Remote Starter
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jim LE 1301, Aug 24, 2018.
  1. Sep 20, 2018 at 6:21 PM
    #61
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    it's setting off the factory alarm. The reason it doesn't go off if you unlock, lock, then start is because the factory alarm takes 60 seconds to arm after you hit the lock button. After 60 seconds from hitting the lock button, then the remote start will set off the alarm. The fix is to reprogram/adjust the remote start to do this sequence for the start process:
    - Turn off alarm (or unlock doors), start engine, Turn on alarm (or lock doors)
    fuguchan likes this.
  2. Sep 20, 2018 at 6:39 PM
    #62
    brttnorman
    brttnorman New Member
    Middle TN
    2018 SR5 Tundra
    6" rough country lift 22" fuel wheels 35" nitto trail grapplers Blacked out badges TRD rear sway bar
    Ah ok. I will just unlock it every time first until I can make it back to the place that installed it .
    Thanks!
  3. Sep 20, 2018 at 7:48 PM
    #63
    Okietundra
    Okietundra New Member
    OKC OK
    2025 Lunar Rock Platinum
    If you really want range, check out drone mobile. It is a compustar device that utilizes cell towers to send the signal to your vehicle, so anywhere you and your vehicle have a cellular signal you can lock/unlock/start/stop etc. I had it on my last vehicle and it was awesome. The downside is that you have to pay a subscription, but it was only like $30 a year I think. Through the app I got feedback on the status of the vehicle. I'm sure there are some videos on youtube on it. I just contacted a local shop and the guy wants $500 to install on the tundra.
  4. Sep 21, 2018 at 8:50 AM
    #64
    maxcala
    maxcala New Member
    Max
    L.A.
    2014 Limited Crewmax
    Nobody recommends Viper here? Anyone have any viper installed on their truck?
    crochetjohn likes this.
  5. Sep 21, 2018 at 8:54 AM
    #65
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
    I second that request for info.
  6. Sep 21, 2018 at 5:06 PM
    #66
    silverhack
    Sacramento, CA
    I have a Viper on my 2018.
    I’m pleased with the Viper product, however I think the installer/programmer who did mine isn’t very good. I’ve had to bring it back to the shop 2 times to have things fixed and get it reprogrammed. :/
    I think my problems are related to...
    1) I had it installed Nov 2017 and Viper did not have a specific rom / codes for a Tundra yet so he programmed it with the Sequoia rom.
    2) seems to work fine for a while, and then out of nowhere when I lock it, it starts saying that the trunk is open or the hood is open, so then the remote start won’t work. Both times the installer just reflashed it and the problem went away, but I think it’s real weird that it came back on it’s own without any changes.
  7. Sep 21, 2018 at 7:00 PM
    #67
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    no idea.
  8. Sep 22, 2018 at 1:30 PM
    #68
    TS18
    TS18 Northern CO
    2018 sport
    Update:: I received the correct harness from Chris. Simple swap, no splicing for tpms. Remote starter functions correctly with compustar fobs and my factory key!!! Works great!
    shhernandez74 and TomC843 like this.
  9. Sep 23, 2018 at 4:41 PM
    #69
    Michael Tregre
    Michael Tregre New Member
    '14 Tundra SR5 CM
    Notta
    Mine showed up today but the package and link are marked for a 2018 Tundra.
    Anyone else with a 14-16 installed one labeled for a 2018??
  10. Sep 24, 2018 at 1:20 PM
    #70
    crochetjohn
    So after reading through this thread and a few others. Chris, 12voltsolutions and a few others have nice easy to install setups. Then doing my own research I went with compustar so I can have the added security of a tilt sensor and add the drone later. Still allows the stock fob to remote start as well. Going to install myself with the almost plug and play harness and the T11 fob. Requires only 4-5 connections to be made manually. Install instructions attached if anyone was curious what it takes.
    silverhack likes this.
  11. Sep 24, 2018 at 4:20 PM
    #71
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I’m getting my compustar installed next weekend. Which is better the T11 or the drone?
  12. Sep 24, 2018 at 6:10 PM
    #72
    crochetjohn
    I wouldn't say one is better. They each have their purpose. The T11 and all the other RF fobs should be a default. They all differ between two way vs one way and range. The drone is att service (that you have to pay monthly for) for it to have a gps location and link it to your phone. Do the T11 and consider the drone. I'm just doing the T11.
  13. Oct 2, 2018 at 8:48 AM
    #73
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    UPDATE: The remote never arrived and I have not been able to get a hold of chris. I would not recommend this seller.
