a Tacoma that I had years ago and someone called the fire dept bc they thought it was on fire. Took care of the mosquitos though...LOL. :yes:
    Fiesta346, Vr0ck, TheBeast and 4 others like this.
  5. Feb 26, 2020 at 12:13 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Usually do 500miles before my next oil change.
    Can in a full tank of gas, half can or so in the crankcase and then the rest intake system. Never had much of a cloud when doing via intake....assuming because we are MPI.
    Rex Kramer and 15whtrd like this.
  6. Feb 26, 2020 at 12:32 PM
    Stig
    Stig New Member
    Did you see an improved mpg?
  7. Feb 26, 2020 at 12:43 PM
    Professional Hand Model
    Hand Protectors
    Did the SeaFoam Engine Spray SS-14 for the first time this fall after never having done it before on the 2002 4.7 V8.
    It really cleaned that inside manifold surface and turned it from soot black to shiny aluminum again. I had already cleaned the throttle body plate with success using a rag and cleaner, but noticed the soot all up in the manifold. Got to reading how the intake valves can get sooted up, as well. This is the only way to clean them other than total engine disassembly so I bought some spray.
    Got nervous after the treatment with the smoke and roughness of engine, but it really settled down after a while. I’ll do this every year from here out for prevent maintenance. A can of SS-16 in the tank helps too.
    NewImprovedRon likes this.
  8. Feb 26, 2020 at 1:33 PM
    KissMyAxe1
    KissMyAxe1 New Member
    Utah
    2008 Black Tundra SR5 Crewmax
    I seafoamed my engine, still waiting to get closer to an oil change to add a little to the crank and fuel. I didn't do a thorough before and after check, but I feel like once a year, it helps keep things moving.
  9. Feb 26, 2020 at 2:38 PM
    HulkSmurf14
    Ryan
    Bozeman, MT
    2014 Tundra Limited
    Tastefully enhanced...
    I use MMO in the tank every 4 tanks during the winter...once a year in the crankcase 500 miles prior to oil change...if you have old fuel and don't drive a lot it usually just drive short bursts most of the time, I suggest BG44k fuel treatment a couple times a year...that's just my personal opinion after owning German vehicles...works well...
    I typically find myself getting at least 2mpg better for one tank AFTER the tank with the "juice" in it...doesn't make sense to me but it's been consistent over 3x...
    Hillbilly Taz and BENWALES like this.
  10. Feb 26, 2020 at 4:05 PM
    Erick
    Erick
    Thornton Colorado.
    So far no mpg gain. I reset my mpg to see. Still at 13.7 to 14.
  11. Feb 26, 2020 at 4:11 PM
    If I'm not having any issues, should I do what some of you guys are doing? Only thing I've done was a fuel additive last year, was at a dealership getting a oil change and saw the additive, bought it poured in
  12. Feb 26, 2020 at 5:37 PM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    You dont need no additives in a Toyota engine, waste of money, it's not a domestic pig. Stay with the same brand of oil, same hi octane gas, unless in travel take what you get, and rev the f*@# out of it once in a while. Gas mileage? What concern is that when you buy a V8.
    B.Ross, Hoff and HulkSmurf14 like this.
  13. Feb 26, 2020 at 6:36 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Why?
  14. Feb 26, 2020 at 6:42 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Cause rotary!!!
    Wait. That's not us.
    Cause Italian tune up!!!
    Wait. Not us either.
  15. Feb 28, 2020 at 7:03 AM
    Erick
    Erick
    Thornton Colorado.
    I'm currently at 16mphs. I did indeed get a gain.
    That's a unexpected yet fantastic bonus. I was just trying to get rid of the rattle.
    HulkSmurf14 likes this.
  16. Feb 28, 2020 at 10:03 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Because the engine is made to for one, but not talking excessive here. If you have a stretch of road, take the revs up and enjoy. It's good for the engine to perform like it should, in safety and safe levels.......instead of driving like grandma all the time.
  17. Feb 28, 2020 at 12:18 PM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
    Can you explain your “rattle” a bit more?
    I’ve got one too. Diagnosed as a bad timing chain tensioner. The rattle happens after the truck has been cold started and goes away when warm. Haven’t heard of an actual timing chain tensioner failure yet so I haven’t had it fixed yet. Mainly due to the fact that it’s 10 hours labour...
