RIP Pro...Long Live the Limited
Discussion in '2.5 Gen Builds (2014-2021)' started by GodlessPro, Sep 25, 2017.
  1. Dec 28, 2017 at 4:35 PM
    #91
    GodlessPro
    GodlessPro [OP] Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I posted the second angle because it is a little more obvious. The back two holes shouldn't look like that and the powdercoat cracked. I must have dropped down onto a large rock. In the last picture if you look between the back two holes, you can sort of see that there was a rock wedged in there, it must have broken off of whatever did the damage.
    The sliders did their job, no new damage to the truck!
  2. Dec 28, 2017 at 5:22 PM
    #92
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The sliders just saved you money:rofl:. Seriously, it looks like it might've saved you from a good rocker dent. Probably happened going up that hill that I couldn't make.
  3. Dec 28, 2017 at 5:30 PM
    #93
    GodlessPro
    Matthew
    NorCal
    Yep, they have already paid for themselves. I might have a little too much confidence with them on now. They are going to be beat to hell by the time I get the BAMF sliders.
  4. Dec 28, 2017 at 5:32 PM
    #94
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Oh yeah I see it really good now.. if only they were there at poker flat.. :anonymous:
    joonbug and GodlessPro[OP] like this.
  5. Dec 28, 2017 at 5:35 PM
    #95
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It'll be OK. That's why hammers come in various sizes.
  6. Jan 20, 2018 at 11:44 AM
    #96
    GodlessPro
    Matthew
    NorCal
    After telling myself I was going to get this thread updated for a couple months, I finally did something about it. It isn't 100% up to date, but better than it was.
    My current issue is trying to improve on the RCI 38 gallon fuel tank skid design. I'm really worried about the exposed nuts. They defeat the purpose of swapping out the stock skid, if I snag one of them on a rock, I'm going to have a really bad day.
    My current idea is a "nut bumper" that would be put in place of the washer. I sent the design to a couple of companies to see what it would cost to get it machined out of stainless steel.
  7. Jan 20, 2018 at 11:48 AM
    #97
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Good idea. You should look into making it out of derlin. I think it will resist damages better. Might be cheaper too.
  8. Jan 20, 2018 at 11:59 AM
    #98
    GodlessPro
    Matthew
    NorCal
    I wasn't familiar with delrin, I just looked it up. Do you think that would hold up as well as stainless? If the stainless quotes come back astronomically high, I'll take a look at other materials.
    joonbug and dcsleeper408 like this.
  9. Jan 20, 2018 at 12:06 PM
    #99
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    What about the secret mods :spy:
  10. Jan 20, 2018 at 12:25 PM
    #100
    GodlessPro
    Matthew
    NorCal
    I totally forgot about the bumpstops. I can't see them, so do they really exist?
    joonbug and dcsleeper408[QUOTED] like this.
  11. Jan 20, 2018 at 12:43 PM
    #101
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Delrin is a great idea. And, I just happen to have a bunch of it. Yep, sailboat stuff.
  12. Jan 20, 2018 at 12:45 PM
    #102
    Vizsla
    Vizsla pretend2send
    I like it, please let me know what numbers you get back, I need something also. I do not think derlin is strong enough for this application. Mine is a little better, made shims to go in between the tank strap and skid plate because mine rubbed the tank. This allowed me to use a lower profile nut, the nylon in the nylok nuts didn’t engage the threads anyhow.
  13. Jan 20, 2018 at 12:48 PM
    #103
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    With the problems and obvious lack of thought put into the 38 gal. tank skid, no way I'd order one. I feel badly for you guys.
  14. Jan 20, 2018 at 12:48 PM
    #104
    GodlessPro
    Matthew
    NorCal
    If my idea works I'll share the cad file so everyone that wants it can use it.
  15. Jan 20, 2018 at 12:50 PM
    #105
    GodlessPro
    Matthew
    NorCal
    If my idea doesn't work or I don't have enough confidence in it I'll switch back to stock before Death Valley.
