Rear View Trailer Camera
Discussion in 'Towing & Hauling' started by Ruggybuggy, Jun 25, 2021.
  1. Mar 7, 2022 at 7:31 PM
    avssuc
    avssuc Efilnikufesin
    Gulf Coast
    2021 Tundra TRD Pro LR
    I got the same thing, towed with it twice, then on the 3rd trip, it went out. Came home, emailed the company, they told me it was 6 days out of warranty, so basically they told me to f**k off.
    The display was washed out, and it was generally a POS. I'm currently looking for anything better than this pile.
    TundraTex and Ruggybuggy[OP] like this.
  2. Mar 9, 2022 at 7:07 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    If your trailer is prewired that is half the battle! And if your Furion wireless receiver is still good, then the FRAC Harness and Video adapter kit will take care of the rest. The trailer Cam video will then be available for display on your Head Unit.
    avssuc[QUOTED] likes this.
  3. Mar 9, 2022 at 7:32 AM
    Solv3nt
    Solv3nt New Member
    Oregon
    2021 SR5 Off-Road 4x4
    Driver side grab handle, Genuine Cooling System Transmission cooler package, Max Modular Bed Rack, White Knuckle Off-road sliders, undercover ultra flex tonneau cover
    Where does the receiver mount with this setup?
  4. Mar 9, 2022 at 7:43 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    There is no pre-determined location. Ideally you want it located as close as possible to the FRAC VSM (i.e. in the head unit bay). The receiver will have an antenna attached and the antenna orientation is important for maximum receiver sensitivity. This directly affects the range of your wireless connection. I would hard mount or double-side tape the receiver to the back of the HU bay with the antenna extended vertically (or as vertical as space allows) for maximum range performance.
    avssuc likes this.
  5. Mar 9, 2022 at 7:57 AM
    Solv3nt
    Solv3nt New Member
    Oregon
    Ha! I just read about the negative Furion. I'm leaning towards hard wiring.
    avssuc and TundraTex[QUOTED] like this.
  6. Mar 9, 2022 at 8:04 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    That takes a little more work, but it's definitely the best way to go.
  7. Mar 9, 2022 at 8:11 AM
    Solv3nt
    Solv3nt New Member
    Oregon
    My trailer is pre-wired for a camera, I'm guessing that means power only.
    avssuc likes this.
  8. Mar 9, 2022 at 8:41 AM
    avssuc
    Gulf Coast
    Indeed it is, but just for power. You mentioned an antenna attached to the HU to grab the signal? My Kenwood DNR 1007 has 4 camera inputs, 2 are free.
    If I wanted it on my HU, all I need to do is pull the HU, grab a remaining input, slap the receiver in there, and I'm golden? What are the specs on the cam? Any idea on when you might have some operational pics or videos? Everything sounds awesome!
    TundraTex[QUOTED] likes this.
  9. Mar 9, 2022 at 10:17 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. It's as "easy" as that. Or you can run an RCA cable all the way from the camera to your head unit. (Through a bumper bulkhead connector).
    The Head unit doesn't care where the video comes from. So it should work great in one of your open RCAs. There are lots of different wireless video transceiver systems out there. I don't have a specific recommendation for those since I prefer to use the RCA cable method.
    I'm working on my kit instructions and posting at the moment. Once things warm up a bit, I plan to video the entire installation process.
  10. Mar 9, 2022 at 10:19 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Usually that is the case in my experience. The power is generally connected to your running light circuit. So to power the trailer cam during operation you just need to turn on the running lights.
  11. Mar 9, 2022 at 10:38 AM
    Solv3nt
    Solv3nt New Member
    Oregon
    How did you install the bumper bulkhead connector? Do you have any pictures?
  12. Mar 9, 2022 at 10:47 AM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Solv3nt[QUOTED] likes this.
  13. Mar 12, 2022 at 1:14 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
