Replacing starter on 2002 4.7. What else while in there?
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, Dec 9, 2020.
  1. Dec 9, 2020 at 12:44 PM
    ToyotaJim
    ToyotaJim [OP] New Member
    On my 2002 4.7L Tundra I am starting to have intermittent "grinding" as I turn the key to start the truck. It starts, then grinds for a 1/2 second, and then runs great. The motor is very strong in spite of 240,000 miles.
    I know the starter is buried deep in the motor (a weird design decision) and the motor must be removed or the entire top of it removed to access the starter to replace.
    So, first question, is this the starter issue? Maybe it's hitting some damaged flywheel teeth? It's intermittent and sometimes does not make the noise.
    Secondly, with the labor involved, at 240k miles, is this a good host to just pull and replace the entire ENGINE with a low mileage or rebuilt one? I'm reluctant, since we're probably taking about several thousands of dollars to replace a motor that is very strong and probably at 1/2 of it's useful life.
    Third, I'm leaning on just pulling off the top of the motor and replacing the starter with OEM new. While I'm there (or more to the point, my mechanic), what else should I have done? Seals, gaskets, wear parts, belts, hoses, etc.?
    Thanks.
    Edited for clarification.
    theblurry1, tunyota and YardBird like this.
  2. Dec 9, 2020 at 12:50 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    My guess is that the contacts in your solenoid are toast. You're on the right track ~ replace the starter with the best unit you can find so you don't have to go back in there again any time soon.
    On our aging Lexus I was able to salvage the starter by just replacing the contacts. It's easy to R&R a starter on the Lexus V-6 ~ a V-8 1Gen Tundra, not so much.
    N84434, tunyota and ToyotaJim[OP] like this.
  3. Dec 9, 2020 at 12:51 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You don't need to pull or lift the entire motor. You just have to remove the intake manifold. I think most recommend replacing that rubber manifold gasket.
    @bmf4069 has done this job and has some pictures he might be able to share.
    TheBeast, Darkness, tunyota and 2 others like this.
  4. Dec 9, 2020 at 12:52 PM
    ToyotaJim
    Is the Solenoid tucked down in the starter, or maybe elsewhere easy to reach?
    YardBird[QUOTED] likes this.
  5. Dec 9, 2020 at 1:09 PM
    YardBird
    Jonesy
    2005 RCLB
    The solenoid on my Lexus (and I assume it's the same on a Tundra) is attached to the starter itself if memory serves.
    It was quite simple to merely change the contacts and put the unit back in service on the Lexus. A Tundra, not so much.
  6. Dec 9, 2020 at 2:47 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Gents,
    The OP is not asking if he should replace the starter motor, he's asking if he should just replace the entire engine!
  7. Dec 9, 2020 at 2:52 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Bring lunch , dinner and maby breakfast because it gonna take that long. I did mine and it took all day and then some. I didn’t cut any corners. I did thing correct that’s why it took so long. Get a factory made sensor product to you won’t have to do all over again when a cheap one goes out soon afterward good luck
  8. Dec 9, 2020 at 3:01 PM
    Professional Hand Model
    Hand Protectors
    Parts needed:
    1) New Manifold Gaskets.
    2) New Denso 2.0kw Starter which is the Heavy Duty Cold Package Starter. If yours is the 1.4kw starter then the HD 2.0kw starter will still work nicely as an upgrade. Its less$ money, as well. Win win with better starts!
    3) Maybe replace the 2 knock sensors which are right next to the starter. Huge $$$ at about $170 each.
    *** Do not skimp on aftermarket parts! Toyota Knock Sensors and Denso Starter 2.0kw ONLY!!!
    Trust me as others have learned the hard way and paid twice.
    Trip9698, theblurry1, Tundra2 and 7 others like this.
  9. Dec 9, 2020 at 3:04 PM
    ToyotaJim
    Precisely the sound advice I am looking for! Thanks. Much appreciated.
    Tundra2, N84434, tunyota and 2 others like this.
  10. Dec 9, 2020 at 5:03 PM
    zgurrola21
    zgurrola21 New Member
    Zyan
    2001 Toyota Tundra SR5 TRD OFF-ROAD
    do not replace motor, remove the intake manifold and replace the starter, make sure to go with oem intake manifold gasket, I repeat go with oem intake manifold gasket, I bought cheap ones and since they there aftermarket they didn't have no label or anything on how to place them in correctly and unfortunately I installed them incorrectly and had to replace it a year since the truck started having idling problems and eventually wouldn't start so make sure to get oem, they will have a marking to show how it properly goes in as well buy the Hanes manually book it will also show you how.
    Darkness, tunyota and ToyotaJim[OP] like this.
  11. Dec 9, 2020 at 8:18 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Op, tape off all the intake ports when you have removed the intake while you are working on replacing the starter. Helps make sure you don't get a nasty surprise because something fell in the ports and you didn't see it.
