Rubbing with larger tires? Enter the Relentless Fab CMC plates!
Discussion in 'Relentless Off-Road Fabrication' started by Relentless, May 7, 2014.
  1. Aug 27, 2018 at 1:09 PM
    #121
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Yeah mine is complete already. Thank u
  2. Aug 27, 2018 at 2:00 PM
    #122
    TheBeast The Beach
    cut cut cut...:)
  3. Aug 27, 2018 at 3:37 PM
    #123
    Relentless
    Relentless [OP] Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    You bet! Fits all gen 2 and gen 3's
    ColoradoTJ likes this.
  4. Aug 27, 2018 at 4:24 PM
    #124
    I have installed several different sets of these CMC’s and highly recommend using the ones from @Relentless.
    I just recommended this to member in Denver.
  5. Aug 27, 2018 at 4:54 PM
    #125
    Relentless
    Eric
    Thanks! We appreciate it!
  6. Aug 27, 2018 at 5:54 PM
    #126
    I like to recommend quality products. So, thank you. I have installed the straight ones without the bend....that sucks.
    RelentlessFabrication likes this.
  7. Nov 4, 2018 at 1:27 PM
    #127
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Y'all have these for first gens?
  8. Nov 4, 2018 at 5:29 PM
    #128
    Relentless
    Eric
    Do not. I didn't think it was as much of an issue for the 00-06s
  9. May 1, 2019 at 8:25 PM
    #129
    Tundra_Sam
    Tundra_Sam New Member
    Anybody know the discount code for these?
  10. May 1, 2019 at 9:20 PM
    #130
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
  11. Jun 11, 2019 at 11:18 PM
    #131
    reno_tundra
    reno_tundra New Member
    2019 White Tundra CM SR5
  12. Sep 2, 2019 at 12:13 PM
    #132
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    Noticed these are not in stock online. What would the time frame be to have them available?
    woundflatout likes this.
  13. Nov 9, 2019 at 8:29 AM
    #133
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    @RelentlessFabrication Thanks for making what many say is a great product. The site says these are on backorder. If I purchase, do you have an approximate timeframe for when they will be available? I'm looking to get the cab mount chop done in the next month or so. Thanks!
  14. Nov 9, 2019 at 8:47 AM
    #134
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    I wish I had known about these when I bought mine; just to support the site sponsors.
  15. Dec 4, 2019 at 1:25 PM
    #135
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    @Relentless I picked these up local yesterday afternoon and got them tacked in last night. I was just going to cut up some 3/16" sheet and be done with it, but after I saw the bend and all happy folks, I have to say that was a good twenty-something dollars spent.
    Thanks Eric!
  16. Dec 4, 2019 at 1:34 PM
    #136
    Uhhhh....
    Dave
    7” BDS, 37s
    Did you gain a decent amount of clearance? I had it at a shop just today and the guy who will eventually do the chop/weld said he thinks adding the plates will negate most of the clearance you gain from the chop. His advice was to just chop the mount, and not weld the plates on. I know Relentless' website says there's a gain of about 1.25" if done correctly - just trying to deconflict the conflicting statements that are causing conflict in my conflicted brain. KnowWhatIMeanVern?
  17. Dec 4, 2019 at 1:53 PM
    #137
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    So, the amount of clearance you gain will depend on the cut. Not sure if the guy you talked to actually took a look or not, but the plate is 1/4". I cut out roughly 1 1/4" and inset the plate instead of setting the plate on the outside (which makes welding much easier) then tacked it up. So, where it counts, I gained 1.25"± 0.1". I only tacked them because I might take out more if needed. I had room for maybe another 1/2 inch.
    I did this pre-35s, mostly because I run a 1.25" spacer, Rock Warrior wheels, and am strapping on 35x12.5r17 Nitto Trail Grapplers which actually measure out at 34.84" 13.19".
    On the Tundra, it's not the tire height that gets ya, it's the width.
  18. Dec 4, 2019 at 2:49 PM
    #138
    Uhhhh....
    Dave
    7” BDS, 37s
    Cool, good to hear. I'll prob have them weld the plate on then. I'm running 37 12.50 20 Nitto Ridge Grapplers & have rub only in reverse at full cut. Let off half a turn of the wheel & it stops rubbing - so it's not too bad.
    Though he did say that the plate is essentially for aesthetics, as it really doesn't contribute to the integrity of the cab mount...that the chop itself doesn't diminish the cab mount's structural integrity. I was a bit surprised at that. It obviously depends on how much you cut off, but not matter how much you cut, you're still weakening it to some degree. (The guy did take a look at it, with the plates in hand.)
