Rusted leaking rear differential cover
Discussion in '1st Gen Tundras (2000-2006)' started by Big Paully, Jun 24, 2018.
  1. Mar 21, 2021 at 7:02 PM
    #91
    KamperBob
    KamperBob New Member
    2002 Tundra Limited 4WD 4.7L
    I'm in the middle of my repair. I'll follow up in a couple days with pix. Meanwhile, some observations so far. I believe [empty_lord nailed it]. The geometry of the cover is such that a crevice is formed between the bottom edge of the radiused cover where it meets the flat vertical housing. My leak originated there. No perforations above the lip. I'm convinced that any trapped moisture collecting in that crevice initiates corrosion and eventual leaking. A cover welded around the outside (stock) leaves that crevice inside. Root cause.
    Thanks (again) to [NUDRAT for sharing the axle vent issue]. In my case thinner hot oil from use and internal pressure from clogged vent increased the leak rate. I got as far as an exploratory procedure in my GF's garage, then paused. I waited 'til I could book time at a buddy's garage to completely remove the axle from the truck. That dovetailed with other brakes & suspension issues. Since unclogging the vent and replacing nasty stank fluid I've recorded cover temps from 125 to 180F in recent weeks.
    I started with [Jeffersonjohn's bolt-on replacement]. I prefer how forming a gasket can fill the crevice on bottom. No crevice, no leak initiation there. My stock cover may've been 14 gauge originally; compared to about 11 gauge on the Dorman replacement; considerably thicker. So, although I could've easily welded on a replacement, I like bolting better. But my version took some twists. In short, mods to the cover for a friendlier fill port and way to check fluid level better. Stay tuned...
  2. Mar 22, 2021 at 4:21 AM
    #92
    Professional Hand Model
    Hand Protectors
    Nice. That Jeffersonjohn method looks solid and I’d go that route if in the same boat. Look forward to some pics!
  3. Mar 22, 2021 at 6:59 AM
    #93
    tvpierce
    tvpierce Formerly New Member
    Maine
    Interesting observation. I've always assumed the rust was coming exclusively from the exterior (which wouldn't be surprising given that it's exposed to some pretty harsh conditions). But you're saying you saw evidence of moisture accumulation on the inside in that crevice?
  4. Mar 22, 2021 at 6:01 PM
    #94
    KamperBob
    Good question.
    Below the fluid level there's clearly more protection; presumably oil protection. The actual crevice was destroyed removing the old cover, unfortunately. Mine was solid above the crevice. Not even close to perforation.
  5. Mar 23, 2021 at 6:37 PM
    #95
    KamperBob
    Followup time. The old cover was cut off with a 4.5" disk. The housing was ground not perfect but flat enough.
    I tried minimizing sparks and dust getting inside. Some did anyway so it'll get attention early and often going forward. (shrug)
    The replacement cover was modified. The stock fill port was drilled out at roughly 45-deg angle using a simple guide.
    The new hole was elliptical. A threaded coupler was welded in for an up-angle port. Not just for easier filling. It's alignment provides a clear path to the bottom of the housing.
    The second port was added for a site glass. Eight 1/4-20 holes were made around the lip/rim to secure the new cover. The housing was wire wheeled. Both housing and cover were primed with Rustoleum Rust Reformer then painted with Rustoleum Rubberized Undercoating.
    Scope creep included new brake lines from the T block to both sides; the old ones twisted off during removal. Rear brakes were completely replaced: drums, shoes, wheel cylinders, parking brake bell cranks. Saving the old U bolts wasn't worth it; they were cut off and replaced.
    Y0TA PR0, bmf4069, NUDRAT and 5 others like this.
  6. Mar 23, 2021 at 6:42 PM
    #96
    Hand Protectors
    Nice work!
    Where can I get one of those site ports to fit the OEM Plug?:yes:
    Tundra2 likes this.
  7. Mar 23, 2021 at 7:00 PM
    #97
    KamperBob
    LOL
  8. Mar 24, 2021 at 5:17 AM
    #98
    Hand Protectors
    Thanks my man! You can get them at McMaster-Carr or this one other place.
    FrenchToasty likes this.
  9. Mar 24, 2021 at 5:18 AM
    #99
    Hand Protectors
    Cool bud. You are awesome.