  12. Dec 9, 2020 at 8:49 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Greetings ToyotaJim! Thank you for sharing. I would choose option #3. It would be safe to assume it is time to replace or rebuild the starter considering the mileage. Based on what you are describing it is unlikely that you damaged teeth on the flywheel and if that were the case you should be able to replicate the grinding sound as the flywheel makes a full rotation. We recently replaced ours which had 224k miles as preventative maintenance with a Denso (280-0319) branded unit. I recommend watching and rewatching several videos online which can easily be found by searching “tundra 4.7 2uz-fe starter replacement removal” to familiarize yourself as they also offer helpful tips and tricks. If you decide to do it yourself consider it takes several hours so make sure to prepare yourself before diving in. I find it extremely rewarding to do it yourself. There should be no need to replace or rebuild the engine with only 240k as long as it has been adequately maintained and is running strong as you mentioned. These 2uz-fe engines are extremely durable and reliable even when neglected. I did not replace the manifold seals when I replaced the starter as I forgot to purchase new ahead but obviously recommend doing so for peace of mind. I wouldn't worry about anything less underneath the manifold. A single OEM knock sensor (89615-20090) costs more than the starter and there are (2) of them so would suggest forgoing replacing them when there is no need especially at that $$$ per sensor. Removing the manifold isn’t the most difficult job if you ever find it needs to be removed for any reason. The only aspect that makes the starter replacement difficult is getting to just (1) or (2) of the bolts/fasteners securing the starter motor for which online videos will provide all the helpful tips and tricks. Lastly, consider replacing or rebuilding the alternator given the mileage if it still has the original. If you do I would recommend a Denso (210-1065). Either way please be sure to keep us posted whichever direction you decide to go!
  13. Dec 10, 2020 at 3:46 AM
    Hand Protectors
  14. Dec 10, 2020 at 8:33 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Ok... I'm stumped. I search and could not find an answer, but what the heck is that blower doing in the Valley???
    ToyotaJim[OP] likes this.
  15. Dec 10, 2020 at 9:44 AM
    artsr2002
    'Yonder
    Isn't that part of the SAIS?
  16. Dec 10, 2020 at 10:21 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    It is.. I just watched a short video on bypassing the SAIS system. That blower is part of it.. 2005 and newer..
    Thanks for the info Art..
    Tundra2 and artsr2002[QUOTED] like this.
  17. Dec 10, 2020 at 10:33 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I might be alone on this but while the intake manifold is off, you are halfway to installing a supercharger. :D
    Trip9698, TheBeast, Tundra2 and 3 others like this.
  18. Dec 10, 2020 at 10:57 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Some advice I give to anyone replacing a starter or alternator is to have the store check it when you buy it. I've seen several new and rebuilt units that were bad right out of the box. I asked for a check on an alternator that I was going to put in my Mom's pickup and the guy at the counter started arguing that it was OK since it was rebuilt and tested at the factory. I insisted and he grudgingly tested it. It was bad. He changed his tune fairly quickly after that. A quick test at the parts house can ensure that you won't get the first one off the line on Monday morning when the rebuilder is still hung over, or the last one off the line on Friday as the whistle blows.
  19. Dec 10, 2020 at 11:26 AM
    remington351
    2006 SR5 DoubleCab
  20. Dec 10, 2020 at 12:23 PM
    dguzzi
    dguzzi New Member
    I just finished this project, it is do-able but not fun. I replaced the contacts and it works great now. Be careful of the fuel line on the drivers side. I ended up with a leak and had to replace the line with the banjo bolt, then since it was rusted to the next section I had to replace all the way back to the filter. It was a race against the temperature drop here but all good. I remembered all the right swear words to get it done.
    Mine is 2000 so no other stuff in the valley. Couple sensors.
  21. Dec 13, 2020 at 3:20 PM
    evilrb
    evilrb New Member
    Jeremy
    Might as well add a supercharger since the intake manifold has to come off... :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    tunyota likes this.
  22. Dec 13, 2020 at 9:18 PM
    artsr2002
    'Yonder
    This is the way.
  23. Jan 1, 2021 at 2:36 PM
    Hand Protectors
    How’d it turn out?
    ToyotaJim[QUOTED][OP] likes this.
  24. Jan 1, 2021 at 3:08 PM
    ToyotaJim
    Thanks for asking. This is bizarre, in a good way. I *thought* I had a starter issue weeks ago. I parked it, not wanting to damage it, until I can get it into the shop which will be in January. I have too many other things going on now. Anyway, it sat for weeks, and the battery died. I needed to change the oil, so I charged it and changed the oil. I started it probably 10 times in a 2 day period. Weather was frigid cold. Never had a hint of a starter problem.
    I have no idea or explanation...
    I wonder if it's possible that there is a weak connection but the cold moisture in the air has improved that electrical connection??
    Or maybe I have a self-healing Tundra like the John Carpenter movie car, Christine??
  25. Jan 1, 2021 at 5:06 PM
    artsr2002
    'Yonder
    I vote self healing. Has to be.
    Tundra2 and ToyotaJim[OP] like this.
  26. Jan 1, 2021 at 5:25 PM
    ToyotaJim
    It's around freezing temps tonight. Started and drove just fine to the dog park. Started and drove just fine back. This truck has nearly a quarter million miles on it, and aside from some creaks and groans here and there, and some minor paint fading, it runs strong, shifts strong, and would be a challenge for a blind folded person to differentiate it from when it rolled off the assembly line ... I'm so thrill with it.
  27. Jan 1, 2021 at 6:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    how cold was it when your starter made the noise. toyota starters are known to stick once its really cold out. (all of my toyotas start sticking around 20 degrees or less)
  28. Jan 1, 2021 at 7:08 PM
    ToyotaJim
    Early December, so not particularly cold. Maybe 50-60 degrees.
  29. Jan 1, 2021 at 7:10 PM
    empty_lord
    05 rollover special
    eh. just monitor it. sticking plungers do happen.
  30. Jan 1, 2021 at 7:12 PM
    ToyotaJim
    Interesting. I am trying to think of when I drove it PRIOR to December. I would guess, several weeks. Maybe it was just "stuck" from being idle?
