Say YES! To the TRD Sway Bar!
Discussion in 'Suspension' started by TundraXPLover, Oct 27, 2019.
  1. Nov 6, 2019 at 11:29 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Not to mention that the Hellwig costs nearly twice as much the TRD! :eek: But they are HEAVY DUTY (Solid forged spring steel, 1.13" diameter)...and they're also already gray powdercoat.
    Rex Kramer[QUOTED] likes this.
  2. Nov 6, 2019 at 11:35 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Yep, the Hellwig on my 2002 is a beast... it's much larger than the TRD on my '07.
    TundraXPLover[OP] and Winning8 like this.
  3. Nov 6, 2019 at 11:42 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    1D1DD482-365E-4295-B5D6-DA9C721E9151.jpg 14B4C4A4-FFB6-49A4-AB0A-D5415CE18FE0.jpg
    I got the rear sway bar for my birthday too, but due to UPS delivery. My box was broken and I’m missing a end link spacer. I have to go HD get a coupling nut, and cut to length, to replace the missing spacer.
    TundraXPLover[OP] likes this.
  4. Nov 6, 2019 at 12:10 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    That thing is thicker..(that's what she said) so your rear end would be planted more on the road than the TRD bar?
  5. Nov 6, 2019 at 12:18 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Did you shim your brake line on the drivers side or are you letting it rub on the shackle? I got a longer bolt and put some washers under the bracket. That's how ocd I am
  6. Nov 6, 2019 at 12:25 PM
    Rex Kramer
    Georgia
    That's the idea.
    Moon Puppy[QUOTED] likes this.
  7. Nov 6, 2019 at 2:31 PM
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    My bad. Yeah, I was referring to the labor cost, not the cost of the RSB.
    Roman[QUOTED] likes this.
  8. Nov 6, 2019 at 2:34 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Every time i see this thread bumped to the top i get the urge to orders ome of these things....THANKS guys!
    MAGDADDY and TNTundra7 like this.
  9. Nov 6, 2019 at 2:49 PM
    JohnLakeman
    For a tow vehicle, I would go with the Hellwig for insurance (Sorry, @Roman). For daily street driving, Toyota has probably sized the TRD to be all you'll ever need.
    The Hellwig has three holes in each end of the anti-roll bar: the end hole has the least effect, middle for medium effect, inside hole for maximum roll resistance.
    Winning8 and Rex Kramer like this.
  10. Nov 6, 2019 at 3:17 PM
    Rex Kramer
    Georgia
    Hellwig makes a monster RSB.
  11. Nov 6, 2019 at 3:28 PM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    If shes as oblivious to her cars driving characteristics as mine she will never notice.
    Jengel451[QUOTED] and TNTundra7 like this.
  12. Nov 6, 2019 at 4:27 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    I noticed that, and this makes me wonder about those installs of the TRD SB on the side, might have differing effect to the proper install. Sure it'll have some effect but is it the same?
    TNTundra7 likes this.
  13. Nov 6, 2019 at 4:35 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Hbjeff[QUOTED] likes this.
  14. Nov 6, 2019 at 5:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
  15. Nov 6, 2019 at 6:06 PM
    Leetomnsx
    Leetomnsx New Member
    2016 Toyota Tundra Platinum
    Air lift, black out emblems, wheels, tonneau cover, tires, led lighting, hidden step rail, remote start.
    Installing mine Sunday lol.
  16. Nov 6, 2019 at 6:19 PM
    JohnLakeman
    I'm not clear what you mean when you say "installs of the TRD SB on the side".
    The end links for the TRD and the Hellwig anti-roll bars attach at the same point, i.e. in the front bolt hole of the trailer hitch bracket for 2007+. The Hellwig anti-roll bar is 1 1/8" diameter forged steel bar, the TRD is maybe 7/8"(?) diameter forged steel bar. I estimate the Hellwig will be slightly stiffer than the TRD with the links mounted in the end hole, or the lowest stiffness setting. If you are towing a large camper, the stiffer roll bar will help stabilize your truck against sway induced by the camper. If you're driving the Hellwig daily on the street, you may see a little more stiffness in the ride, even with the links in the end hole. Just guessing here, haven't ordered one yet.
  17. Nov 6, 2019 at 6:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Guys who lift their trucks have to install the sway bar on the back of the axle instead of under it. I cant imagine it making a difference
    JohnLakeman likes this.
  18. Nov 6, 2019 at 6:39 PM
    Rex Kramer
    Georgia
    I had to install mine on the backside because I lowered the rear.
  19. Nov 6, 2019 at 7:08 PM
    #49
    JohnLakeman
    Ahhhh, now I get it. Hellwig has a different part number for trucks with 2-4" lift, plus the end links are adjustable if needed. For 2007-2020, stock height with trailer hitch, the rear anti-roll bar is PN7692. For 2-4" lift, you use PN7889.
    Rex Kramer likes this.
  20. Nov 11, 2019 at 5:08 PM
    #50
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Just have it powder coated
  21. Nov 17, 2019 at 7:23 AM
    #51
    TundraXPLover
    TundraXPLover [OP] New Member
    Clif
    NC
    2018 CM 4x4 XP
    Update 500 miles later....
    Very minimal loosening of Ubolt nuts only. Retorqued to specs.
    We had an extremely windy day here in the middle of NC yesterday and that sway bar made a huge difference with handling and body sway against the wind. I was very surprised how well it handled.
    Best upgrade yet!
    Y'all have a good week!
  22. Nov 17, 2019 at 8:05 AM
    #52
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
  23. Nov 17, 2019 at 11:18 AM
    #53
    TNTundra7
    TN
    2016 SR5 4WD 5.7L
    Agreed. One of the best benefits is driving on the interstate with strong crosswinds.
  24. Nov 20, 2019 at 5:11 PM
    #54
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    20191120_143446.jpg Joined the TRD sway bar club today. Should've done it a long time ago. Got mine from Bam wholesale for $204.00 total.
  25. Nov 20, 2019 at 5:46 PM
    #55
    Take it up to 75 or 80 mph and do a quick lane change....you will feel the difference. I have front and rear.
    Leetomnsx, Winning8 and TNTundra7 like this.
  26. Nov 20, 2019 at 6:40 PM
    #56
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    OEM Tundra front sway bar (48811-0C020) - 17 lb - hollow (inner diameter d approx. 64% of outer diameter D)
    OEM Sequoia front sway bar (48811-0C030) - 24 lb - hollow but thicker walls (d/D = 0.41) - 16% stiffer than Tundra (ref. 1)
    2018 TRD Sport front sway bar (PTR62-0C180) - 29 lb (ref. 2) - solid - 20% stiffer than Tundra (ref. 3)
    My 2018 Limited Tundra drives like a dream to me [it came with a front sway bar]. For 50 bucks difference, I think I'll go with the TRD Sport when I put it on, although I am not sure the difference would be noticeable.
  27. Nov 20, 2019 at 6:43 PM
    #57
    TemujinNomad
    TemujinNomad New Member
    When would you not want to install a rear sway bar? Rock crawling folks?
  28. Nov 20, 2019 at 8:04 PM
    #58
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You don’t want sway bars offroad
  29. Nov 20, 2019 at 8:15 PM
    #59
    Leetomnsx
    How is the front. Just took truck out on a curving road and big difference.
  30. Nov 21, 2019 at 7:38 AM
    #60
    Yes
