Regearing Package
Discussion in 'Performance and Tuning' started by vanthesupreme, Mar 14, 2019.
  1. Jun 14, 2020 at 3:44 AM
    #61
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Absolutely true!
  2. Jun 14, 2020 at 7:36 PM
    #62
    ZPMAN
    Minnesota
    I did the Revolution gears without the bearings, truck had less than 20,000 on it and if you are careful and have the right tools you can reuse the old bearings. Without beer and a gun to my head I can have the rear punkin out in a 1/2 hr and the front in less than 1 1/2.
    Rica25 likes this.
  3. Oct 4, 2020 at 7:14 PM
    #63
    Boyd8019
    Boyd8019 New Member
    Bob
    Las Vegas, NV
    2020 White Tundra TRD Sport
    BDS 7" lift, 20x10 Fuel "Lethal" wheels, 37x13.50R20 Cooper Discoverer STT PRO tires, AMP Research PowerStep XL electric running boards, Line-X spray in bedliner, 6" BAM Muffler from Dirty Deeds.
    Posting here mainly for the ability to find this thread later. On the 20th I will be getting the Nitro 5.29's with a Powertrax LSD unit installed. My math came up with 4.967 for gearing. According to Keith @ Dirty Deeds, he likes the Powertrax as a better option to the Auburn and a FAR cheaper option than the Eaton E-Locker. I'm running a 2020 TRD Sport with 37" Cooper STT PRO tires on 20x10 -12 wheels. What little time I have spent on the highway has been very frustrating. The truck is always searching for a gear and spends a lot of time in 3rd, 4th, & 5th trying to hold 70 mph. It only goes into 6th when going downhill & as soon as the road levels out drops back to 5th. So far the best average mpg I have attained is 11.6, and only once in 3300 miles. Mostly getting 9.9 or less combined driving.
  4. Oct 4, 2020 at 7:23 PM
    #64
    Tundrafan23
    Tundrafan23 New Member
    Do you have the 5.7?
  5. May 5, 2021 at 11:55 PM
    #65
    Cosmo10
    Cosmo10 New Member
    2010 Tundra Rock Warrior
    I went from 285/70/17 to 35s.... huge difference. I was going from 280miles to the tank to 190, mostly 180 miles to the tank with the 35s. All I want is MORE CLEARANCE! Lol!
    D4x4TRD likes this.
  6. May 7, 2021 at 7:11 PM
    #66
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Just curious, do you drive aggressive? My last couple tanks I've been avg 16mpg, and I have skinny 35s and around couple hundred lbs of stuff in the bed all the time, I also don't drive gently.
  7. May 7, 2021 at 11:03 PM
    #67
    Cosmo10
    Cosmo10 New Member
    I feather that pedal now since the 35s. I just filled a full tank just now so I’ll double check my MPGs. But I’m sure I average 11 MPGs.
  8. Aug 4, 2021 at 12:15 AM
    #68
    Pipusplace
    Pipusplace New Member
    Josh
    TRD PRO 17
    I have a 17 trd pro added coachbuilder +3 shackles and I added 35's KM3's. I just bought a 30ft travel trailer weights about 10k lbs. Thinking of adding airbags and was told to look into regear to 488. What will the regear help with?
  9. Aug 4, 2021 at 7:03 AM
    #69
    Downytide
    GTA
    Go with 5.29
    Mine is towing 10k like a champ.
    TXTundra2722 and snivilous like this.
  10. Aug 4, 2021 at 12:47 PM
    #70
    Pipusplace
    Josh
    TRD PRO 17
    Do you have airbags? What does the 5.29 do?
  11. Aug 4, 2021 at 1:27 PM
    #71
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Regearing changes the amount of torque going to your tires. More torque = more force applied to the ground. Increasing the size of your tires has the opposite effect, and decreases the amount of force going to the ground. An analogy would be you're driving around in 2nd gear, if you increase tires it's like being in 3rd gear where the truck has to work harder, and being regeared is like being in 1st gear where the engine is revved up more but pulls a lot harder. Regearing will decrease stress on the engine and transmission and driveshafts since the higher ratio gears are increasing the mechanical advantage multiplier in the differential. Less stress, more torque to pull your trailer and accelerate, however it runs about $4k and you have to regear both the front and rear differentials.
  12. Aug 4, 2021 at 2:36 PM
    #72
    07KingTundra
    07KingTundra New Member
    Scott
    07 Tundra Limited
    King, Icon, General
    on my 07 I have 315/70R17's and I don't think I need to regear at all. It has plenty of power and the transmission hardly searches for gears. Even towing my TT which weighs around 5k fully loaded, it does awesome. I guess I could regear but right now I don't think the benefit outweighs the cost.
