Rear Diff has metal fragments in it.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by YotaBro, Sep 18, 2020.
  1. Sep 20, 2020 at 6:28 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I have 1000 miles new Taco ones too lol. I might weld them into art or something.
    rockmup[QUOTED] likes this.
  2. Sep 21, 2020 at 11:32 AM
    Elduder
    Elduder New Member
    Got to take that in, leave it alone and whatever caused that to break off will remain unaddressed, leave it alone and any other broken pieces can lead to total failure, or worse a seized rear end. As already stated that appears to be one of the teeth off the ring, it should not have broken off. Either backlash is not set right and there is improper contact or perhaps the cast is poor and the gear set itself may be at risk for further failure.
  3. Sep 21, 2020 at 1:52 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    That’s a nice offer. !! You could be in the pay it forward thread.
  4. Sep 21, 2020 at 3:57 PM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    Thanks for all of the help guys! I had her towed this morning to the dealership. The serviceman that I am working with sent the picture to Toyota to make sure that he can open it up. He plans on opening her up tomorrow morning. He reassured me that the powertrain warranty will cover the expenses so that is a huge relief. I will keep y'all posted once I know more!
  5. Sep 21, 2020 at 4:22 PM
    18" TRD Off Road Wheels
    Get that assurance from him in writing. Always C.Y.A.
    Inquiringone likes this.
  6. Sep 22, 2020 at 2:10 PM
    YotaBro
    Calvin
    FL
    Update ***
    Got the truck back today. The dealer is claiming that they could not find anything wrong with the gears. They swapped out the old chunk with a brand new one.
  7. Sep 22, 2020 at 5:07 PM
    Inquiringone
    Ter
    NorCal 408
    Did you ask to see the old parts?
    Either way your truck is fixed.
    Have some fun now.
  8. Sep 22, 2020 at 5:40 PM
    YotaBro
    Calvin
    FL
    Oh yeah, I don't trust dealers. I saw the old one and I also looked at my truck and found the new one was actually attached.
    Inquiringone[QUOTED] likes this.
  9. Sep 22, 2020 at 5:44 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What do you mean they swapped out the old chunk with the brand new one?
    Black Wolf likes this.
  10. Sep 22, 2020 at 5:58 PM
    :notsure:
  11. Sep 22, 2020 at 6:39 PM
    YotaBro
    Calvin
    FL
  12. Sep 22, 2020 at 7:40 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  13. Sep 22, 2020 at 7:51 PM
    Redcon41318
    Redcon41318 New Member
    Good ol boy eh
  14. Sep 22, 2020 at 7:53 PM
    YotaBro
    Calvin
    FL
    Yeah the serviceman kept referring it to chunk, so i guess it stuck. I think he just meant the whole assembly but im not complaining.
  15. Sep 22, 2020 at 8:02 PM
    TheBeast The Beach
    nice ! now break it in easy
    JohnLakeman likes this.
  16. Sep 23, 2020 at 4:54 AM
    YotaBro
    Calvin
    FL
    Any suggestions on how to break it in?
  17. Sep 23, 2020 at 5:14 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The carrier assembly is the center frame and input shaft housing with ring gear, pinion, and drive flange installed. The gears come pre-adjusted (lash and tooth surface contact), i.e. done under controlled precision conditions at the factory. The technicians can bolt it in, fill it with oil, and done.
    Gearset adjustment in the field is mostly a lost art. It was time-consuming, and required expertise and patience found only in experienced craftsmen.
    The operative word for "break-in" is "easy". It's the exact same gearset as came in it...follow the owner manual's advice.
    Sumo91, Inquiringone and DZ_ like this.
  18. Sep 23, 2020 at 8:31 AM
    Inquiringone
    Ter
    NorCal 408
    Atta boy...great job. I was hoping you would say that. :thumbsup: You stuck to your guns:quickdraw: got it done.!!!
    Not sure if you ponder this thought... where did those pieces come from if the third member was good.
    Enjoy that Tundra find some dirt.:mudding:
    YotaBro[QUOTED][OP] likes this.
  19. Sep 23, 2020 at 8:50 AM
    #49
    TheBeast The Beach
    I would say drive the truck easy for 500 miles. no towing or burn outs :)
  20. Sep 23, 2020 at 9:04 AM
    #50
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I hate having to get the gear mesh correct, but it's not too terrible, just takes alot of patience like you said. Been years since I've done it, but when worked on a fleet of 16 old concrete haulers, I was the only mechanic there, and boy oh boy did I have some nerve racking projects to do.... my least favorite was rebuilding the Eaton transmissions in them. They had 3 gear shafts, each with 3 gears on them, a primary, intermediate, and secondary intermediate shaft. Trying to get those bastards all meshed and synced correctly with only 2 hands was a pain, and there was more than one wrench thrown across the shop during the time.....
  21. Sep 23, 2020 at 9:17 AM
    #51
    P-Factor
    P-Factor New Member
    I was rear ended many years ago and on impact the ring gear over stressed the pinion gear and sheared a fragment very similar to what you found.
    Was your truck ever involved in an accident by chance? Just a thought...
    jetfishn likes this.
  22. Sep 23, 2020 at 11:41 AM
    #52
    YotaBro
    Calvin
    FL
    Yeah, ive thought a lot I still think that it came off of one of the gears but not sure which one.
  23. Sep 23, 2020 at 11:42 AM
    #53
    YotaBro
    Calvin
    FL
    No, the only thing that I've noticed is a slight scratch mark on the rear bumper like the previous owner hit a cement pole while parking but I dont think it would cause something like that.
