Rusted leaking rear differential cover
Discussion in '1st Gen Tundras (2000-2006)' started by Big Paully, Jun 24, 2018.
  1. Oct 25, 2019 at 7:30 PM
    Mytechguyri
    Mytechguyri New Member
    2004 Tundra 4x4 Access Cab step side
    It was... Only thing that sucked was i had to do it twice... Salvager i got first one from miscategorized it as access cab... Turned out it was for double cab.... Bolted right up perfect...but when i slid the axles in i realized i had a problem.... Wouldnt engage the diff... Double cab has a 2" wider wheelbase, so my axles were 1" too short..... So found another in good shape, also for $350 shipped, this time it did come off an access or regular cab so fit perfect...6 hours later was driving it home.... So now i have a double cab housing i don't need.
  2. Oct 30, 2019 at 8:01 PM
    Jordanct1
    Jordanct1 New Member
    2004 double cab 4x4
    Hey I might be able to use that. Let me know if you still have it. I have a 2004 tundra double cab 4x4 with abs. I'm in CT and I'm assuming you are in RI. I am dealing with this same issue and don't want to spend a fortune to fix it.
    Mytechguyri and NUDRAT like this.
  3. Oct 31, 2019 at 7:41 PM
    Mytechguyri
    Yup still got it....
  4. Nov 4, 2019 at 6:26 PM
    Oldgray
    Oldgray New Member
    Lee
    Double cab limited
    Where are you located?
  5. May 22, 2020 at 8:47 AM
    Deverett5
    Deverett5 New Member
    Dakota
    I know this is a late post on this topic but would a rear from a 2003 tundra with ABS be able go into a 2001 tundra that doesn't have ABS has the same gears and everything?
  6. May 22, 2020 at 9:01 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yes. You just need to snip
    Off the wires from the abs sensors and leave the sensors in to plug the holes
    NUDRAT and Deverett5[QUOTED] like this.
  7. Jun 3, 2020 at 5:47 PM
    Jeffersonjohn
    Jeffersonjohn New Member
    04 Sequoia
    So my rear differential is leaking worse. I'm a machinist, not a welder. Has anybody tried grinding off the old cover and drilling and tapping a series of holes around it and sealing it with silicone gasket in a tube?
  8. Jun 3, 2020 at 6:06 PM
    Professional Hand Model
    Hand Protectors
    No but it sounds doable for someone with your skills. You’d be a hero to all those that have done the other routes (JB Weld, etc).
  9. Jun 4, 2020 at 10:28 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Should work but seems more labor intensive than just using something like this.
    https://www.amazon.com/Loctite-Bonding-Compound-2-Fluid-1360700/dp/B0044F9JWM
  10. Jun 5, 2020 at 8:54 AM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    Why not just go the "new cover" route... barnes4wd.com
  11. Jun 13, 2020 at 8:40 AM
    Jeffersonjohn
    04 Sequoia
    I drilled and tapped 8 1/4-20 holes and sealed the new one with silicone gasket. I'll see how it works out. Thanks for the advice all.
  12. Jun 13, 2020 at 9:15 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    What cover did you use?
  13. Jun 13, 2020 at 12:40 PM
    Hand Protectors
    Post up some pics man!
  14. Jun 13, 2020 at 3:02 PM
    Jeffersonjohn
    04 Sequoia
  15. Jun 13, 2020 at 3:03 PM
    Jeffersonjohn
    04 Sequoia
  16. Jun 13, 2020 at 3:14 PM
    Jeffersonjohn
    04 Sequoia
    Looks like I posted three of the same pic.
    If you want a step by step I'll write it out when I get time. This took up all my free time for a week and I'm behind on chores.
  17. Jun 13, 2020 at 5:29 PM
    Hand Protectors
    @Darkness
    This green would match your spare tire.
    YardBird likes this.
  18. Jun 13, 2020 at 6:26 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Anyone have good tips for buying a used rear axle? Like can a 2x4 axle hook up to a 4x4? Can a 2005 access cab go into a 2001 access cab? And whats the best website to look for one at? Thanks
  19. Aug 11, 2020 at 6:12 AM
    #49
    ibiggs22
    ibiggs22 New Member
    So I had this issue, my rear differential was leaking on the drivers side of the cover. It was a slow leak, about a drop an hour but I wanted to get ahead of the situation. I followed Big Paully's advice and it has not leaked in over 500 miles of driving it. Not the prettiest but it works for sure.
