Recovery strap suggestions?
Discussion in 'Recovery & Gear' started by FirstGenVol, Dec 30, 2018.
  1. Dec 11, 2019 at 10:36 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    closed loop. Strap flies off the hitch ball and it's pretty dangerous.
  2. Dec 11, 2019 at 11:04 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Even worse than that strap coming off the ball, the ball can break loose. This is a video I found of someone testing this - they were pulling really fast but it does show the ball snapping off (just skip to the 4:29 mark):
    https://youtu.be/eFD4Fd03bq8
    joonbug, theraven and KarmaKannon like this.
  3. Dec 11, 2019 at 11:10 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    take the stinger out , Use the pin inside the hitch receiver
    KillaahCam likes this.
  4. Dec 11, 2019 at 1:18 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Recovery Hitch.
  5. Dec 11, 2019 at 1:57 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    jordan0317 likes this.
  6. Dec 11, 2019 at 2:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Billet, made in USA.
    http://www.billet4x4.com/pro-kinetic.htm
    joonbug likes this.
  7. Dec 11, 2019 at 3:04 PM
    Zero One Actual
    Check out and/or call the guys at Factor 55. They are about the most knowledgeable winching experts in the industry right now.
    theraven and smslavin like this.
  8. Dec 11, 2019 at 3:30 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Whatever you choice,You can't get it too strong! Passed experience tells me when you can't pull it easy then it seems everyone backs up to get some "slack"and then hit it wide open! Also a good idea to get a heavy blanket to let at on the chain,strap or whatever you are using.BACK WINDOWS AND TAILLIGHTS ARE EXPENSIVE!!!
    BravoDeltaRomeo and jordan0317 like this.
  9. Dec 11, 2019 at 3:31 PM
    tenntundra
    Walter
    Tennessee
    I have a 10 ft strap that was used to pull bull dozers out. I'm not too worried about breaking it!
  10. Dec 12, 2019 at 3:32 AM
    Zero One Actual
    Remember, if you don’t have a blanket, a jacket will work or anything else you can drape over the line to absorb the stored energy causing it to fall downwards to the ground rather than flying like a sling shot to the left or right or whatever direction.
    rmvcard0303 likes this.
  11. Dec 12, 2019 at 3:57 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    That was my setup for a while. I was a little worried about the end of the hitch chafing the strap if I had to pull or be pulled off to the side at all. I watched a video where a guy was saying I go off road x amounts of times and I'm an expert and you don't need those d ring receiver mounts. Oh well I got mine for under $30 and used a grade 8 bolt to attach it so I'm no longer worried about chafing the strap at any reasonable angle. I also tightened the shackle with an adjustable wrench so it's on there unless you use tools which I always have within feet of the shackle anyway.
    I doubt a hitch pin would fail, but a solid sleeve pulling on a pin is still stronger than a somewhat flexible strap.
    831Tun likes this.
  12. Dec 12, 2019 at 7:40 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's a really good idea to "seize" or "mouse" the pin. Basically, a wire or zip tie through the hole on the pin and around the shackle to keep the pin from from inadvertently spinning out if you plan to leave the shackle attached.
  13. Dec 12, 2019 at 8:13 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
  14. Dec 12, 2019 at 8:24 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    I found the equivalent to bubba rope with a soft shackle that was locally made at a 4*4 shop for about a third of the price. Forget what it was called, cannot really comment on it’s effectiveness yet :fingerscrossed:
    BravoDeltaRomeo likes this.
  15. Dec 12, 2019 at 8:28 AM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    PLEASE! if you use the ball for a recovery mount, please loop around your hitch pin instead for the occasional recovery. Using the ball is extremely dangerous as previously stated.
    Do some research and have the safe equipment and knowledge to use it if you plan to “help” anyone including yourself.
    Outbound and BravoDeltaRomeo like this.
  16. Dec 12, 2019 at 8:38 AM
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    Been pullin with the ball for 40 years, never saw a problem. Not an everyday thing, or pulling bigass heavy trucks, but pullin people outta snow or little muddy situations- BUT - I like the shackle hitch and will get one of those and save the ball for trailers.
    KarmaKannon likes this.
  17. Dec 12, 2019 at 8:57 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I haven't seen the video but @csuviper said there's one where not 1 but 2 people are killed by a ball breaking loose while pulling. Risks VS Rewards. I'll never use the ball again.
    BestGen, Skey44, joonbug and 2 others like this.
  18. Jan 1, 2020 at 10:53 PM
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Thanks for the very informative post. I used this as my buying guide.
    joonbug[QUOTED] and 831Tun like this.
  19. Jan 14, 2020 at 6:00 PM
    #49
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
  20. Jan 14, 2020 at 6:43 PM
    #50
    Outbound
    Aaron
    Northern Alberta
    I'm eyeballing a Smittybilt recovery hitch. Seems well made.
    khunk likes this.
  21. Mar 24, 2020 at 6:46 PM
    #51
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
