Regearing Package
Discussion in 'Performance and Tuning' started by vanthesupreme, Mar 14, 2019.
  1. Mar 14, 2019 at 1:11 PM
    vanthesupreme
    vanthesupreme [OP] I'm Batman
    OKlahoma
    2014 Tundra
    I have been looking at the Nitro 4.88 & 5.29 gear package. According to Nitro website I'm currently running 33" tires so I would use the 4.88. I noticed that the 5.29 gear package is cheaper than the 4.88. I have also found this other company by the name of Revolution Gear & Axle that has a 4.88 kit but you reuse the bearing for a lower cost. What would some of you guys recommend as far as to which package to buy? So for this question but a newbie when it comes to this stuff.
    https://www.ebay.com/itm/Revolution...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
    Mnorris1206 likes this.
  2. Mar 14, 2019 at 1:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You dont need either for 33’s.
  3. Mar 14, 2019 at 1:12 PM
    15whtrd
    15whtrd Mr. Blonde
    I think I’d want new bearings. But I’m not an expert.
    chugs, Grumpy Uncle, Rica25 and 3 others like this.
  4. Mar 14, 2019 at 1:14 PM
    15whtrd
    15whtrd Mr. Blonde
    But 4.88 would be fun! 5.29 is way too much for 33’s. Maybe he intends on jumping up in tire size.
    trayday, Mountun Goat and Rica25 like this.
  5. Mar 14, 2019 at 1:15 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    4.88s on 33s would be a dragster!
  6. Mar 14, 2019 at 1:20 PM
    Mnorris1206
    08 tundra
    I suggest keeping your money. I run 35s on my truck and pull my camper no problem. Stock gears. Now if I come on here one day and say well time for a new transmission I guess that's what I deserve but I don't think it will happen .
  7. Mar 14, 2019 at 1:27 PM
    15whtrd
    15whtrd Mr. Blonde
  8. Mar 14, 2019 at 1:39 PM
    TXTundra2722
    2015 Black Tundra
    If you're going to spend the money on gears... you always want to spend the money on bearings/seals. It might be cheaper initially, but it could cost you twice as much in the long run.
  9. Mar 14, 2019 at 1:54 PM
    vanthesupreme
    OKlahoma
    2014 Tundra
    Just bought 33" tires so not going up a tire size anytime soon
    15whtrd[QUOTED] and Rica25 like this.
  10. Mar 14, 2019 at 1:56 PM
    Mnorris1206
    08 tundra
    15whtrd[QUOTED] likes this.
  11. Mar 14, 2019 at 1:57 PM
    vanthesupreme
    OKlahoma
    2014 Tundra
    I was reading through the other two threads listed. I might have to turn on the tow/haul button and see how the performance is for a period of time.
    15whtrd likes this.
  12. Mar 14, 2019 at 1:57 PM
    vanthesupreme
    OKlahoma
    2014 Tundra
    Yes from I have found it you have the tow package.
    Mnorris1206[QUOTED] and 15whtrd like this.
  13. Mar 14, 2019 at 1:59 PM
    Rica25
    Ricardo
    Tulare
    I had 33 and went to 295 70 18 which is little higher than 34 now I wish o would have stayed lower size due to having to re gear.....my truck definitely feels heavier and a rougher ride now I'm trying to get rid of my tires so I dont have to re gear......only thing I like about this size is the look
  14. Mar 14, 2019 at 2:05 PM
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    IMO I would say that re-gearing would be a waist on a 33" tire. I had 33" on my FJ and re-geared due to the V6 engine (also cause Toyota did it for free). I feel with the bigger V8, the re-gear wouldn't make sense unless you ran 34"+.
  15. Mar 14, 2019 at 2:05 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes sir! Unless it’s a 4.6 without the tow package.
  16. Mar 14, 2019 at 2:07 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s just a rougher ride due to the E rating and more weight right? I will be jumping up to 33’s when my tires wear out. I know it’s not the consensus around here but I’m trying to keep the truck quick without needing a re-gear. I’m also seriously considering not even jumping up to an LT or E rated tire
    Rica25[QUOTED] likes this.