  16. Jan 20, 2018 at 1:16 PM
    #106
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Derlin is used for sport bike sliders. So when the crash it slides on them. They are very strong/resistant but light and easy to mill.
    Just get a stainless cap/dome and JB weld it to the bolt lol. Who’s cares about servacibility! Haha.
    Good luck on your project. Keep us updated!
    Vizsla, joonbug, 831Tun and 2 others like this.
  17. Jan 20, 2018 at 1:51 PM
    #107
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You gave me an idea for using Jb weld for a Delrin cap. Then I remembered even epoxy doesn't stick well to Delrin.
  18. Jan 20, 2018 at 2:14 PM
    #108
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Or you can build a skid plate for your skid plate @GodlessPro :rofl:
    Seriously ... right!?!? :amen:
  19. Jan 20, 2018 at 2:18 PM
    #109
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Reminds me of Monica on Friends using the mini vacuum to vacuum the big vacuum.
  20. Jan 20, 2018 at 2:38 PM
    #110
    Vizsla
    Vizsla pretend2send
    Here is mine shimmed down(basically put washer on top of skid instead of under), with the factory nuts. Reduced the profile a bit.40E4D9EA-EB10-4AB1-A5C7-E5EC88AF3B30.jpgB9386553-8031-4583-B377-C4E843A1DC60.jpg
  21. Jan 20, 2018 at 3:29 PM
    #111
    GodlessPro
    Matthew
    NorCal
    Haha that is exactly what I need.
  22. Jan 20, 2018 at 3:35 PM
    #112
    GodlessPro
    Matthew
    NorCal
    I got in on the SCS Ray 10 pre-order so I'll be swapping soon. I think the ring on them is removable, so between that and getting wider tires hopefully I will be able to keep them in better shape than the Pro wheels.
  23. Jan 20, 2018 at 3:45 PM
    #113
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Sorry to burst your bubble. They are not removable. I asked them and was bummed too...
  24. Jan 20, 2018 at 3:51 PM
    #114
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Nope, not removable. You’re going to destroy those too. Not as much because you’ll have wider tires and deeper dish. But nonetheless they’ll still getting destroyed. :devil:
  25. Jan 20, 2018 at 3:52 PM
    #115
    BlueBottle
    '16 Platinum 4x4
    See fine print
    At least you look cool destroying them!
  26. Jan 20, 2018 at 4:14 PM
    #116
    GodlessPro
    Matthew
    NorCal
    Can I make skid plates for my wheels out of delrin? :D No, well hopefully the wider tires will help. And maybe learning to pick better lines.
    BlueBottle and dcsleeper408 like this.
  27. Jan 20, 2018 at 4:35 PM
    #117
    BlueBottle
    '16 Platinum 4x4
    See fine print
  28. Jan 20, 2018 at 5:06 PM
    #118
    GodlessPro
    Matthew
    NorCal
    Here is the other build that I have been working on today. It was late Christmas present from my amazing wife.
  29. Jan 20, 2018 at 8:36 PM
    #119
    GodlessPro
    Matthew
    NorCal
    My son is 15 now so our father son Lego time doesn't really happen anymore. He has a massive collection, mostly Star Wars.
    I'll never stop loving Lego. With the Ideas collection they have cool stuff coming out that even adults can enjoy. I got the Beatles Yellow Submarine for my birthday. When I saw the Saturn V, I dropped some very serious hints.
    joonbug, dcsleeper408 and Watt maker like this.
  30. Jan 29, 2018 at 5:22 PM
    #120
    GodlessPro
    Matthew
    NorCal
    To do list for the next 8 weeks:
    • CMC
    • Spindle gussets
    • 35" General Grabber X3's on my new Ray10's
    • Resolve any excessive rubbing.
    • Mount jerry can holders.
    • Exhaust chop behind last hanger.
    Anything I get done above and beyond those will be gravy.
