Scangauge 3 Available
Discussion in 'General Tundra Discussion' started by Bergy24, May 19, 2022.
  1. Sep 2, 2022 at 4:58 PM
    #121
    fireman_pete
    fireman_pete New Member
    Pete
    2021 SR5 Trail Edition
    Thanks, I used the Auto Scan, and it pulled up A/T Oil Temp 1 and A/T Oil Temp 2. Anyone know what the difference between the two are?
    A/T Oil Temp 1 has been consisent in the 195-215 range. However, this afternoon, I noticed A/T Oil Temp 2 around 235.
    Thanks!
    Pete
  2. Sep 2, 2022 at 4:59 PM
    #122
    fireman_pete
    Pete
    Thank you. It did. Do you know the difference between the A/T Oil Temp 1 and A/T Oil Temp 2?
  3. Sep 2, 2022 at 7:51 PM
    #123
    flatlandclimber
    flatlandclimber New Member
    2022 DC
    One should be pan temperature and one is... somewhere else. I think it's most likely the torque converter output temperature, though I am not positive.
    The TC output temperature will likely rise faster and higher than the pan temp.
    nobodyintexas likes this.
  4. Sep 3, 2022 at 3:21 AM
    #124
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    yes
    1 is pan
    2 is TC
    2 will fluctuate as TQ happens...cruising down hwy, they should be equal-ish
    you can choose TC lockup & gear. along with the above is a good picture when towing
  5. Sep 13, 2022 at 10:29 AM
    #125
    Bustedandrusted
    Bustedandrusted New Member
    I just received a Scangauge 3.
    The stock configuration shows the trans temp and lock up status however I thought there were two transmission temperatures? Pan and Converter. I can only see one.
    Anyone have the manual codes for the two transmission temps on the ‘22 tundras? I can’t seem to find them on the scangauge website.
  6. Sep 13, 2022 at 10:30 AM
    #126
    nobodyintexas
    nobodyintexas What?
    South of Houston
    scan your xguages it should pop in.
  7. Sep 13, 2022 at 10:54 AM
    #127
    Did you get the SG 2 or 3? Maybe the pic just popped up as the 2 when you were typing.
  8. Sep 13, 2022 at 11:01 AM
    #128
    ScanGauge
    ScanGauge New Member
    Data I've collected from a 22' Tundra seems to indicate that only 1 Transmission Temp is supported. The feedback I've gotten on it is that it appears to be reading from the Pan.
  9. Sep 13, 2022 at 11:18 AM
    #129
    flatlandclimber
    2022 DC
    I had the same question. After discussion with scangauge they sent me a data logger to capture an image of what's going on.
    When they analyzed the file they found no evidence of a second sensor. They said they will continue to research.
    Based on how slowly the temperature changes I think the one that is being displayed is the pan temp.
    Bustedandrusted likes this.
  10. Sep 13, 2022 at 12:36 PM
    #130
    Bustedandrusted
    It’s a 3, yeah just an error with the pic.
  11. Nov 16, 2022 at 3:27 PM
    #131
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    Wondering if this got settled? Which Scangauge reads both transmission pan and TC temps?
  12. Nov 16, 2022 at 4:55 PM
    #132
    Bustedandrusted
    The 22+ Tundra only reports the single value, which is Pan temp, regardless of reader.
  13. Nov 17, 2022 at 4:54 AM
    #133
    spyshot
    Ohio
    Oh darn. I missed the part about that being a '22 tundra. What about the '19? I would like to get a scangauge 2 but I will rethink that if it does not give me the data I need when checking fluid level.
  14. Nov 17, 2022 at 4:56 AM
    #134
    nobodyintexas
    nobodyintexas What?
    South of Houston
    SG2 will give both readings on pre-22 Tundra's
    i used it for such.
    Saltyhero13 likes this.
  15. Nov 17, 2022 at 4:57 AM
    #135
    spyshot
    Ohio
    thank you!
    Thank you!
  16. Jan 16, 2023 at 4:33 PM
    #136
    texasrho83 likes this.
  17. Jan 16, 2023 at 4:50 PM
    #137
    Actual User manual is available now as well.
  18. Jan 23, 2023 at 7:36 AM
    #138
    Still working good for you? I just ordered one.
  19. Jan 23, 2023 at 7:37 AM
    #139
    The full manual is available on their site now.
  20. Jan 23, 2023 at 7:38 AM
    #140
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I use it everyday. stays hooked up.
    Since my dash mileage is jacked up due to tuning, the SG3 is damn accurate on the mileage.
    it's within a 10th of a gallon on fillups.
  21. Jan 23, 2023 at 7:40 AM
    #141
    Nice. I just ordered the Rago dash plate but I will most likely keep it where my SG2 is. I like things hidden. ICS can custome make a mount for it if I want to use it on the Rago at all.
  22. Jan 24, 2023 at 4:42 PM
    #142
    Hooked up the SG3....this thing is a beast!
  23. Feb 3, 2023 at 3:49 PM
    #143
    Question on that mount. Can it be mounted from the bottom side of the vent and the holding portion rotated? I'm looking at their phone mount but I want to have it lower on the dash on the vent to the right side of the steering wheel.
    ZPhilip likes this.
  24. Feb 3, 2023 at 4:02 PM
    #144
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    You can mount at any orientation along the air vent, but you’d have to move the actual flaps of the vent accordingly - and they would be locked into that position.
  25. Feb 3, 2023 at 4:05 PM
    #145
    Gotcha. Thanks for the reply. I'll take some pics tomorrow of what I'm looking at doing to replace my current phone mount. It looks like I would be able to get the Tackform fairly close to the dash.
  26. Feb 8, 2023 at 10:21 AM
    #146
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you unplug your radio so you now get all your monitoring through the SG?
  27. Feb 8, 2023 at 11:08 AM
    #147
    No.
  28. Feb 8, 2023 at 11:40 AM
    #148
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  29. Feb 8, 2023 at 11:56 AM
    #149
    WVI
    WVI New Member
    @008 Tundra Limited
    Question for those switching from an SG2.
    How or where did you mount the SG2??
    I can't figure out a good way to do it.
  30. Feb 8, 2023 at 12:21 PM
    #150
    Saltyhero13
    Saltyhero13 Throbbing Member
    I had 3 daisy chain mounted at the top of the windshield. I found a mount on Amazon that was made for mounting on the rear view mirror and modified it using suction cups mounts.
    WVI[QUOTED] likes this.