  14. Oct 2, 2018 at 1:13 PM
    #74
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    I was gonna ask you guys who else wants in on this? Like to get a group buy going if we can
  15. Oct 2, 2018 at 1:52 PM
    #75
    Jim LE 1301 [OP] Camaro Lover, SSEM # 11,TTC#179
    That is just wrong. And I totally agree with you.
    shhernandez74[QUOTED] likes this.
  16. Oct 3, 2018 at 9:34 AM
    #76
    Michael Tregre
    '14 Tundra SR5 CM
    Notta
    My replacement still hasn't shown up. While I have been able to talk to Chris via phone a couple of times, and he has replied to both emails Ive sent him, he did sound way too busy to hold a conversation on the phone. more than likely why I was sent the wrong unit to begin with.
  17. Oct 3, 2018 at 11:42 AM
    #77
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    #77
  18. Oct 4, 2018 at 4:25 AM
    #78
    atrinh15
    atrinh15 New Member
    495-93 area
    I asked Chris for a group buy cuz im local to him and he told me 4 or more to get $200 a piece. Its getting cold here at night in the New England so he must be starting to get busy. Anyone else in on this? I have 2 already just need 2 more to join for the group buy
  19. Oct 4, 2018 at 7:41 AM
    #79
    Michael Tregre
    '14 Tundra SR5 CM
    Notta
    Replacement showed up and I installed it. It works.... BUT my doors do UNLOCK for about 6secs, then relock, after the truck starts.
    As for pricing, some here have had him honor the $200 price when they mention Tundras.com. When I talked to him however, he didn't seem to know what Tundras.com was.
    All in all it works, I wont need another one so my opinion of him is irrelevant. The kids and wife are already happy the truck is cool now before they get buckled into their seats.
  20. Oct 4, 2018 at 8:24 AM
    #80
    atrinh15
    atrinh15 New Member
    495-93 area
    The reason they unlock and re-lock is to bypass the factory alarm without setting it off at least that’s what I was told
    Michael Tregre likes this.
  21. Oct 4, 2018 at 8:54 AM
    #81
    Glad it worked out Mike.
  22. Oct 5, 2018 at 7:28 PM
    #82
    crochetjohn
    Well my weekend just got a fun new addition to the schedule. Took over a week for everything to come in. It's 95% plug and play. Only have to hardwire the parking lights and the immobilizer. Everything else is plug and play. I'm skipping the hood pin switch and using the oem horn. Also don't have auto headlights to worry about.
    Once I have it all finished and test for a few days i'll update everyone on the difficulty and function of everything.
    GlockTeam123 likes this.
  23. Oct 5, 2018 at 7:36 PM
    #83
    atrinh15
    atrinh15 New Member
    495-93 area
    No one else want in on this? Just need 2 more
  24. Oct 5, 2018 at 7:36 PM
    #84
    crochetjohn
    Just realizing I thread jacked this... My bad.
  25. Oct 6, 2018 at 12:17 PM
    #85
    Michael Tregre
    '14 Tundra SR5 CM
    Notta
    Update: unit pretty much stopped working. Unless I'm only a few feet away it doesn't start.
    I'll contact Chris for a refund.
  26. Oct 7, 2018 at 6:56 AM
    #86
    atrinh15
    atrinh15 New Member
    495-93 area
    Really? Anyone else having the same problem ? Would love to get this for my truck
  27. Oct 7, 2018 at 10:26 PM
    #87
    zeekworld
    zeekworld New Member
    Let us know for sure!!
  28. Oct 8, 2018 at 8:11 PM
    #88
    Twinky
    07 double cab work horse
    Oh gawd!
    I cant believe that possibility never occurred to me... ugh..
    Pressing the brake as im getting the key in the ignition isn't even a thought that registers in my brain..
    Damn, thanks Dave.
    feel like i just learned why the square peg won't fit in the round hole.
    4x4_Angel likes this.
  29. Oct 10, 2018 at 8:29 AM
    #89
    DCslick
    DCslick New Member
    2015 Radiant Red Tundra TRD 4x4
    I am currently looking for a remote starter. It sounds like Chris is not trustworthy and his product seems unreliable. Are there any other quality remote starters out there that are reasonably priced and that are plug and play and will work on a 2015 Tundra?
    TIA!
  30. Oct 10, 2018 at 9:19 AM
    #90
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    I'm considering the Fortin Evo one
    http://fortin.ca/en/products/evo-series/evo-one/
    Heard good things
