Regearing Package
Discussion in 'Performance and Tuning' started by vanthesupreme, Mar 14, 2019.
  1. Aug 10, 2021 at 2:08 PM
    #91
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    I was really happy with their work and their price. Great group of guys. I paid $2200 OTD on a 4x4. I looked up the thread on tacoma world and someone asked about Tundras. Sounds like they'll do $2050 on a 4x4 Tundra as part of the group buy with Revolution, Nitro, or Yukon gears. This is a really good deal if you ask me. I also know they get people driving in from out of state for the work. If someone somehow gets the group buy to spill into this forum, you all might get a better price than $2050 with more buyers.
    TheBeast[QUOTED] likes this.
  2. Aug 10, 2021 at 2:17 PM
    #92
    TheBeast The Beach
    good to know thanks.
  3. Aug 10, 2021 at 2:19 PM
    #93
    TheBeast The Beach
    just plan on stopping often for the 500 miles break in period. Or get the REM polishing for another $300.
    SoCalTundy likes this.
  4. Aug 10, 2021 at 3:44 PM
    #94
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    My place to that shop is 4408km each way lol.
  5. Aug 10, 2021 at 4:51 PM
    #95
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    Can you re-gear the rear end to a higher gear? For example 3.73 or 3.23?
  6. Aug 10, 2021 at 4:56 PM
    #96
    IsaiahCanada
    Isaiah
    Calgary, Alberta
    Fair enough, my knowledge of gearing isn't great. This is good to know.
  7. Aug 10, 2021 at 6:20 PM
    #97
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Don’t forget that the transmission is a double overdrive. 4th gear is 1:1
    IsaiahCanada[QUOTED] likes this.
  8. Aug 10, 2021 at 6:45 PM
    #98
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I think tundras without the tow package had 4.10 gear instead of 4.30. You could swap diffs with a junk truck. I believe 3.90 was also available on V6 models but the axles are different.
    I wouldn't recommend it though. The toyota 6 speed has a double overdrive that is higher than other 6 speeds and especially 4 speed transmissions from years past. 6th gear in the toyota is 0.58 versus around 0.67 I think on GM 6 speed. A old GM 4 speed overdrive was 0.70.
    Grimmjeeper.com has a gearing calculator that you can play around with that is way more informative than those stupid gearing charts that always get posted.
  9. Aug 10, 2021 at 6:48 PM
    #99
    crewmaxlmt
    scott
    Also, don’t be afraid to rev it. The valve train lends itself to the higher rpm’s
  10. Aug 30, 2021 at 9:56 AM
    #100
    pjh183
    pjh183 New Member
    Patrick
    2014 Tundra
    Is this group buy happening
  11. Aug 31, 2021 at 10:49 AM
    #101
    Lucky0402
    Lucky0402 New Member
    Dane
    3/2 Lift Gear Double Pump rims 295/70r18 Nitto Terra Grappler G2s
    Check out Nitto Terra Grappler G2s 295/70r18 S116. They are P rated, 50 lbs tires, that will not need re-gearing. They are light enough that you will only lose .25 to .5 MPG as compared to stock.
  12. Oct 29, 2021 at 10:39 AM
    #102
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Necro but I think this is good info.
    I reached out to this shop today about the group buy for the $2000 regear and they are still doing it. I put a deposit of $400 down to lock in the deal and made my appt for January to give me time to decide what gears I want. This is a great deal and Miguel said they would do the needle bearing free if you buy the part or have them buy it. Said it's a half day job.
    I been leaning toward 4.88 since I don't tow and don't plan on going bigger than bfg 35s, but he said most people do the 5.29s now. Need to make a decision by mid December. I kind of want to do the polishing too but he said it's really only for the break in period. I'm going with the revolution gears since he said they are the same as nitro just quieter.
    The $500 parts and labor warranty for 10 years sounds pretty amazing considering the shop is 15 minutes from my house.
    TXTundra2722 and TheBeast like this.
  13. Dec 1, 2021 at 7:38 PM
    #103
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Okay y’all, hear me out, 5.29 on 33’s with a supercharger!:bikewheelie::burnrubber:
  14. Dec 1, 2021 at 8:08 PM
    #104
    MadMaxCanon
    Do it lol. Instant recline probably. Just make sure to do a powertrax too.
    TundraTRD08 likes this.
  15. Dec 1, 2021 at 8:09 PM
    #105
    TundraTRD08
    Wesley
    Also does anyone know every transmission gear ratio on the 5.7