  20. Aug 11, 2020 at 4:26 PM
    #50
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Nice work. Make sure the vent on top of the differential housing is open and able to breath. Keeps pressure down inside the diff...
  21. Aug 12, 2020 at 5:47 AM
    #51
    ibiggs22
    ibiggs22 New Member
    Yep, made sure the breather was clean and clear!
  22. Aug 12, 2020 at 6:26 AM
    #52
    Pucks18
    What did you use? Very curious
  23. Aug 12, 2020 at 7:24 AM
    #53
    ibiggs22
    ibiggs22 New Member
    Follow the initial post in this tread from Big Paully.
    1. Pour 15 kit: degreaser, metal prep, then Pour 15 (4 coats) PS. wear freaking gloves with pour 15. That stuff will stain your hands like nothing else.
    2. Flex seal around the weld seam.
    3. 2 or 3 coats of truck bed liner.
    Took about 2.5 days because of the time it took to dry between coats. If I can do it, anyone can do it.
  24. Aug 14, 2020 at 7:04 AM
    #54
    Jimbobber10
    Jimbobber10 New Member
    2000 V8 4.7L
    Just did this job myself. Opted to replace the cover with a Dorman new one.
    1st mistake,, YOU HAVE TO GAS WELD (not electric) to retain fluid! Our 'welder buddy' used electric to booger weld it and it kept leaking and had to be re welded by a good welder with Gas.
    'While in there', I replaced the rusted backing plates, which means pulling the axles, which means do the wheel bearing, seals, etc 'when you're in there'.
    Warning, don't be fooled by the YouTube videos where these guys pop out the bearings just by banging them on the ground. Be prepared to torch them out! 2 different 20 ton harbor freight presses wouldn't budge them.
    Turned in to a 3 day hell job that saved me about $1500 over replacing the entire housing with a new housing. A used housing, shipped, off ebay would have cost me $1000- and who knows what shape the bearings in those are.
    #54
  25. Aug 22, 2020 at 6:50 PM
    #55
    TUNDRA_
    TUNDRA_ New Member
    2000 Tundra 4.7 4WD
    Please share the steps you took to complete this project. I have been thinking of doing this bolt on cover for about 3 years but never really did it. Excellent work on your part!!
    Please mention how difficult grinding the old cover was. Did you first cut it above the weld line and then grind it down? How did you achieve a flat surface.
    I think your idea and execution is the best out there so far. How is it holding up and how many miles have you driven after?
    thank you.
  26. Aug 22, 2020 at 6:52 PM
    #56
    TUNDRA_
    TUNDRA_ New Member
    2000 Tundra 4.7 4WD
    Forgot to add?
    How wide is the lip on the new cover? Is it enough to seal or do you think they should make one with a wider lip.
    tia
  27. Sep 30, 2020 at 11:00 AM
    #57
    Mdovey86
    Mdovey86 New Member
    2002 Tundra SR5
    I’m having issues with my 02 3.4l 2WD leaking. I tried the POR15 route. Did not work.
    So I have to find a rear end for my exact model? Can I use a rear end from a 4WD tundra?
    Pucks18 likes this.
  28. Sep 30, 2020 at 2:29 PM
    #58
    Kongap
    Kongap New Member
    2004 SR5 DC
    Did you try sanding and jb weld?
    N84434 likes this.
  29. Sep 30, 2020 at 4:08 PM
    #59
    N84434
    Milwaukee WI.
    2001 Limited TRD
    When I started cleaning all the rust off mine, it started to drip from a rust perforation, so I drained the differential, cleaned the area thoroughly, sealed it with Black Form-A-Gasket, painted it with my rust stop paint (Chassis Saver) and then added a second layer of the Form-A-Gasket. Has not leaked at all..... At all.
    Maybe try a good quality gasket sealer and then paint??
  30. Sep 30, 2020 at 4:21 PM
    #60
    Kongap
    Kongap New Member
    2004 SR5 DC
    don’t forget to make sure your breather is working!
