Rubbing with 275/65r18
Discussion in 'Wheels & Tires' started by Rica25, Mar 17, 2018.
  1. Mar 26, 2018 at 8:18 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    O right so I took of the fender plastics behind the fog lights for the VSC issue I am having and didn't help at all...any more ideas?
  2. May 18, 2020 at 5:23 PM
    jgraphix73
    jgraphix73 New Member
    Richard
    2010 Tundra Crewmax
    Did you ever figure the problem out?
    I am having the same issue.
    Running Cooper STT Pro's in 305/70/18....have a 3/1.5 Toytect lift with Total Chaos UPC and a BMC.
    I was running the tires at 50psi (been doing long road trips with it) and never had a problem. Then lowered my psi to 42 then it started to rub (and the traction control alarm would beep) when doing certain sharper turns at decent speed (30mph +)
    Rica25[OP] likes this.
  3. May 18, 2020 at 5:24 PM
    Rica25
    Ricardo
    Tulare
    I went back to 33s I could not justify the MPGs and power loss
  4. May 18, 2020 at 5:26 PM
    Rica25
    Ricardo
    Tulare
    I think it has to do with the tires because since I got rid of them I've never had that issue again and I. An take the turns faster now on the same exact road it was doing it on
  5. May 18, 2020 at 5:27 PM
    jgraphix73
    Richard
    2010 Tundra Crewmax
    Thank you!
    I am considering going back to 33's also, but I have too much tread still.
    I will trying increasing the psi on my tires and see if that helps.
  6. May 18, 2020 at 5:57 PM
    Rica25
    Ricardo
    Tulare
    I sold mine