  10. Mar 24, 2021 at 5:50 AM
    #100
    KamperBob
  11. Mar 24, 2021 at 5:55 AM
    #101
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  12. Mar 24, 2021 at 6:13 AM
    #102
    Hand Protectors
    In my research, there are 360° View Site Plugs. Now I’ll be able to monitor the health of the entire diff. :yes:
    Where are my Crazy Pills?:rofl:
    KamperBob[QUOTED] likes this.
  13. Mar 24, 2021 at 6:24 AM
    #103
    Hand Protectors
  14. Mar 24, 2021 at 6:32 AM
    #104
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Is that bung on the OEM diff cover metric, or pipe thread? The one @KamperBob used was a NON-OEM.
    You may have to get crafty like KB did above. Great work! :thumbsup:
  15. Mar 24, 2021 at 6:38 AM
    #105
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    A sight tube would probably work better than just replacing the plug but adds an extra leak potential.
    Tundra2 likes this.
  16. Mar 24, 2021 at 6:39 AM
    #106
    Hand Protectors
    I’m almost sure its BPPT. Yeah. Creative and I like it. Probably won’t do it unless ‘in there’ for something major which I never hope to be. :thumbsup:
    KamperBob and Tundra2[QUOTED] like this.
  17. Mar 24, 2021 at 6:59 AM
    #107
    KamperBob
    Thanks, Noah. Yes, 3/4" pipe thread. The larger, up angled hole is not only more funnel friendly. Having a clear path to the bottom of the housing means I can swab it with a telescoping magnet. Noninvasively! The drain plug has a magnet but one has to dump the oil to check/clean it. (Unless the truck is upside down of course. LOL)
  18. Mar 24, 2021 at 7:04 AM
    #108
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes, I saw all that. Your work looks great. Fantastic upgrades "while in there" also. :)
    The noninvasive pap smear is a wonderful idea. :cheers:
  19. Mar 24, 2021 at 7:10 AM
    #109
    Hand Protectors
    This is the one guys! Sight Glass with Oil Monitoring Draw Off Capabilities to send off to the lab. I’m sure we could somehow magnetize the Butterfly Screw for @KamperBob Metal Catching Analysis.
    KamperBob and Tundra2 like this.
  20. Mar 24, 2021 at 7:19 AM
    #110
    KamperBob
    I know I was pedantic but some might appreciate that. :)
  21. Mar 24, 2021 at 7:21 AM
    #111
    KamperBob
    That's not crazy, dude. It's insane! Love it.
  22. Mar 24, 2021 at 7:22 AM
    #112
    Hand Protectors
    Yeah. You’ve inspired it. :rofl::thumbsup:
    Tundra2 likes this.
  23. Mar 24, 2021 at 7:26 AM
    #113
    KamperBob
    You're welcome. ;)
  24. Aug 9, 2021 at 7:53 PM
    #114
    Bee man.
    Bee man. New Member
    Make sure it's not just a failing weld. I had two dealerships look my 2006 Tundra Double Cab over and both told me the cover was failing but they could only replace the whole axle since they don't do any welding at dealerships.
    I got a buddy who is an expert welder to cut off the old cover and weld on a new Barnes 4WD cover. (He was impressed by the thickness of the Barnes cover by the way). We didn't inspect the original differential cover to make sure the "experts" at the dealerships were correct. We just had a local mechanic drain it and pull out the guts. Then we cut off the cover.
    Once the cover was off, my buddy called me over to show me that the original cover was just fine all along. No perforations. The factory weld had failed. He traced out a small little line on the housing's surface showing me where the oil was leaking. "If I had known this, I could have repaired it in 15 minutes. We wouldn't even have had to bring it into this shop. We could have drained it and I could have simply ground out the failing section and re-welded it. We wouldn't have needed to pull the gearing because that little bit of welding wouldn't have heated it up at all".
    The story gets sadder because shortly after having everything put back together, I started hearing a faint whine from the differential. The mechanic was confident it must be road noise from a wearing tire or something else but not the differential. Turns out the shop didn't have the tools needed to do that job and they shouldn't have taken it on. One mechanic there retired, the other left during pandemic. The owners won't do anything to help me out other than offer to have their new guy (who was honest enough to explain why he couldn't work on my now failing differential), bolt on a salvage axle for just a little less than Toyota wants to put on a remanufactured one.
    Now Toyota is likely to get a nice payday because their guys never actually inspected the leaking cover like they said they did. I now believe they eyeballed it and assumed they knew the problem and solution. And yes, I bear responsibility for trusting and not verifying.
