2000 tundra 4x4 Starter bolts
Discussion in '1st Gen Tundras (2000-2006)' started by Bsud, Mar 13, 2019.
  1. Mar 13, 2019 at 12:56 PM
    Bsud
    Bsud [OP] New Member
    Does anyone know the very best possible way to get the bolts out of starter on a 2000 tundra 4x4? I've gotten everything loose manifold out and down to starter. Now I've got one bolt toward passenger side loose which I could see. But from here its getting difficult.
  2. Mar 13, 2019 at 12:59 PM
    koditten
    Kirk
    Midland of the Mitten
    Subbed.
    I've always wondered what kind job it was to change those starters.
    Sorry I can't offer any support.
  3. Mar 13, 2019 at 1:00 PM
    Bsud
    PITA!
    bmf4069 likes this.
  4. Mar 13, 2019 at 1:18 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It would probably help if you could post some pictures for people to see. Can you do that?
    15whtrd likes this.
  5. Mar 13, 2019 at 2:02 PM
    Bsud
    It will be the weekend before I do anything else to it
  6. Mar 13, 2019 at 2:10 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Remove intake manifold and all hoses and wires from top of motor. Starter is underneath manifold toward back of motor/ firewall. I did it myself all day difficult job, I would replace 3 knock censors at same time so you don’t have to go back in there when they fail
  7. Mar 13, 2019 at 2:11 PM
    Bsud
    I'm down to the starter, my question was, what's easiest way to get the starter bolts out?
  8. Mar 13, 2019 at 3:01 PM
    Velociraptor4x4
    Velociraptor4x4 New Member
    Joe
    2000 SR5
    A flex head fine toothed ratchet and a deep well socket is what did the trick for me. Took me about 3 hours for the whole job.
  9. Mar 13, 2019 at 3:12 PM
    Bsud
    Did you get them from top or how you get to them
  10. Mar 13, 2019 at 3:16 PM
    Velociraptor4x4
    Joe
    2000 SR5
    Yeah from the top
  11. Mar 13, 2019 at 3:43 PM
    Bsud
    If I could get past the bar and that big wiring harness it may make things a bit easier.
  12. Mar 13, 2019 at 3:53 PM
    Velociraptor4x4
    Joe
    2000 SR5
    It's been a few months since I did mine. But if I remember right you have to snake the ratchet down in there. It's a tight fit
  13. Mar 13, 2019 at 5:11 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    Try flex head adjustable wrench, i believe it is 12 or 14 mm
  14. Mar 13, 2019 at 8:06 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Maybe something like this would help?
  15. Mar 13, 2019 at 9:24 PM
    CelticNomad
    CelticNomad New Member
    2000 SR5 Thunder Grey Tundra. Stock.
    Oh Man! Where were you six months ago when I was doing that job? I got to the starter and had to throw in the towel. I still curse those engineers who put that starter where they did.
  16. Mar 17, 2019 at 6:31 PM
    Bsud
    Well got new starter on and everything put back together and it did not fix my problem. Still not doing nothing when turn switch. You can hear the starter whining but it just will not turn the motor over. The old starter was doing the same thing. It also has a new ignition switch. So I'm stumped as to what's going on.
  17. Mar 17, 2019 at 6:40 PM
    Mike Tread lightly.
    south carolina
    sounds like a bad bendix in the starter... Take your old one to a parts store and have it checked see if it does the same thing as it did in the truck.
  18. Mar 17, 2019 at 6:43 PM
    koditten
    Kirk
    Do you have a broke tooth in the flywheel? Could you see the flywheel teeth with the starter out.
  19. Mar 17, 2019 at 6:44 PM
    Bsud
    I didn't even pay any attention to that.
