Rubbing with larger tires? Enter the Relentless Fab CMC plates!
Discussion in 'Relentless Off-Road Fabrication' started by Relentless, May 7, 2014.
  1. Oct 12, 2016 at 4:55 PM
    #61
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Great product at a great price. Keep up the great work! :thumbsup:
  2. Oct 13, 2016 at 8:40 AM
    #62
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Eric, the website says back ordered.
    I went ahead and just placed my order.#2497
    Thanks!
    -Mark
  3. Oct 13, 2016 at 9:13 AM
    #63
    Relentless
    Relentless [OP] Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    We've got em. I'll let my wife know to update stock numbers on them
    dcsleeper408[QUOTED] likes this.
  4. Oct 13, 2016 at 3:36 PM
    #64
    Master_tundra
    Master_tundra New Member
    2017 MGM limited
    I'm running method with 25mm offset with 35 tires and mine rubs slightly at the bend at full lock. This is after I had it installed
  5. Oct 13, 2016 at 4:23 PM
    #65
    TheBeast The Beach
    after the CMC plates install or the 35"s install ?
  6. Oct 13, 2016 at 6:05 PM
    #66
    Master_tundra
    2017 MGM limited
    Plates
  7. Oct 13, 2016 at 6:12 PM
    #67
    Relentless
    Eric
    Shouldnt be rubbing with that setup, might have needed to trim the body mount back farther before capping with the plate. Or possibly your alignment needs some attention to add caster/push the tire forward a bit. Do you have pictures of the body mount? @Master_tundra
  8. Oct 13, 2016 at 9:10 PM
    #68
    Master_tundra
    2017 MGM limited
  9. Oct 13, 2016 at 9:23 PM
    #69
    Master_tundra
    2017 MGM limited
    Caster is at 3.5. Welder said, if he would of cut more into the body mount the plate would not fit flush on the back side. He said we can put a small triangle plate where the bend is at.
  10. Oct 14, 2016 at 8:06 AM
    #70
    Relentless
    Eric
    Ah thats it. If you look at the OP post photos you'll see; in some cases it's helpful to cut it so the bottom of the plate is pushed in a bit to help prevent rubbing. There's really no reason it needs to be kept flush on the edge of the mount so long as it isnt too large a space to weld closed.
  11. Oct 15, 2016 at 9:30 AM
    #71
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    @Relentless do the plates come with instructions on how to install? I don't have a welder so I have to take me truck to a guy to have him put my lift and the plates on. I know it doesn't seem too complicated but I just want to make sure nothing gets messed up.
  12. Oct 16, 2016 at 11:14 AM
    #72
    Relentless
    Eric
    They do not however it is quite simple. Hold the plate to the cab mount, trace the cut area, then rough cut and hold the plate back up until final desired contour/tight fit is achieved by grinding/cutting as necessary.
    Weld plate in place a little at at time, keep a compressed air blow gun handy to cool the mount between welding in order to not burn/melt the cab bushing. Repeat for second side, then paint everything thats bare metal and you're done.
    Edit: OP has a link to a post where I outlined the procedure in the thread previously a bit more in-depth as well.
  13. Oct 16, 2016 at 12:30 PM
    #73
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    I might have asked you this before and I'm probably gonna buy the plates regardless when I do my lift anyways but on a 2015 sr5 with a Toytec boss 3" lift, TC uca's and 295 70 18 tires will they be necessary? How about with 305 70 18 or 35 12.5 18?
  14. Oct 16, 2016 at 1:01 PM
    #74
    TheBeast The Beach
    35" for sure.
  15. Oct 16, 2016 at 4:57 PM
    #75
    Relentless
    Eric
    295's- no rubbing, so long as you stay positive in the offset you should be fine (I was with +18mm offset 18x9's)
    With 35's or the larger 305/70/18s you will most likely see rubbing.
  16. Oct 17, 2016 at 1:56 AM
    #76
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    Ok thanks. I was thinking 295s with +18 method rims anyways
  17. Nov 2, 2016 at 7:20 PM
    #77
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    What's the promo code for these this month?
  18. Nov 4, 2016 at 8:25 PM
    #78
    Relentless
    Eric
    code is "TUNDRAS"
  19. Aug 29, 2017 at 5:03 PM
    #79
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    So thinking about a set of CMC plates ... Those that bought these and had them mounted, how did it work out for you. I'm current running 20x9 +20 offset wheels with 1" wheel spacers making me about a -6 offset with 295/60 Nitto ATII'S. Would like to go even alittle wider if I can ... What say you?
    dcsleeper408 likes this.
  20. Aug 29, 2017 at 6:11 PM
    #80
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    What kind of welder do you need? I have a gasless/self shielding mig welder. Would that do it or do I need a legit mig or stick welder?
  21. Aug 29, 2017 at 6:13 PM
    #81
    TNTundra08
    Blake
    2008 DC 4x4
    Dang, and that tire set up works? I barely have enough room to go bigger with my offset at +18
  22. Aug 29, 2017 at 6:20 PM
    #82
    r4z0r51o
    Dave
    I started my current set up at +20 with the 295/60/20's with some minor rubbing on the front liner and had to remove the flaps. Since I purchased fender flares I wanted to prevent the tucked in look, so I bought my Bora wheels spacers to take care of that. However in doing so I brought the cab mount into play. i think my next move is to do the chop and see if that will buy me enough room to go slightly bigger and wider on my next set of tires.
  23. Aug 30, 2017 at 9:07 AM
    #83
    r4z0r51o
    Dave
    Is this code still valid? Doesn't seem to work ...
    Edit ... Okay, got the code to work (Just had to use a different non-outdated tablet). Order placed!
  24. Sep 1, 2017 at 11:18 AM
    #84
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Dave if you haven't ordered yet
    15% - code : Laborday
  25. Sep 1, 2017 at 1:03 PM
    #85
    r4z0r51o
    Dave
    Thanks Mark, but order already placed. I'm okay with it, it's not like 15% would have saved me alot more than the 10% I got on a $25 order. Just happy that RF made a good quality product for us and hope it will provide enough clearance for my tires.
  26. Sep 1, 2017 at 4:06 PM
    #86
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    LMK who does the welding for you and how it comes out. Planning on doing this when I go bigger tires...
  27. Sep 1, 2017 at 4:26 PM
    #87
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    TRD15559, r4z0r51o and BlueBottle like this.
  28. Sep 1, 2017 at 5:00 PM
    #88
    I like the design you guys have with the bend. Today I installed a competitors CMC on a members Tundra. Not as much clearance as your design.
    I highly recommend this design guys/gals.
  29. Sep 1, 2017 at 5:19 PM
    #89
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    Just ordered mine.
    Relentless[OP] and ColoradoTJ like this.
  30. Sep 1, 2017 at 7:12 PM
    #90
    r4z0r51o
    Dave
    I really hadn't found someone just yet ... Was thinking about asking a guy I worked with who is a pipe fitter and does amazing weld work. However ...
    If Mark's guy charges a reasonable rate and is a good welder, maybe I'd try him.
    BlueBottle[QUOTED] likes this.
