Rough country lift issues HELP ! HELP ! HELP !
Discussion in 'Suspension' started by Rockin 2nd Gen, Jul 13, 2021.
  1. Jul 22, 2021 at 9:33 AM
    2mchfun
    Lack of traction bars is causing axle wrap so your pinion angle is going to shit under acceleration.
  2. Jul 22, 2021 at 9:44 AM
    Rockin 2nd Gen
    Rockin 2nd Gen [OP] New Member
    Jay
    Ohio
    2010 Tundra
    5" lift 20x12 fuel with 35" nitto ridge graplers. Full led and secaine 9" android head unit.
    Both rear views of blocks
  3. Jul 22, 2021 at 9:50 AM
    2mchfun
    Don't believe me, put a go pro on it and watch the pinion angle go to hell under acceleration. That creates very unhappy u joints. Which then makes all kinds of vibration, eventually premature failure.
  4. Jul 22, 2021 at 10:38 AM
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
    I don't disagree with your statement i have seen some videos. Lets focus on what has changed in the last 2 weeks. The truck was smooth when i drove it in for shocks. they replaced a wheel bearing and emergency brake and now its jacked up. So its either the new 2.5 shocks are bad or the other work that was done. I have a hard time believing that the new shocks have changed the geometry to cause this, but that is why i am asking for input. I ask RC if there is a difference between the 4.5" lift and 6" lift and they said they are the same other than the rear blocks. The 4.5" kit had strut spacers and the new vertex shocks eliminate that with the strut design. They said the front height should be 28" from center of hub to bottom of fender which it was and 28 3/4 in the rear which it is. I had the shop lower the coils in the front per RC recommendation in case they were set to high. Nothing has changed the issues.
    Carrier bearing could be shot, but again 2 weeks ago all was well until new shocks were installed and rear axle was removed.
  5. Jul 22, 2021 at 10:40 AM
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
    The shop pulled the drive shaft and said no weights were missing and the u joints look new. He didnt want to change the carrier bearing but lowered it some more per RC recommendation. That didnt fix the issue.
  6. Jul 22, 2021 at 10:49 AM
    2mchfun
    Different shocks affect the axle wrap because they are valved differently so that changes the geometry from previous set up, plus the carrier bearing location changed. You have a driveshaft angle issue when accelerating.
  7. Jul 22, 2021 at 10:54 AM
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
    So would that be associated to the popping and creaking ? or the drive line vibration above 55 mph ? Its smooth driving in town but thats where i hear the popping and creaking. I tried to upload a video that has the noise but this platform doesnt allow for that.
  8. Jul 22, 2021 at 12:29 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Post it on YouTube and post the link in here
    Trm904 likes this.