  13. Aug 8, 2021 at 10:04 PM
    #73
    Pipusplace
    Josh
    TRD PRO 17
  14. Aug 8, 2021 at 10:06 PM
    #74
    Pipusplace
    Josh
    TRD PRO 17
    That's a lot of money. Do you think my tundra will have issues pulling a 10k lbs trailer with the bigger tires? Will my transmission fail quicker?
  15. Aug 9, 2021 at 10:20 AM
    #75
    Downytide
    GTA
    How big of tires? I've seen guys towing with 37s fine, transmission should be fine as long as you stick with regular maintenance.
  16. Aug 10, 2021 at 8:06 AM
    #76
    Pipusplace
    Josh
    TRD PRO 17
    My tires are 35's. I seen post about transmission oil cooler is that something that would benefit the transmission running cooler oil?
  17. Aug 10, 2021 at 8:30 AM
    #77
    TheBeast The Beach
    BFGs are on the small side for 35"s.
    FYI: there is a group buy on tworld forum right now. was quoted $2100 for re-gearing 5.29 or 4.88. Includes master kit. front and rear 4x4. Labor/parts included. In SoCal. Hard to beat imo.
  18. Aug 10, 2021 at 9:49 AM
    #78
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    This is a very cheap price. I am getting gears and lockers installed tomorrow and they are going to need my truck for two full days. The gears and install kits alone were nearly $1800, granted the gears are Motiv and the install kits are Yukon.
  19. Aug 10, 2021 at 10:18 AM
    #79
    TheBeast The Beach
    yeah some people driving from out of state for the group buy.
    this is the second one they are doing. They did 150 ish tacomas on the first run.
    3 to 4 hours per truck looks like.
  20. Aug 10, 2021 at 10:23 AM
    #80
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Do you happen to have a link to this thread? That's a pretty good deal
  21. Aug 10, 2021 at 10:30 AM
    #81
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    What shop is doing the group buy? I recently did mind back in June at Premier West Gears in Riverside. For the record, I did 5.29 Revolution gears for the fact that they are quieter than Nitro. I have 35' tires and don't really tow anything heavy. Although I didn't go with 5.29 for better gas mileage, I was hoping for an improvement and got nothing out of them. Lot's of nice power though. A part of me feels I should have gone with 4.88.
    TheBeast[QUOTED] likes this.
  22. Aug 10, 2021 at 10:34 AM
    #82
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Hmm...for some reason I thought Nitro and Revolution gears were manufactured at the same facility. :confused:
    What size tires?
    Towing?
  23. Aug 10, 2021 at 10:40 AM
    #83
    SoCalTundy
    Yep, read a few comments on here that Revolutions were quieter and the guys at the shop told me the same. 35 inch tires and only tow a utility trailer with ATV's. I initially experienced a whine when decelerating, but that's gone now. No noise coming from gears.
  24. Aug 10, 2021 at 10:55 AM
    #84
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    @TheBeast what group buy are we talking here?
  25. Aug 10, 2021 at 10:55 AM
    #85
    Downytide
    GTA
    Your truck should have them since it's a 2017, you should be golden!
  26. Aug 10, 2021 at 12:36 PM
    #86
    TheBeast The Beach
  27. Aug 10, 2021 at 12:37 PM
    #87
    TheBeast The Beach
    yes that's them. Are you happy with the job ?
  28. Aug 10, 2021 at 12:45 PM
    #88
    Downytide
    GTA
  29. Aug 10, 2021 at 12:47 PM
    #89
    fisherman951
    Tony
    2017 crewmax 4x4
  30. Aug 10, 2021 at 1:02 PM
    #90
    Cfincke
    San Antonio
    I regeared last year to 5.29s and i was on 295/70/18s (34.3x11.5). It made towing our 5500lb travel trailer so much easier thru the texas hill county.
    Stock gears and 295s - i had to tow in S4 and it would drop down to 3rd and sometimes 2nd gear when going up hills. Trans temp would climb up in the 230s and run around 215
    5.29s with the 295s - i could tow in S5 on the highway at 70mph easy and just downshift to 4th for hills, 3rd if i really pushed it. I had the power to pass and a lot better acceleration. Trans temps would stay between 190-200
    5.29 and 37s - i tow in S4 now and still have good power to accelerate. It does down shift to 3rd for larger hills. Trans temps stay between 195-203. I have tried S5 and it ends up shifting down to 4 for shallow grades or any acceleration, plus trans temps go up.
    I recently put on air bags as my leafs are showing signs of flattening out, happened after a 3k mile road trip towing, i have a 1k lbs WDH too.
    Pipusplace[QUOTED] and iHacker like this.
