Rear diff cover
Discussion in '1st Gen Tundras (2000-2006)' started by rickybobby6969, Mar 8, 2020.
  1. Mar 8, 2020 at 9:07 AM
    rickybobby6969
    rickybobby6969 [OP] New Member
    2003 tundra extended cab 5 speed
    As many people know toyota sometimes makes things hard for no apparent reason. The rear diff on many first gen tundras when exposed to salt rust out and begin to leak. The DIY method of fixing for many is J.B weld. I’ve tried I have 3-4 things of jb weld on that thing and she’s still pissing. So I have priced out the new cover for it. 75 bucks what a steal but has to be welded on. Now I am a shitty welder but could do it my only concern is what happens when I blow the rear end and need to rebuild it. If I weld on my cover I won’t be able to do it without cutting it off. So what I am asking is is their a way to drill and tap holes into the axle so I don’t have to weld it on. I would ya gasket maker so it wouldn’t leak.
  2. Mar 8, 2020 at 10:18 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    For the weld-on cover, I'm thinking you would need a certified pipe welder (or similarly qualified) to get a leak-tight weld joint. Regards drilling, tapping for plug, rust occurs generally and seldom at a single point, so there is likely to be thinning all around the leak that will soon rust through. Considering the debris from the cover removal and the welding procedure, it is probably easier to simply transfer the internals to a new housing or replace the differential complete. Previous threads on this problem below:
    https://www.tundras.com/threads/rusted-leaking-rear-differential-cover.27684/
    https://www.tundras.com/threads/replacing-differential.59874/#post-1570269
    Darkness likes this.
  3. Mar 9, 2020 at 1:39 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    With Toyota axles, the gear-set is accessed through the front/input side as opposed to how it's done in a typical Dana or Spicer axle in which it's accessed from the rear.
    A lot of heavy duty axles are set up similar to the way Toyota does it. For example, these are from a Deuce and a half. Granted these input at the top, but it's the same principle: the gears are accessed from the input side, and the opposite side is a welded-on cover.
    Sunnier, Mr0range and speedtre like this.
  4. Mar 17, 2020 at 6:23 AM
    rickybobby6969
    After talking to a SEM rep I’ve been told I can use their adhesive products to so called glue it on and then seam seal around it
    Mr0range likes this.
  5. Mar 17, 2020 at 6:39 AM
    tvpierce
    Maine
    You're going to cut off the old one, right?
  6. Apr 25, 2020 at 5:01 PM
    rickybobby6969
    Sorry for the month late reply yes I will be cutting it off this whole corona virus thing has delayed my progress on the truck I ran into a seized caliper so I’ve just replaced calipers rotors and pads as it was a must do
  7. Apr 25, 2020 at 5:55 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Dorman sells replacement covers for fairly cheap. welding them on isnt too much of a challenge...
  8. Apr 27, 2020 at 6:48 AM
    rickybobby6969
    I’m gonna buy the doorman cover and use the SEM product to attach it my only issue with welding it is getting a clean mettle to weld it on I live in Maine so just about everything is surface rusted to shit
  9. Apr 27, 2020 at 7:03 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    No leaks for $50. No noise, tight, new brake drums and shoes.
    TX-TRD1stGEN likes this.