  17. Mar 14, 2019 at 2:11 PM
    15whtrd
    15whtrd Mr. Blonde
    The tow haul button will make the throttle more sensitive making it feel like the truck is quicker. It also changes the shift points so it holds a gear out for longer. There are also a few devices that can just change the throttle response without messing with the shift points. I use a bully dog and it makes the truck feel quicker without really adding much horsepower. I think it’s mostly in the throttle response.
  18. Mar 14, 2019 at 2:18 PM
    PNW-Tundra
    PNW-Tundra New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    Curious why you say you have to re-gear? I’m runnning 295/70/18 and re-gearing has never crossed my mind.
    tttrdpro, TheBeast and Rica25[QUOTED] like this.
  19. Mar 14, 2019 at 2:25 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    if you downsize the tires, the yodagan sticker will have to come off... :cool: :cheers:
    boardude, Kilos, Darkness and 4 others like this.
  20. Mar 14, 2019 at 2:38 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Im on 295/70/18 MT's and have not regeared. I think regearing for 33's is overkill especially for the price it carries - gears and install. Rather spend money on other mods
    TheBeast and Rica25 like this.
  21. Mar 14, 2019 at 2:47 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Bearings can easily be damaged when trying to pull them off of the differential case or pinion. It's worth buying the new bearings when you get new gears.
  22. Mar 14, 2019 at 3:47 PM
    Rica25
    Ricardo
    Tulare
    Down shifting on any highway minor up hill climb and loss of power
    Hbjeff and TacoWuzzaTurd like this.
  23. Mar 14, 2019 at 4:29 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I'm running a 34" tire and it's been recommended that I go 5.29's. mostly because our 5th & 6th gears are both overdrive gears and 6th is a tall 0.58 I thought 4.88's but due to added mods and weight, the 5.29's would put me in a power band almost ALL the time. I'm still debating, but all the arrows are pointing towards 5.29's. and if I want I can jump up to a 35" tire and still be in the sweet spot.
    Rica25 likes this.
  24. Mar 14, 2019 at 5:12 PM
    MJ_19Tundra
    MJ_19Tundra Ain't nuthin but a G thang
    Ben
    Nashville, TN
    2023 PEARL PLATINUM
    I been on 35s and stock gears for a week. Ain't really noticed a distance. Still squal the tires when I pinch it
    Rica25 likes this.
  25. Mar 14, 2019 at 6:06 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    If you re-gear, your truck will still look badass, but get up and go as if it were stock... It is something that I have found to be an absolute must with any increase in tire size. I already have the quote to do the work, I just have to file my taxes first. Then it is Game On for gears!
  26. Mar 14, 2019 at 6:24 PM
    Rica25
    Ricardo
    Tulare
    Was quoted 1450.00 For 2wd
    Toyotoholic[QUOTED] likes this.
  27. Mar 14, 2019 at 6:25 PM
    Rica25
    Ricardo
    Tulare
    If I could afford it I would do it quick but unfortunately I can't so now dont know what to do
  28. Mar 14, 2019 at 6:52 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Drive with the Tow/haul button on and enjoy your truck. Put the gears high on the "must-do" list, and when you can, do it then. (This mod took many months of waiting for me and they are still Not done yet!) So don't sweat it. Also try driving in "S" sequential shift mode. It will allow you to stay in gears longerl remain in a better powerband. I'm almost never in 5th or 6th.
    TundraTRD08 and Rica25[QUOTED] like this.
  29. Mar 14, 2019 at 7:00 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I was quoted $3k for 4wd out the door, if they supply the gears. (Nitro). I called Nitro and they confirmed the dealer legitimacy of the shop. I've done other work with this shop and everything continues to line up in a very positive way. A good gear shop is a rare find in my neck of the woods. ( Within a 2 hour drive there are only 2 shops I would trust).
  30. Mar 14, 2019 at 7:09 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Did that include the gears?