    Hence this precautionary post to all others. Power wash the daylights out of your cover and then climb under there with a wire brush, clean it up, and look at the seam. These covers are not that fragile. I live in rust belt city. My truck was 14 years old at the time. The cover was solid. One small portion of the weld was bad and my pipe fitter buddy would have fixed it for a pack of homebrew.
    NUDRAT likes this.
  25. Aug 9, 2021 at 11:54 PM
    #115
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If the axle is now failing all it should need is old 3rd member to be unbolted, everything inside cleaned out to make sure no metal fragments, and a new 3rd member put in. Of course you must pull axles out slightly to do this. Unless the noise is coming from a wheel bearing or similar. If it's the differential itself just swap it with a known good unit.
    Tundra2 likes this.
  26. Aug 10, 2021 at 7:21 PM
    #116
    Bee man.
    Bee man. New Member
    Okay well here's your chance for me to learn. I have only minor theoretical knowledge of differentials. I was skeptical when I saw the guts of my axel lying on their grubby shop floor but decided to stay quiet and trust the guys that were helping me out. That acted like they had done this before and they were letting us use their lift to weld the new cover on. The new guy at this shop told me he doesn't have a special tool required to put it back together after pulling it apart and repairing it but that a transmission shop would. He would be able to swap out the whole axle with a new/used one though.
    It's definitely a whine coming from the differential. Louder under load but also there slightly when coasting. The transmission shop he recommended has not returned my call and the best mechanic shop in the city nearby is NOT interested in taking it on. I watched a two hour university class on YouTube with a professor who went through quite a procedure using shims to make sure the gears meshed perfectly in a particular differential housing. I was under the impression when finished that each set up was unique.
    The shop that damaged my good differential wants to replace the whole thing with a scrap unit for 3600 dollars. For 1000 dollars more Toyota would replace it with a remanufactured unit (conceivably with a warranty). That was their fix for the differential cover. I have not asked them to look at it now that I had it "fixed". Any thoughts you have would be appreciated. Especially before going back to the dealership.
  27. Aug 10, 2021 at 7:29 PM
    #117
    NickB_01TRD
    Nick
    KY
    If they just pull out the old 3rd member (differential gear assembly) they don't have to take any of the differential components apart. They just need a known good 3rd member to put in place that is already assembled. If it's already assembled you just remove the driveshaft then you need to pull both axles out at least slightly. Then unbolt old 3rd member and remove then install new and reverse all other tasks.
    Many people like to do wheel bearings, axle seals, and backing plates when pulling the axles but it is not a necessity if you do not want to spend the money.
    dbittle likes this.
  28. Aug 10, 2021 at 10:28 PM
    #118
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If you and your buddy can pull the axles and 3rd member, I would do that. Just get another one to throw in. It'd be the cheapest option and can be done in a garage/driveway.
    Your location may help. If you were near the Sacramento, CA area I could probably sell you my spare once I pull it. (If 2wd OR it matches your gearing if 4x4. Has 4.10's and OEM LSD.)
    East coast gear has a swap out program, where you buy an assembled 3rd member and provide yours as a core. West coast diff (differentials.com) may also be able to do the same (they're local to me and who I buy parts from).
    NUDRAT likes this.
  29. Aug 11, 2021 at 7:34 AM
    #119
    Bee man.
    Bee man. New Member
    Wow you guys make this sound like replacing a light switch. (A very heavy light switch) I wonder why I'm getting all the drama from the shops around here? I wish I had more time (and talent) to mess with it this year, but I already have so many irons in the fire. Probably can't drive it to Sacramento from Michigan to watch you do it. But you have inspired me to look into getting a complete 3rd member shipped here and paying someone with the tools to do it right. You see after we replaced the differential cover, I was motivated to have the rust on the frame dealt with (my 06' fell outside the recall). After needle scaling, painting, cutting and welding, I can't say goodbye to her yet. Thanks. This might take a while to solve, but I'll keep you posted.
  30. Aug 31, 2021 at 8:20 PM
    #120
    Bee man.
    Bee man. New Member
    My truck goes in tomorrow to a different shop from the one that messed it up. I drove it on a short 120 mile round trip and by the time I got back I was hearing the noise even when coasting. My new guy ordered a remanufactured 3rd member from Jasper. It comes with a three year 100k mile warranty, parts AND labor for 3000 dollars. That beats Toyota and the it beats the price the other shop quoted for a scrapped rear axle.
    We'll see how things go. Hope to get it back in a few days, maybe even with a report on how it got goobered up to begin with.
    NUDRAT likes this.
