Ridge grappler
Discussion in 'Wheels & Tires' started by Joeshaker, Mar 15, 2017.
  1. Mar 18, 2017 at 7:12 PM
    #121
    Joeshaker
    Joeshaker [OP] New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    You might have to do some lift in rear. But I think you should just get the front up where you want it. Then see how it looks and drives and go from there. That's what I did and mine didn't seem to have as much rake stock as some. With 2.5 in the front and 1.5 rear. I have less than an inch of rake.
  2. Mar 18, 2017 at 7:15 PM
    #122
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  3. Mar 18, 2017 at 7:17 PM
    #123
    Its the knuckle dude
  4. Mar 18, 2017 at 7:20 PM
    #124
    rons23
    Ron
    Kill Devil Hills
    Is that directed @ me. Notsure
  5. Mar 18, 2017 at 7:41 PM
    #125
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @LOTSOFTOYS would've likely noticed a bad ball joint during alignment.
  6. Mar 18, 2017 at 7:46 PM
    #126
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    If u think something is rubbing, bring it back in. I can throw it on the alignment rack and release the turn plates. That'll allow us to turn the wheels freely with the vehicles weight on the tires.
  7. Mar 18, 2017 at 8:13 PM
    #127
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Not necessarily, the big tires had only been on for a maybe 100 miles when he did the alignment. Things could have loosened up after that.
  8. Mar 18, 2017 at 8:14 PM
    #128
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    When do you work on Sat next. I'll try to get an appointment.
  9. Mar 18, 2017 at 8:17 PM
    #129
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    It doesn't feel like anything's loose, just a thought. And if something was rubbing you would think it would still be noticeable with trac off.
  10. Mar 18, 2017 at 10:58 PM
    #130
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    The more I think about it, the more I can't see how it can be the knuckle. The unloaded part of the tire would have to be expanding inward over an inch. Maybe the tie rod end, we didn't look at that. That part of the tire might be expanding from diving into the corners. I'll try my grease pencil on that tomorrow.
    Black Wolf likes this.
  11. Mar 19, 2017 at 7:55 AM
    #131
    I just remembered now that my coworker said that his Tundra has been doing something similar. He was thinking in his case it's a bearing issue and may well be. I'll have him give me ride and also get under and take a gander to see if there is anything obvious. I already told him to take it to the dealer.
  12. Mar 19, 2017 at 7:59 AM
    #132
    Nice drive though and was great to meet Amado. Hell, we would maybe drive to Grand Junction. Maybe....:mudding:
    T-Rex266[QUOTED] likes this.
  13. Mar 19, 2017 at 10:20 AM
    #133
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Haven't done anything but look under my truck yet. It's definitely not the tie rod they are well inside the wheels on our trucks. Duh! Grasping at straws again. I really don't think it's rubbing on anything. But I think I'll go ahead and get spacers. $180 from another member shipped is pretty good. I can always re-sell them if I don't need them.
  14. Mar 19, 2017 at 10:42 AM
    #134
    The tires showed clear indicators of rubbing. The proof was in the pudding.
    Wynnded likes this.
  15. Mar 19, 2017 at 11:07 AM
    #135
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    The marks in the blue stuff didn't change after driving it more and looking at where on the tire it looks like it's rubbing. The blue coating could have gotten scuffed in handling. Maybe I'll rotate them, take pics before hand and see if there are similar marks on the other two.
  16. Mar 19, 2017 at 11:11 AM
    #136
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    It's not logical that if it is a rubbing issue that it would still do the exact same thing with the stock tires that were not a problem before the switch to big tires. Somehow those big tires messed something up. Remember that there is absolutely no noise or any indication of rubbing with the trac off.
  17. Mar 19, 2017 at 11:13 AM
    #137
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I guess I'll grab the spacers just to eliminate the chance that there is a slight rub that is just enough to set off the trac.
  18. Mar 19, 2017 at 12:05 PM
    #138
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Man I feel bad for the guys that helped you. They drove all the way to you, figured out the problem which you came on here and told everyone, and now you are saying that cant be it. God bless you man and good luck.
    Law323 and T-Rex266 like this.
  19. Mar 19, 2017 at 12:50 PM
    #139
    rons23
    Ron
    Kill Devil Hills
    Joey why would you spend $200 on spacers to correct a rubbing problem that might or might not be there. Buy ya this cheap USB bore scope and set it up on tire you think maybe rubbing. Not trying to be a ahole just $12 vs $200. Unless you are planning on running spacers, then disregard. Just trying to give you some more options. $_1.jpghttp://m.ebay.com/itm/401191563765
    Good luck Joe
  20. Mar 19, 2017 at 1:54 PM
    #140
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I'll look into that, no I don't really want to spend money on spacers that I would rather not put on my truck. I think I should save that to$ towards having @LOTSOFTOYS diagnose what the problem is. Then fix it.
  21. Mar 19, 2017 at 2:04 PM
    #141
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Like I said, I thought about the possibility of the tire hitting the knuckle more last night and realized that unless something is serious loose. There is no way that the center of the sidewall is expanding out well over an inch. I still appreciate Sean coming all the way to help me and do value his opinion. But both front wheel bearings would have to be completely gone for the tire to be hitting the knuckle. The wheels spin on a fixed axis, the wheel bearings are riding on a fixed point on the knuckle. When you turn the steering wheel the knuckles and wheels turn together. There should be no change in the orientation of the two. Plus, if I did have loose bearings. It would be quite apparent.
  22. Mar 19, 2017 at 7:18 PM
    #142
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I smeared grease pencil on the knuckles and no red on the tires and none missing off the knuckles. Although this was after letting all the air out of the bags(previously at 5 psi) and airing the tires down to 32 psi. The trac never went off when I drove it. I also pulled the wheels off and checked all the torque specs. One nut on each side of the coil overs was a little loose and the the nut on the pass side top of shock was a little loose. I don't think any of them were loose enough to have been moving around. Next I'll try putting the air bags back to 5 psi and see if that causes it to do it again. If not, I'll air the tires back up. If it still doesn't come back then maybe it was just a slightly loose coil over mount.
  23. Mar 19, 2017 at 7:29 PM
    #143
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I also noticed what looks like small heat fractures in the pass side brake rotor. The brakes feel the same as they did when I bought it and the pads have a ton of life left. But there is a possibility that I could have a slightly warped rotor.
  24. Mar 19, 2017 at 7:48 PM
    #144
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I literally work 6 days this week. Call in or wait for a day off that I have time
    GNTundra likes this.
  25. Mar 19, 2017 at 7:48 PM
    #145
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    I'm going to say a warped rotor sounds more like the culprit than your truck now liking Ridge Grapplers
  26. Mar 19, 2017 at 8:01 PM
    #146
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Im just flabbergasted that a tire shop didn't have the "specific experience" to check for rubbing.
    Wynnded[QUOTED] likes this.
  27. Mar 19, 2017 at 8:03 PM
    #147
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I really don't think there is any rubbing. Especially now with smaller tires.
  28. Mar 19, 2017 at 8:04 PM
    #148
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have to wonder if the crew in the bays aren't just told what to do rather than trouble shoot.
  29. Mar 19, 2017 at 8:08 PM
    #149
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    It could just be a coincidence and the rotors where ready to go and the added strain of the big tires finished them off. Big tires and mountain roads can wreak havoc on brakes, I hope thats all it is. Gonna have@lotsoftoys look at it in a couple weeks. I'm tired of chasing my tail on this.
  30. Mar 19, 2017 at 8:14 PM
    #150
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, it's just a bunch of kids going as fast as possible. It's all about getting in and out and on to the next.