  18. Feb 28, 2020 at 12:24 PM
    KissMyAxe1
    Utah
    I had a rattle too. Sounded like one of the heat shields rattling though, and only on a cold start. I didn't do a ton of investigating, and it would last for a minute or two and then go away. Hasn't happened since I put some seafoam through the intake though. I'm not sure what the seafoam would've fixed, but the rattle hasn't come back yet.
  19. Feb 28, 2020 at 12:33 PM
    Uhhhh....
    Dave
    7” BDS, 37s
  20. Feb 28, 2020 at 12:54 PM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
  21. Feb 28, 2020 at 2:07 PM
    KissMyAxe1
    Utah
    Mine didn't sound like it was in sync with the engine RPM like it does in this video or from the thread linked above. Maybe it was, the start up idle is pretty quick. I just figured mine was a heat shield or something, but it hasn't happened since doing the seafoam. It didn't happen the first couple of times after I brought it home, and then it's been a few weeks since doing the seafoam and I haven't heard it since.
  22. Feb 28, 2020 at 2:50 PM
    Erick
    Erick
    Thornton Colorado.
    My rattle sounds like your issue. It may have what other have stated it may be. It happebed to me cold or hot.
    My truck would also make a winding sound on super cold day . It had since been problem free after the treatment. It has also only been less than a week so I'll update.
  23. Feb 28, 2020 at 2:53 PM
    KissMyAxe1
    Utah
    Mine would only happen during the first start of the day, and then it wouldn't happen after the RPM dropped from that first idling rpm. So like if I shifted into gear, it was gone, or if I waited a while to let the RPM's naturally drop, it would go away too. I could never get it again until the next day when the engine was completely cold.
  24. Feb 28, 2020 at 3:36 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Can you post a link to vid of what you did?
  25. Feb 28, 2020 at 3:39 PM
    KissMyAxe1
    Utah
    scpete24 and NewImprovedRon like this.
  26. Feb 28, 2020 at 4:00 PM
    Sas
    OKC, OK
    From Step 2, it should've been...
    Step 3: Tear intake boot because your car is old.
    Step 4: Start getting weird idling issues and lean codes.
    Step 5: Quickly get on the Amazon page for Sea Foam Spray and post a 1-star OMGWTFBBQ review.
    Step 7: Forget step 6.
    Step 8: Get on your favorite auto forum and :bananadead: Sea Foam Spray.
    Step 9: Feel sheepish when someone finally asks if you checked the intake boot for damage.
    Step 10: Shamelessly post "Of course I did, I'm not a noob".
    Step 11: Go check your intake boot for damage.
    Step 12: Order a new intake boot and hide out for a week while you lick your wounds.
    Congratulations, you've completed your Sea Foam Spray 12-Step Program!
    Dantdodge and Deuxlatch like this.
  27. Feb 28, 2020 at 4:25 PM
    Dank1296
    Dank1296 New Member
    JC
    2015 Grey Tundra SR5
    Nerf Bars
    What He Said
  28. Feb 28, 2020 at 7:04 PM
    Double Aught
    Double Aught New Member
    2018 Magnetic Grey 1794 Edition CM 4wd
    I used this once on my 01 Firehawk. I used the power brake booster vacuum line to suck in the Seafoam. I had to carefully let the hose suck in the seafoam to prevent the engine from stalling, but I have to tell you, I got clouds of smoke at first out of the exhaust pipes and then nothing. I felt it did its job.
  29. Feb 28, 2020 at 7:32 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    I’ve got a can of RP Max Blast. Will be using it for the first time this next week, before oil change.
    Anybody used it? Good as Seafoam?
    Also been contemplating taking the manifold off for a thorough cleaning and perhaps a porting. Which might have to come first, before the RP.
  30. Mar 15, 2020 at 12:07 PM
    Oklahoman
    Oklahoman New Member
    Moore
    2015 White Tundra 4x4
    Leveling Kit TOYOTA grill
    Mine sounds exactly the same as the video in post 20. It is intermittent and seems to cycle on and off. It never makes the sound at the dealership. Hope I can get it fixed before my warranty runs out.