    You have the more aggressive Nitto tread - how you liking the Trail Grapplers? I thought about getting them, but opted for the Ridge Grapplers for quieter highway driving (I barely hear them) - I'm rarely offroad with them. Are the Trail G's very loud on highway?
  19. Dec 4, 2019 at 3:08 PM
    #139
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    I wouldn't go that far, but I can say that I know guys who just covered it with plastic and have been "heavy wheeling" for years, mostly 2nd gen Tacomas. Any time you box something in, it will create a stronger support, but it's not going to break the mount unless something else is already cracked, in which case, you'd already know.
    That, sir, will be answered tomorrow. I almost went with the ProComp MT2s again (that's what I run on my Taco) but I got a killer deal on the Nitto for Cyber Monday, so, as soon as I know, I'll let ya know. I just saw the actual width and decided the cut would be in my best interest.
  20. Dec 4, 2019 at 3:16 PM
    #140
    Uhhhh....
    Dave
    7” BDS, 37s
    Definitely post when you've driven with them. Where'd you find the Nitto deal? I didn't find anything at all for 37" Ridge Grapplers.
  21. Dec 4, 2019 at 7:33 PM
    #141
    cmack
    cmack New Member
    AZ
    2018 Burrito
    Was gonna say, the bend is what made me decide to order them from Relentless as opposed to BAMF. Shipped today. Looking forward chopping and getting them burned in...
  22. Dec 5, 2019 at 7:13 AM
    #142
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    The bend is really cool, as the skinny outer part of the mount support is the tire-biter.
    If you're doing this yourself, pay close mind to your 'rear' cut, i.e. the vertical cut closest to the middle of the vehicle. Underestimate your cut, then gradually take more material away until it fits snug. Filling in a gap with weld because you rushed the cut is a pain in the ass because of that rubber mount. It heats up so quickly, then you have to sit there like a doof and let it cool down before continuing, ask me how I found out. XD
  23. Dec 5, 2019 at 7:48 AM
    #143
    cmack
    cmack New Member
    AZ
    2018 Burrito
    Yep, I’ll be doing it myself, so appreciate that. I figured it’d be a slow job just to avoid heating up the body mount. Figured my air compressor should help a little though...
  24. Dec 5, 2019 at 7:57 AM
    #144
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    Yeah it helps, so did the 15*F temp outside. Honestly I found it easiest to just jump from one side to the other. By the time I moved over, sorted out my next spots, I just ran two ~1 inch beads on opposite sides of the plate. Once I got a rhythm down, I was golden.
    Regardless, the rubber will smoke a little bit, that's where the compressor with air gun tool comes in handy.
    cmack[QUOTED] likes this.
  25. Dec 5, 2019 at 5:38 PM
    #145
    Scary
    Scary New Member
    Sparks NV
    2012 RW
    Yes
    Local shop... Buddy owned.
    They are quiet until freeway, not a lot of noise, but I can hear them if music is off.
    Cleared 35 12.5 r17 all day with 3"coils Eibach/Toytec on 1.25 spaced RW wheels.
    Uhhhh....[QUOTED] likes this.
  26. Mar 3, 2020 at 9:12 PM
    #146
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Ordering these now, can’t wait to get my BMC done to stop the rubbing!
  27. Mar 3, 2020 at 9:25 PM
    #147
    2020Platinum
    Patrick
    Northeast PA
    @Relentless just placed an order for my 2020 Platinum, says they’re on back order, any idea when they’ll ship???...want to get my BMC done asap due to already having my 35’s on and rubbing...thanks in advance!
  28. Mar 4, 2020 at 2:53 PM
    #148
    RelentlessFabrication relentlessfabrication.com Vendor
    Sparks, NV
    Give Brittony a shout at 775-200-0544 between 9am-5pm Pacific (M-F) or email her at sales@relentlessfabrication.com
    She'll be able to give you more real time shipping info. They usually go out USPS Priority so it should be pretty fast.
    Relentless Fabrication
    www.relentlessfabrication.com
  29. Mar 5, 2020 at 4:57 AM
    #149
    2020Platinum
    Patrick
    Northeast PA
    Thanks for getting back to me!...she actually called me yesterday and said they would most likely ship today, thanks so much for the help!
  30. Mar 6, 2020 at 9:08 AM
    #150
    mahmer09
    mahmer09 SR5 4x4
    Sorry for a dumb question, what is the discount code you used for this purchase? Thanks!
